Water Temp Sender ( mechanical Water Temp Gauge
#2372097
09/17/17 09:37 AM
09/17/17 09:37 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I am going to use a Autometer mechanical (analog) water temp gauge. There is a fitting and metal LINE that are supposed to run from the passenger side of the water pump into the interior and then to the gauge 1) What size fitting is required ( any links ) 2) Where can I find this "line" that runs from the pump into the interior ? ( i have looked, searched on line, etc,,,but not having much luck )...I have this set up on the race car,,,( was already on the car when purchased ),,looks like a flexible spring like line,,,with the end that goes into the water pump having a dumbbell shaped fitting that seats into the water pump fitting ) ( trying to describe this as best as possible ),,, Thanks !!! Doug
Re: Water Temp Sender ( mechanical Water Temp Gauge
[Re: 69CHARGERMD]
#2372148
09/17/17 12:39 PM
09/17/17 12:39 PM
69CHARGERMD
KENTUCKY
Did not know that,,,,, I have one in the race car,,,,and if needed ( changing water pump, pulling motor, etc ),,,i usually just disconnect it at the water pump,,,, Have not removed any line from the gauge itself,,,, Thx for the info Moparx !!
[Re: 69CHARGERMD]
#2376040
09/24/17 07:55 PM
09/24/17 07:55 PM
69CHARGERMD
KENTUCKY
Thanks everyone,,,,, I got the gauge installed and it worked fine,,,, AutoMeter gauge,,,they supplied everything for the install,,,including the NPT fittings.. Thanks Moparx,,,only had to use 12 NPT fittings,,,just kidding,, thx
