Locked Dizzy and starting ? #2372586
09/18/17 10:13 AM
09/18/17 10:13 AM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Hey Guys it's been a little while since I posted on here but here it goes. My small block 422 CI engine has always started and run fine at 34* timing locked down dizzy. I have noticed lately that it seemed to buck when trying to start like it had too much timing. Well long story short , At the track this weekend it started okay for the first pass but when I got back to the pits it was really hard to start. I borrowed a battery "too small" but it started again. Won my first round but when I got back to my pit it would not start. I charged my original battery and replaced the starter with a hi torque unit. By that time I had missed the call for second round so I finally got the car started and loaded it up. Brought it home and the next day I charged the battery with my big charger and it started but still bucked like the timing was too high. I backed the timing down to 20* and checked the wiring and it starts right up and seems to run fine. I am sure that is not enough timing though. Any ideas what I should look into to find out what happened ? I am kind of lost on this one ..
6.50 @105.26
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372593
09/18/17 10:41 AM
09/18/17 10:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm thinking you didnt check the timing when it
was hard starting and I believe it moved on you
over time.. put it back to 34* and give it a
try and go from there.. the timing chain could
have stretched some also
wave
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372594
09/18/17 10:43 AM
09/18/17 10:43 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Why do you have it locked? What is a dizzy? lol
Yea your going to have this problem with a locked distributor, unlock it and tune it like it should be and have a reliable car.
Locked distributor tells me someone does not know how to tune a motor.
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372595
09/18/17 10:43 AM
09/18/17 10:43 AM
crabman173
crabman173
With any high compression engine or one that has the timing locked you wire it so you can spin the engine THEN hit the ignition "on" separately
That is how all race cars should be wired--this will solve most issues with hard starting
Re: Locked Dizzy and starting ? [Re: ] #2372599
09/18/17 10:49 AM
09/18/17 10:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is how I had my car set up.. started great
all the time(that was at 38*)
wave
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372601
09/18/17 10:54 AM
09/18/17 10:54 AM
Seaford, Va
Seaford, Va
Crabman 173 Thanks that is a good idea. I never really had a problem until lately that is what makes me go ???? My car isn't a high compression engine and it still has the factory wiring Street Car !! But I can give that a try and see what happens.
As far as tuning my car with a locked out distributor I have been doing it for years and never had a problem.
6.50 @105.26
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372605
09/18/17 11:10 AM
09/18/17 11:10 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Msd sells a starter saver that pulls 20 degrees of timing time the engine starts .. I use one on the duster with a crank trigger .. don't know if that would be an option or not ???
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372608
09/18/17 11:12 AM
09/18/17 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running a roller cam.. if so the intermediate
shaft could be worn a fair amount which causes slop and
timing issues
wave
Re: Locked Dizzy and starting ? [Re: MR_P_BODY] #2372631
09/18/17 11:40 AM
09/18/17 11:40 AM
Virginia
moparroad Offline
moparroad  Offline
Virginia
Cranking and then hitting ignition can be hard on gears. I turn on pump to fill bowls, then crank while pumping fuel for 5 seconds or so with out ignition, then turn on ignition and start. My engines usually only need this 1st start of the day and sometimes after sitting over an hour.
Easier on starter & ring gears.
It works for me!
BH
Re: Locked Dizzy and starting ? [Re: MR_P_BODY] #2372635
09/18/17 11:46 AM
09/18/17 11:46 AM
Seaford, Va
Seaford, Va
timing issues
wave
Hey thanks everybody for the ideas , I was thinking about the bronze gear also . It may be worn a little because I do run a roller cam and it has been in there for quite a while.
6.50 @105.26
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372654
09/18/17 12:15 PM
09/18/17 12:15 PM
Seaford, Va
Seaford, Va
Thanks again for the info and advice. Damn I hate it when you over think everything. The Optima Battery just didn't have the cranking amperage anymore. I took the battery out of my Motor Home 825 CCA and put it in the car . Set my distributor to 34* and it starts fine again. Damn battery cost me a ton of worry. Oh well at least I know what it is..
6.50 @105.26
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372661
09/18/17 12:28 PM
09/18/17 12:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My 470 BB starts fine at 12.1.1 comp locked at 36* unless the batteries get low from sitting a few weeks then a boost charge and it's fine and has been locked longer than I can remember.......... thumbs Starts the same weather I spin it first then hit the ign. or just crank it and I guess I'm not a good tuner since my dumb azz locked it out.......... biggrin
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372664
09/18/17 12:36 PM
09/18/17 12:36 PM
P
Paul_Fancsali Offline
P
What compression is the engine?I ran into a similar issue but it was ground problem
Re: Locked Dizzy and starting ? [Re: Thumperdart] #2372675
09/18/17 12:59 PM
09/18/17 12:59 PM
Seaford, Va
Seaford, Va
LOL Me too !!!!
6.50 @105.26
Re: Locked Dizzy and starting ? [Re: Paul_Fancsali] #2372679
09/18/17 01:01 PM
09/18/17 01:01 PM
Seaford, Va
Seaford, Va
Weak ass Optima Battery.. Cost me a few more passes at the track..
6.50 @105.26
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372699
09/18/17 01:31 PM
09/18/17 01:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run 2 Orbital gel batteries and one is from 07 and still rocks........... biggrin
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372710
09/18/17 01:51 PM
09/18/17 01:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How recent is centrifugal advance, in other words how far back do you need to go to buy a car with fixed advance?
Over 100 years.
Boffin Emeritus
Re: Locked Dizzy and starting ? [Re: ] #2372756
09/18/17 03:06 PM
09/18/17 03:06 PM
We had to do this on the stock car (only 9-1 CR) as it was cranky when hot. Battery was in the trunk tho but the cables were 1/0 or 2/0 & a regular starter.
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372759
09/18/17 03:20 PM
09/18/17 03:20 PM
Deerfield, Ohio
Deerfield, Ohio
How do you wire one to turn over and the ignition switch ?
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372944
09/18/17 09:10 PM
09/18/17 09:10 PM
A727Tflite Offline
A727Tflite  Offline
Correct me if I am wrong - locked out distributor - essentially the same as a crank trigger - no?
The biggest benefit to the crank trigger is you take the intermediate shaft slop between the cam and distributor out of the equation.
No scatter within the locked out distributor since the rotor and shaft are locked together.
As for starting - we always had a start switch and a run switch per the old Direction Connection instructions. Never any issues.
As for locked out distributors being used by people that can't tune - really - ?
