Water Temp Sender ( mechanical Water Temp Gauge #2372097
09/17/17 09:37 AM
09/17/17 09:37 AM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
I am going to use a Autometer mechanical (analog) water temp gauge.
There is a fitting and metal LINE that are supposed to run from the passenger side of the water pump into the interior and then to the gauge
1) What size fitting is required ( any links )
2) Where can I find this "line" that runs from the pump into the interior ? ( i have looked, searched on line, etc,,,but not having much luck )...I have this set up on the race car,,,( was already on the car when purchased ),,looks like a flexible spring like line,,,with the end that goes into the water pump having a dumbbell shaped fitting that seats into the water pump fitting ) ( trying to describe this as best as possible ),,, shruggy
Thanks !!!
Doug
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2372108
09/17/17 10:11 AM
09/17/17 10:11 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
The tube running from the gauge to the WP comes with and is attached to the gauge on the Auto Meter gauges that I have used.
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2372130
09/17/17 11:52 AM
09/17/17 11:52 AM
KENTUCKY
KENTUCKY
Thanks Pushbutton !! I hope it's included. Thx.
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2372135
09/17/17 12:02 PM
09/17/17 12:02 PM
moparx Offline
moparx  Offline
the needed "tube" on mechanical water temperature gages are always attached to the gage. the "tube" is filled with a substance that expands and contracts with the temperature fluctuation. if that tube is cut, or removed from the gage somehow, that gage is now non-operational. they can be repaired, but with a commonly available aftermarket gage, it usually costs more to repair them than it does for the gage set.
beer
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2372148
09/17/17 12:39 PM
09/17/17 12:39 PM
KENTUCKY
KENTUCKY
Did not know that,,,,,
I have one in the race car,,,,and if needed ( changing water pump, pulling motor, etc ),,,i usually just disconnect it at the water pump,,,,
Have not removed any line from the gauge itself,,,,
Thx for the info Moparx !! wink
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2372221
09/17/17 02:46 PM
09/17/17 02:46 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It usually requires a hardware store bushing for the water pump.
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2372485
09/18/17 01:11 AM
09/18/17 01:11 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can't remove it from the gauge.
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2373897
09/20/17 02:15 PM
09/20/17 02:15 PM
P
Paul_Fancsali Offline
P
Use bells and pipe fittings to install on engine
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: Paul_Fancsali] #2375395
09/23/17 11:21 AM
09/23/17 11:21 AM
moparx Offline
moparx  Offline
make sure, however, the bulb is in the water flow path for an accurate reading. you may have to drill and tap the sender location to a bigger NPT size to accomplish this. plus, it will look much better than 23 adapter fittings screwed together.
beer
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2376040
09/24/17 07:55 PM
09/24/17 07:55 PM
KENTUCKY
KENTUCKY
Thanks everyone,,,,, I got the gauge installed and it worked fine,,,,
AutoMeter gauge,,,they supplied everything for the install,,,including the NPT fittings..
Thanks Moparx,,,only had to use 12 NPT fittings,,,just kidding,, thx wink
Re: Water Temp Sender ( mechanical Water Temp Gauge [Re: 69CHARGERMD] #2376350
09/25/17 11:54 AM
09/25/17 11:54 AM
moparx Offline
moparx  Offline
beer
