Custom exhaust in washington, oregon #2368681
09/11/17 08:00 AM
09/11/17 08:00 AM
tri-cities Washington/Denver, ...
5280Dart Offline OP
5280Dart  Offline OP
Looking for a shop to fab and install 3" exhaust on the hotrod. Anyone have a favorite?
Re: Custom exhaust in washington, oregon [Re: 5280Dart] #2369177
09/12/17 01:38 AM
09/12/17 01:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Accurate is in Oregon.
I'd call them and see if they do it themselves or have someone they recommend
Re: Custom exhaust in washington, oregon [Re: 5280Dart] #2369371
09/12/17 01:14 PM
09/12/17 01:14 PM
BlueRacer69 Offline
BlueRacer69  Offline
Second that. Accurate LTD. in Oregon.
Re: Custom exhaust in washington, oregon [Re: BlueRacer69] #2369543
09/12/17 06:04 PM
09/12/17 06:04 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Ditto!! Tom and his crew is first class.
Abe Lincoln
Re: Custom exhaust in washington, oregon [Re: 5280Dart] #2369548
09/12/17 06:09 PM
09/12/17 06:09 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Accurate doesn't do installs. Besides, Accurate is a long way from Tri-Cities. The Portland area probably has what you need, good luck!
Re: Custom exhaust in washington, oregon [Re: 5280Dart] #2370947
09/14/17 10:00 PM
09/14/17 10:00 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
There is a small shop in Glenwood, Oregon... It is in between Eugene and springfield... I havent been there in years but they used to do really nice work..
Accurate is in Sutherlin, just north of Roseburg...
Re: Custom exhaust in washington, oregon [Re: 5280Dart] #2371106
09/15/17 05:10 AM
09/15/17 05:10 AM
None of the Austin shops or Walt's automotive do custom exhaust anymore? confused
What brand, model, engine and year car is your hotrod?
I've bought and used several of the Summit kits one on my 1969 Dart GTS 383 4 speed car and I have two of there exhaust pipes only kits from the headers back with no mufflers for both my 1966 dodges BB Coronet and my 1963 BB Fury up
Lots of choices out there work scope
Re: Custom exhaust in washington, oregon [Re: 5280Dart] #2371126
09/15/17 10:15 AM
09/15/17 10:15 AM
E
earlymopar Offline
earlymopar  Offline
E
Muffler Works in Newberg is a shop that does both OEM and custom work. Just for some back ground, the owner is a gear head and drag racer and is the son of Larry Hill, brother of the late Jerry Hill, former race car fabricator and drag racer. I have taken stuff there for decades.
Muffler Works
406D N Main St
Newberg, OR 97132
(503) 538-3810
- EM
Re: Custom exhaust in washington, oregon [Re: earlymopar] #2372545
09/18/17 03:44 AM
09/18/17 03:44 AM
RT03 Offline
RT03  Offline
With the ridiculous amounts of money the muffler shops around the Portland area want for their lousy crush bent exhaust systems, you might be better off buying a kit from Summit if that would work for you.
The only shop I knew of in the Portland area that did mandrel bent systems closed it's doors on doing exhaust work. The new business does mandrel bends only-no installs.
Re: Custom exhaust in washington, oregon [Re: earlymopar] #2372670
09/18/17 12:54 PM
09/18/17 12:54 PM
AndyF Online content
AndyF  Online Content
Muffler Works
406D N Main St
Newberg, OR 97132
(503) 538-3810
- EM
I had Muffler Works do an exhaust system for me years ago and it came out very nice. I was pretty picky on what I wanted and they just put the car up on the lift and laid it all out the way I wanted and did it per my specs. They were okay with me standing under the car showing them what I wanted. This was more than 10 years ago so I don't know if they are still in business or if the same guys are still there or not. The shop is a little run down but they did excellent work for me. I need a new exhaust system for my Coronet so if they are still in business I'll stop by there and talk to them.
Re: Custom exhaust in washington, oregon [Re: AndyF] #2373188
09/19/17 10:17 AM
09/19/17 10:17 AM
E
earlymopar Offline
earlymopar  Offline
E
Yes, they are still in business. The son of Larry Hill (the original business founder) now runs the shop. I had the same experiences as you did with regard to being under the car directing the layout. I assume the son is the same way but can't speak from experience with him.
- EM
