E-body trunk torsion springs
#237259
02/26/09 07:47 PM
02/26/09 07:47 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I have a question reguarding the possition of the trunk torsion springs. As you can see in the picture, there are multiple holes for the spring to go into. Depending on what hole you put the spring in, you would get more or less tension on the spring. Did cars that had spoilers from the factory have the springs installed in a different hole than cars without spoilers? I would think that the added weight of the spoiler would require more tension on the trunk springs in order to keep it open. If not...why all the extra holes?
Re: E-body trunk torsion springs
[Re: burdar]
#237262
02/26/09 11:13 PM
02/26/09 11:13 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Really...71 only had one bar? My 73 has 2 and you couldn't even get a spoiler from the factory.
Yeap, '71 only had one.. Maybe they tried to cut costs and then realized it was a mistake, hence the 2 rod setup came back? ![](/ubbthreads/images/graemlins/shruggy.gif)
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#237263
02/26/09 11:58 PM
02/26/09 11:58 PM
Posts: 4,165 Florida
cataclysm80
![](/ubbthreads/images/graemlins/iagree.gif) with everything said above... Now if we could only get some info from survivor cars about which hole to use for what application? Or Maybe we could just weigh the 4 options? No Spoiler or luggage rack = lightest weight Go Wing, Trans Am spoiler, Luggage Rack weigh how much? I know if you use a fiberglass reproduction Trans Am spoiler that it's heavy enough that none of the tension setting will lift the trunk lid properly. Tav
[Re: cataclysm80]
#237264
02/27/09 01:14 AM
02/27/09 01:14 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
Ive asked that same question here before and only got the above responses. Are there different lengths? Mine seems to pop out on the right side and that is with very little tension. Although it may be bent and I dont know it. I wouldnt think that spring steel would bend and loose its memory. It is a 71 challenger vert on a plain trunk. Thanks ![](/ubbthreads/images/graemlins/smilie_help.gif)
AAR cuda
71 rag challenger
[Re: burdar]
#237269
02/27/09 11:40 AM
02/27/09 11:40 AM
The thing on the mat is a plastic bag that contained the valve stem caps. If you look you can see the white dot at the end of them. Originally, the cars came with the longer caps that had a white "push type" button in them. They were a pain especially if you tagged a curb and then pinched the cap, gave you a nice and slow air leak.
[Re: ]
#237270
02/28/09 12:30 AM
02/28/09 12:30 AM
cataclysm80
![](/ubbthreads/images/graemlins/iagree.gif) Again. That's probably Dave Waldens car in the pic right? Maybe he could shed some light onto the topic of trunk torsion bars for us with his extensive research. Tav
[Re: burdar]
#237272
02/28/09 10:46 AM
02/28/09 10:46 AM
Posts: 21,501 It's a dry heat
gtx6970
It's a dry heat
Not only is that a 71 and it has two springs but...the orange body plugs for shock access, aren't on the top of the trunk pan. I thought 70-71 had the plug on top and 72-74 had it on the side. Maybe that's just on the Challengers?
metal shock plugs are typically 1970 only, but have been found on some early 71's . where the orange plug on the side of the hump is typical for 1971 and later
[Re: hemi68charger]
#237273
02/28/09 01:26 PM
02/28/09 01:26 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I've seen mid year cars with no spoiler or luggage rack have one rod (which is thicker) and late 71 having two rods.
I would bet that a 71 car with a spoiler or luggage rack would have two rods
[Re: Morty426]
#237274
09/09/09 12:24 AM
09/09/09 12:24 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
7 Months later, and the mystery remains. Maybe this time it wont go so off subject.
AAR cuda
71 rag challenger
[Re: 3406pac]
#237275
09/09/09 12:50 AM
09/09/09 12:50 AM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
My T/A (with spoiler) has two rods. My '71 (no spoiler) had one rod, but it was a larger diameter. Is that a fake vehicle traveler sheet I see? ![](/ubbthreads/images/graemlins/shock.gif)
[Re: Snoopy]
#237277
09/09/09 03:56 AM
09/09/09 03:56 AM
Posts: 8,850 Central Coast, Calif.
Snoopy
What do you think the multiple slots in the anchor brackets are for? Read the factory service manual for deck lid tension adjustment.
