Page 1 of 3 1 2 3
E-body trunk torsion springs #237259
02/26/09 07:47 PM
02/26/09 07:47 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I have a question reguarding the possition of the trunk torsion springs. As you can see in the picture, there are multiple holes for the spring to go into. Depending on what hole you put the spring in, you would get more or less tension on the spring. Did cars that had spoilers from the factory have the springs installed in a different hole than cars without spoilers? I would think that the added weight of the spoiler would require more tension on the trunk springs in order to keep it open. If not...why all the extra holes?
Re: E-body trunk torsion springs [Re: burdar] #237260
02/26/09 08:00 PM
02/26/09 08:00 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yes, depending on the added weight it would have been at a different setting...Remember there was two different spoilers and also a luggage rack available in 1970...Also, generally 70 had two torsion bars and 71 had only one...
Re: E-body trunk torsion springs [Re: screamindriver] #237261
02/26/09 10:47 PM
02/26/09 10:47 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Really...71 only had one bar? My 73 has 2 and you couldn't even get a spoiler from the factory.
Re: E-body trunk torsion springs [Re: burdar] #237262
02/26/09 11:13 PM
02/26/09 11:13 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Yeap, '71 only had one.. Maybe they tried to cut costs and then realized it was a mistake, hence the 2 rod setup came back?
Troy
Houston Mopar Connection Club
Re: E-body trunk torsion springs [Re: hemi68charger] #237263
02/26/09 11:58 PM
02/26/09 11:58 PM
cataclysm80 Offline
cataclysm80  Offline
with everything said above...
Now if we could only get some info from survivor cars about which hole to use for what application?
Or Maybe we could just weigh the 4 options?
No Spoiler or luggage rack = lightest weight
Go Wing, Trans Am spoiler, Luggage Rack weigh how much?
I know if you use a fiberglass reproduction Trans Am spoiler that it's heavy enough that none of the tension setting will lift the trunk lid properly.
Tav
Re: E-body trunk torsion springs [Re: cataclysm80] #237264
02/27/09 01:14 AM
02/27/09 01:14 AM
I DA HOE
3
3406pac Offline
3406pac  Offline
I DA HOE
Ive asked that same question here before and only got the above responses.
Are there different lengths?
Mine seems to pop out on the right side and that is with very little tension. Although it may be bent and I dont know it. I wouldnt think that spring steel would bend and loose its memory. It is a 71 challenger vert on a plain trunk.
AAR cuda 71 rag challenger
Re: E-body trunk torsion springs [Re: burdar] #237265
02/27/09 01:23 AM
02/27/09 01:23 AM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
I am also interested in this topic.
Plus whats the thing on the mat close to the tire?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: E-body trunk torsion springs [Re: 340SIX] #237266
02/27/09 01:32 AM
02/27/09 01:32 AM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Take a look. 2 bars.
Re: E-body trunk torsion springs [Re: Topcat] #237267
02/27/09 08:25 AM
02/27/09 08:25 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've found that in 71 the Cudas had 2 rods and the Barracudas and Grand Coupes had one rod. Thats just what I've seen.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: E-body trunk torsion springs [Re: Topcat] #237268
02/27/09 08:29 AM
02/27/09 08:29 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Not only is that a 71 and it has two springs but...the orange body plugs for shock access, aren't on the top of the trunk pan. I thought 70-71 had the plug on top and 72-74 had it on the side. Maybe that's just on the Challengers?
Re: E-body trunk torsion springs [Re: burdar] #237269
02/27/09 11:40 AM
02/27/09 11:40 AM
The thing on the mat is a plastic bag that contained the valve stem caps. If you look you can see the white dot at the end of them. Originally, the cars came with the longer caps that had a white "push type" button in them. They were a pain especially if you tagged a curb and then pinched the cap, gave you a nice and slow air leak.
Re: E-body trunk torsion springs [Re: ] #237270
02/28/09 12:30 AM
02/28/09 12:30 AM
cataclysm80 Offline
cataclysm80  Offline
Again.
That's probably Dave Waldens car in the pic right?
Maybe he could shed some light onto the topic of trunk torsion bars for us with his extensive research.
Tav
Re: E-body trunk torsion springs [Re: cataclysm80] #237271
02/28/09 10:41 AM
02/28/09 10:41 AM
Winnipeg,Manitoba
cudablues Offline
cudablues  Offline
Winnipeg,Manitoba
My 73 Cuda has 1 rod.
Re: E-body trunk torsion springs [Re: burdar] #237272
02/28/09 10:46 AM
02/28/09 10:46 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
metal shock plugs are typically 1970 only, but have been found on some early 71's . where the orange plug on the side of the hump is typical for 1971 and later
Re: E-body trunk torsion springs [Re: hemi68charger] #237273
02/28/09 01:26 PM
02/28/09 01:26 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I've seen mid year cars with no spoiler or luggage rack have one rod (which is thicker) and late 71 having two rods.
I would bet that a 71 car with a spoiler or luggage rack would have two rods
Re: E-body trunk torsion springs [Re: Morty426] #237274
09/09/09 12:24 AM
09/09/09 12:24 AM
I DA HOE
3
3406pac Offline
3406pac  Offline
I DA HOE
7 Months later, and the mystery remains. Maybe this time it wont go so off subject.
Re: E-body trunk torsion springs [Re: 3406pac] #237275
09/09/09 12:50 AM
09/09/09 12:50 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
My T/A (with spoiler) has two rods.
My '71 (no spoiler) had one rod, but it was a larger diameter.
Is that a fake vehicle traveler sheet I see?
Re: E-body trunk torsion springs [Re: Alaskan_TA] #237276
09/09/09 03:51 AM
09/09/09 03:51 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
You decide.
Re: E-body trunk torsion springs [Re: Snoopy] #237277
09/09/09 03:56 AM
09/09/09 03:56 AM
Snoopy Offline
Snoopy  Offline
What do you think the multiple slots in the anchor brackets are for?
Read the factory service manual for deck lid tension adjustment.
Re: E-body trunk torsion springs [Re: Snoopy] #237278
09/09/09 10:20 AM
09/09/09 10:20 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
This set up works with my 1970 `cuda.
Second version trunk lid.
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Page 1 of 3 1 2 3
