Re: Low oil pressure on first start up.....
[Re: rarefish]
#2370667
09/14/17 12:54 PM
09/14/17 12:54 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
The only plug I know of back there is installed by taking out the transmission. Pipe threads most likely, and the plug should be installed properly, from the proper side, for the best fit and seal against leaks. Have fun.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: rarefish]
#2370676
09/14/17 01:10 PM
09/14/17 01:10 PM
RapidRobert
A common L bend allen wrench with a flexible handle afixed to it might work so the handle would flex below the dist hole cuz an allen wrench needs a 60 sweep to get to the next "flat" on its 6 sides. Not sure if a person could rig up some kind of flexible "drilling" shaft like dentists' use so you could make that right angle turn to get it in. On a side note I drilled a 1/64" (.015") hole in an alum pipe plug (3/8 NPT) so the cam/intergear would get a constant stream of oil (tho you would think that area would be flooded with oil), one of my special internet tricks that ain't bit me in the a$$ yet (unlike the head gasket cooling holes). You will likely need to pull the intake (you may want to do the trans instead) as it is moderately tight access even with the intake off.
[Re: rarefish]
#2370837
09/14/17 05:51 PM
09/14/17 05:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Genius.
Oddly enough, I believe 5/16" is also the size of the oil priming rod.
[Re: rarefish]
#2370838
09/14/17 05:51 PM
09/14/17 05:51 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Do you want to take the oil pan off after you drop several of those fittings into the motor trying to install them through the distributor hole If not, remove the intake now Do that or the tranny and converter
[Re: Cab_Burge]
#2370848
09/14/17 05:59 PM
09/14/17 05:59 PM
Challenger 1
Cincinnati, Ohio
Do you want to take the oil pan off after you drop several of those fittings into the motor trying to install them through the distributor hole If not, remove the intake now Do that or the tranny and converter Got to read his post and comprehend, he already got the plug in through the dist hole. Good job rarefish.
[Re: Supercuda]
#2370852
09/14/17 06:04 PM
09/14/17 06:04 PM
RapidRobert
Genius.
Oddly enough, I believe 5/16" is also the size of the oil priming rod. (1) agreed! (2) it is
[Re: Cab_Burge]
#2370855
09/14/17 06:10 PM
09/14/17 06:10 PM
Posts: 2,252 New York
rarefish
New York
Do you want to take the oil pan off after you drop several of those fittings into the motor trying to install them through the distributor hole If not, remove the intake now Do that or the tranny and converter If it got away from me and I could not retrieve the plug or allen shank then I would be pulling the intake, but that did not happen. I got plug in fairly easy once the threads in-gauged.
[Re: rarefish]
#2370856
09/14/17 06:16 PM
09/14/17 06:16 PM
RapidRobert
I had heard that those ratcheting box end wrenches were pretty trick.
[Re: Challenger 1]
#2371052
09/15/17 01:00 AM
09/15/17 01:00 AM
Cab_Burge
Evidently we where both posting during the same time period, my reply was started before his second one was up and posted I'm glad he figure out a way to get the job done
