Low oil pressure on first start up..... #2370660
09/14/17 12:43 PM
09/14/17 12:43 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I finally started the 340 in my 1969 Dart after a semi rebuild. I was only seeing about 15 psi cold at idle. Well after some thought and inspection I found the culprit. My own fault... I forgot to install the pipe plug that goes in the rear of the driver's side oil galley. This is the one you can see looking down the distributor mounting hole.
I really do not want to pull the intake back off to gain access to the area. I have made a couple attempts to install the plug through the distributor hole, but no luck so far.
I have heard that some have been able to reinstall that plug going through the distributor hole. I want to know what their method was.....
Re: Low oil pressure on first start up..... [Re: rarefish] #2370667
09/14/17 12:54 PM
09/14/17 12:54 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
The only plug I know of back there is installed by taking out the transmission. Pipe threads most likely, and the plug should be installed properly, from the proper side, for the best fit and seal against leaks. Have fun.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Low oil pressure on first start up..... [Re: rarefish] #2370676
09/14/17 01:10 PM
09/14/17 01:10 PM
A common L bend allen wrench with a flexible handle afixed to it might work so the handle would flex below the dist hole cuz an allen wrench needs a 60 sweep to get to the next "flat" on its 6 sides. Not sure if a person could rig up some kind of flexible "drilling" shaft like dentists' use so you could make that right angle turn to get it in. On a side note I drilled a 1/64" (.015") hole in an alum pipe plug (3/8 NPT) so the cam/intergear would get a constant stream of oil (tho you would think that area would be flooded with oil), one of my special internet tricks that ain't bit me in the a$$ yet (unlike the head gasket cooling holes). You will likely need to pull the intake (you may want to do the trans instead) as it is moderately tight access even with the intake off.
Re: Low oil pressure on first start up..... [Re: RapidRobert] #2370834
09/14/17 05:49 PM
09/14/17 05:49 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
After a minor battle, I was able to get the oil galley plug in through the distributor hold. I had to rig up a tool by cutting a 1-5/8" piece off of a 5/16" allen wrench. Using and teflon tape, I secured the piece to 5/16" ratcheting box wrench. I put some teflon tape at the other end to secure the pipe plug to the allen shaft. I then used a large screw driver to apply forward pressure while turning the wrench.
I ended up with 80 psi using the priming drill. More that I thought that I would have being that the new pump that I put in was supposed to be high volume, but stock pressure.
Re: Low oil pressure on first start up..... [Re: rarefish] #2370837
09/14/17 05:51 PM
09/14/17 05:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Genius.
Oddly enough, I believe 5/16" is also the size of the oil priming rod.
Don't be the exception.
Re: Low oil pressure on first start up..... [Re: rarefish] #2370838
09/14/17 05:51 PM
09/14/17 05:51 PM
Do you want to take the oil pan off after you drop several of those fittings into the motor trying to install them through the distributor hole work If not, remove the intake now twocents
Do that or the tranny and converter shruggy
Re: Low oil pressure on first start up..... [Re: Cab_Burge] #2370848
09/14/17 05:59 PM
09/14/17 05:59 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Got to read his post and comprehend, he already got the plug in through the dist hole.
Good job rarefish. up
Re: Low oil pressure on first start up..... [Re: Supercuda] #2370852
09/14/17 06:04 PM
09/14/17 06:04 PM
Originally Posted By Supercuda
Genius.
(1) agreed! (2) it is
Re: Low oil pressure on first start up..... [Re: Cab_Burge] #2370855
09/14/17 06:10 PM
09/14/17 06:10 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
If it got away from me and I could not retrieve the plug or allen shank then I would be pulling the intake, but that did not happen. I got plug in fairly easy once the threads in-gauged.
Re: Low oil pressure on first start up..... [Re: rarefish] #2370856
09/14/17 06:16 PM
09/14/17 06:16 PM
I had heard that those ratcheting box end wrenches were pretty trick.
Re: Low oil pressure on first start up..... [Re: rarefish] #2371051
09/15/17 12:57 AM
09/15/17 12:57 AM
Washington/Las Vegas
1971 Gran Coupe Offline
Good ending to a problem that could have been a [censored]. I like the way you approached the fix. The shortcut paid off, and had it dropped, then the long fix was in order. Might be your week to buy a lottery ticket.
Re: Low oil pressure on first start up..... [Re: Challenger 1] #2371052
09/15/17 01:00 AM
09/15/17 01:00 AM
Evidently we where both posting during the same time period, my reply was started before his second one was up and posted shruggy
I'm glad he figure out a way to get the job done up
