Need recommendations for a new timing light #2371297
09/15/17 04:51 PM
09/15/17 04:51 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
My timing light is over 30 years old, and my eyes are even older than that. I noticed trying to use it out in the sunlight at drag week I could hardly see the flash on the damper. So I need something that is really bright, and also durable and a dial back would be a plus. It needs to work with an MSD of course. What do you recommend? Thanks, Joel
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371302
09/15/17 05:01 PM
09/15/17 05:01 PM
Richmond Twp. Mi.
Mr340 Online content
Mr340  Online Content
Richmond Twp. Mi.
this is the one I got after my 30 year old craftsman took a crap.
https://www.summitracing.com/parts/ino-5568/overview/
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371306
09/15/17 05:10 PM
09/15/17 05:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you read the MSD site you will see that MSD
doesnt like the dial type of light.. the one
that is posted doesnt work with muli spark..
I ended up buying the Flaming River one.. no
dial back
wave
https://www.summitracing.com/parts/fla-fr1001
Re: Need recommendations for a new timing light [Re: Mr340] #2371311
09/15/17 05:18 PM
09/15/17 05:18 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
IF you read the questions under the add, this light will not work with MSD. The first line from 2016 says it will, but the bottom question from 2017 says it will not work.
Old Geezer Racing
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371316
09/15/17 05:29 PM
09/15/17 05:29 PM
Minnesota
Minnesota
I don't NEED the dial back, but really bright is essential
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371322
09/15/17 05:34 PM
09/15/17 05:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
http://www.ebay.com/itm/Sears-Best-Penske-Clamp-On-Inductive-Pickup-DC-Power-Timing-Light-NEW-/253108056771?hash=item3aee6a72c3:g:wqsAAOSwyWZZQDft
Seriously. I have one of the same old original lights sold by MSD many years ago. It's the only one I use on MSD stuff. Works perfect. If it blew up or got smashed, I would replace it with the same NOS one.
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371330
09/15/17 05:38 PM
09/15/17 05:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That can be a problem(brightness) but maybe my
eye sight is a bit better.. so far I havent had
any issues.. my first Flaming River quit and I
bought another.. after checking things the light
never quit.. I had so spark on the injection
wave
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371335
09/15/17 05:53 PM
09/15/17 05:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This is by far the best timing light period. Twice as bright and twice as accurate as anything else on the market. I have used it for years outside and IMO there is nothing better.
There's a reason it cost 3X as much as the flaming river job which is very slow and dull, especially outside.
LINK
I have used all of these at one point in time and the blue one is not even in the same class as the rest. The blue one is the same as what MSD sells even though MSD does not make it. That tells you something.
My blue one was sold to me by French Grimes the magneto guy when he did my mags. It kicks butt and is more accurate and brighter with a more focused light than the rest like I said above. There is nothing better I am telling you.
Re: Need recommendations for a new timing light [Re: SCATPACK 1] #2371349
09/15/17 06:20 PM
09/15/17 06:20 PM
Richmond Twp. Mi.
Richmond Twp. Mi.
Either my MSD is malfunctioning or their info is incorrect because it works fine on my vehicle. i bought it about 2 years ago so unless they changed something it should work.
Re: Need recommendations for a new timing light [Re: Mr340] #2371357
09/15/17 06:40 PM
09/15/17 06:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine would work intermittent with MSD that was why the
change.. plus MSD was saying about a issue
wave
Re: Need recommendations for a new timing light [Re: Challenger 1] #2371364
09/15/17 07:01 PM
09/15/17 07:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would not argue with him. Plus MSD sells it. That's good enough for me. My old chrome light is now 2nd choice.
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371379
09/15/17 07:43 PM
09/15/17 07:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In my experience, the problem with the dial back lights and multi-spark ignitions is...... They "seem" to be working fine, even when they aren't.
I've seen this happen on the dyno a few times where the owner of the motor being tested has brought his timing light with him.
Sometimes the dial back lights agree with the no dial back lights...... Sometimes they don't.
I've seen this play out several times.
No dial back lights and msd for me.
Re: Need recommendations for a new timing light [Re: Challenger 1] #2371385
09/15/17 08:01 PM
09/15/17 08:01 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What brand is that blue one?
Re: Need recommendations for a new timing light [Re: fast68plymouth] #2371411
09/15/17 08:55 PM
09/15/17 08:55 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Exactly.
Ferret Instruments makes very good very bright timing lights. Guess who makes MSD , some Snapon and probably that blue light?
Shop for price. It varies a lot.
Personally I use a jegs branded flaming river light that I bought on sale for $25. It is not as bright as a good light but because it has no handle I can get it closer to the marks. It does not have dialback but so what, I don't trust them anyway. Almost all aftermarket dampeners are degreed and frankly a timing tape with bright yellow numbers on a black background works very well for me. Super glue both ends of the tape and it will never come off.
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371426
09/15/17 09:22 PM
09/15/17 09:22 PM
Minnesota
Minnesota
Is This the same as an MSD light?it's less than 1/2 price.
Re: Need recommendations for a new timing light [Re: 71birdJ68] #2371622
09/16/17 09:37 AM
09/16/17 09:37 AM
Cincinnati, Ohio
Cincinnati, Ohio
I just looked in my home tool box and my french grimes timing light is at work in my tool box there so no close up pictures at this time. Mine says french grimes on it but made by ferret.
Like GomangoCuda said, they are made by ferret instruments for a number of manufactures that want to sell the best.
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371623
09/16/17 09:39 AM
09/16/17 09:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have an old chrome dial back Craftsman that I use at home, I don't have MSD so it works fine and it seemed to work fine when I did have MSD.
I have a flaming river one I take on drag week, its pretty dim but it works in a pinch. I don't check timing much anymore anyways.
68 Barracuda Formula S 340
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371624
09/16/17 09:40 AM
09/16/17 09:40 AM
Cincinnati, Ohio
Cincinnati, Ohio
It sure looks like it to me. You might try to cross some numbers to see if it is the same if possible? But I am betting it is the same light. Good find! up
Re: Need recommendations for a new timing light [Re: Hemi_Joel] #2371654
09/16/17 11:44 AM
09/16/17 11:44 AM
crabman173
crabman173
The Flaming River unit I had was junk--so dull you couldn't see it well at midnight and the D Cells were always dead when you needed it most--
I shop Ebay and buy old Mac and sears units from the 60's and 70's Great lights for around $20 so you can have one handy at all times
Re: Need recommendations for a new timing light [Re: ] #2371655
09/16/17 11:54 AM
09/16/17 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I really like my Flaming River one... love the
single wire hook up.. never had a battery issue
with it.. I've had the same batteries in it for
a few years.. it could be a bit brighter but
it works fine
wave
