Re: Need recommendations for a new timing light
[Re: Mr340]
#2371311
09/15/17 05:18 PM
09/15/17 05:18 PM
Posts: 1,505 TN
SCATPACK 1
TN
IF you read the questions under the add, this light will not work with MSD. The first line from 2016 says it will, but the bottom question from 2017 says it will not work.
Old Geezer Racing
[Re: Hemi_Joel]
#2371316
09/15/17 05:29 PM
09/15/17 05:29 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I don't NEED the dial back, but really bright is essential
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2371322
09/15/17 05:34 PM
09/15/17 05:34 PM
Posts: 11,557 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
http://www.ebay.com/itm/Sears-Best-Penske-Clamp-On-Inductive-Pickup-DC-Power-Timing-Light-NEW-/253108056771?hash=item3aee6a72c3:g:wqsAAOSwyWZZQDft
Seriously. I have one of the same old original lights sold by MSD many years ago. It's the only one I use on MSD stuff. Works perfect. If it blew up or got smashed, I would replace it with the same NOS one.
[Re: Hemi_Joel]
#2371330
09/15/17 05:38 PM
09/15/17 05:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I don't NEED the dial back, but really bright is essential That can be a problem(brightness) but maybe my eye sight is a bit better.. so far I havent had any issues.. my first Flaming River quit and I bought another.. after checking things the light never quit.. I had so spark on the injection
[Re: Hemi_Joel]
#2371335
09/15/17 05:53 PM
09/15/17 05:53 PM
Challenger 1
Cincinnati, Ohio
This is by far the best timing light period. Twice as bright and twice as accurate as anything else on the market. I have used it for years outside and IMO there is nothing better. There's a reason it cost 3X as much as the flaming river job which is very slow and dull, especially outside. LINK I have used all of these at one point in time and the blue one is not even in the same class as the rest. The blue one is the same as what MSD sells even though MSD does not make it. That tells you something. My blue one was sold to me by French Grimes the magneto guy when he did my mags. It kicks butt and is more accurate and brighter with a more focused light than the rest like I said above. There is nothing better I am telling you.
[Re: SCATPACK 1]
#2371349
09/15/17 06:20 PM
09/15/17 06:20 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
IF you read the questions under the add, this light will not work with MSD. The first line from 2016 says it will, but the bottom question from 2017 says it will not work. Either my MSD is malfunctioning or their info is incorrect because it works fine on my vehicle. i bought it about 2 years ago so unless they changed something it should work.
[Re: Mr340]
#2371357
09/15/17 06:40 PM
09/15/17 06:40 PM
MR_P_BODY
IF you read the questions under the add, this light will not work with MSD. The first line from 2016 says it will, but the bottom question from 2017 says it will not work. Either my MSD is malfunctioning or their info is incorrect because it works fine on my vehicle. i bought it about 2 years ago so unless they changed something it should work. Mine would work intermittent with MSD that was why the change.. plus MSD was saying about a issue
[Re: Challenger 1]
#2371364
09/15/17 07:01 PM
09/15/17 07:01 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would not argue with him. Plus MSD sells it. That's good enough for me. My old chrome light is now 2nd choice.
[Re: Hemi_Joel]
#2371379
09/15/17 07:43 PM
09/15/17 07:43 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
In my experience, the problem with the dial back lights and multi-spark ignitions is...... They "seem" to be working fine, even when they aren't.
I've seen this happen on the dyno a few times where the owner of the motor being tested has brought his timing light with him.
Sometimes the dial back lights agree with the no dial back lights...... Sometimes they don't.
I've seen this play out several times.
No dial back lights and msd for me.
[Re: fast68plymouth]
#2371411
09/15/17 08:55 PM
09/15/17 08:55 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
No dial back lights and msd for me. Exactly. Ferret Instruments makes very good very bright timing lights. Guess who makes MSD , some Snapon and probably that blue light? Shop for price. It varies a lot. Personally I use a jegs branded flaming river light that I bought on sale for $25. It is not as bright as a good light but because it has no handle I can get it closer to the marks. It does not have dialback but so what, I don't trust them anyway. Almost all aftermarket dampeners are degreed and frankly a timing tape with bright yellow numbers on a black background works very well for me. Super glue both ends of the tape and it will never come off.
[Re: 71birdJ68]
#2371622
09/16/17 09:37 AM
09/16/17 09:37 AM
Challenger 1
Cincinnati, Ohio
What brand is that blue one? I just looked in my home tool box and my french grimes timing light is at work in my tool box there so no close up pictures at this time. Mine says french grimes on it but made by ferret. Like GomangoCuda said, they are made by ferret instruments for a number of manufactures that want to sell the best.
[Re: Hemi_Joel]
#2371623
09/16/17 09:39 AM
09/16/17 09:39 AM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
I have an old chrome dial back Craftsman that I use at home, I don't have MSD so it works fine and it seemed to work fine when I did have MSD.
I have a flaming river one I take on drag week, its pretty dim but it works in a pinch. I don't check timing much anymore anyways.
68 Barracuda Formula S 340
[Re: Hemi_Joel]
#2371654
09/16/17 11:44 AM
09/16/17 11:44 AM
crabman173
crabman173
The Flaming River unit I had was junk--so dull you couldn't see it well at midnight and the D Cells were always dead when you needed it most-- I shop Ebay and buy old Mac and sears units from the 60's and 70's Great lights for around $20 so you can have one handy at all times
[Re: ]
#2371655
09/16/17 11:54 AM
09/16/17 11:54 AM
MR_P_BODY
The Flaming River unit I had was junk--so dull you couldn't see it well at midnight and the D Cells were always dead when you needed it most-- I shop Ebay and buy old Mac and sears units from the 60's and 70's Great lights for around $20 so you can have one handy at all times I really like my Flaming River one... love the single wire hook up.. never had a battery issue with it.. I've had the same batteries in it for a few years.. it could be a bit brighter but it works fine
[Re: WedgeFED]
#2371664
09/16/17 12:10 PM
09/16/17 12:10 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you find one that you love and trust don't loan it out. Ask me how I know.
[Re: pittsburghracer]
#2371698
09/16/17 01:53 PM
09/16/17 01:53 PM
GomangoCuda
If you find one that you love and trust don't loan it out. Ask me how I know. Yep. Thats why I bought the cheap light. My good light wandered off and couldn't find it's way home.
[Re: Hemi_Joel]
#2479220
04/08/18 02:49 AM
04/08/18 02:49 AM
Hemi_Joel
Minnesota
It looks like the Ferret instruments timing light is discontinued. So does MSD have a new vendor? Are they as good?
[Re: Hemi_Joel]
#2479474
04/08/18 03:50 PM
04/08/18 03:50 PM
GomangoCuda
It looks like the Ferret instruments timing light is discontinued. So does MSD have a new vendor? Are they as good? Another one bites the dust. Closed their doors October 31,2017. There are some tool companies that still have some but I bet they are going fast. I don't know who will take over the high end timing light market.
[Re: Hemi_Joel]
#2479543
04/08/18 06:14 PM
04/08/18 06:14 PM
Posts: 4,848 Memphis
HemiRick
Memphis
So in reading this it seems the best is a battery powered one? I really wish there was a dial back that worked w a MSD.....By the reviews on Amazon the Flaming river is far less than reliable and warranty service is non existent.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
