Question about different diameter 360 flexplates #2370784
09/14/17 03:43 PM
09/14/17 03:43 PM
Badge Offline OP
Badge  Offline OP
I have a 360 motor that came with a 10 inch bolt circle flexplate. I have a 11 inch flexplate from a earlier 360 (mid 1970's) and matching torque converter. Any problem removing the 10" and using the 11" flex and converter?
Re: Question about different diameter 360 flexplates [Re: Badge] #2370802
09/14/17 04:37 PM
09/14/17 04:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
On an LA the stock type flex plate has to match the torque converter bolt pattern and the crank bolt pattern
Don't be the exception.
Re: Question about different diameter 360 flexplates [Re: Supercuda] #2370818
09/14/17 05:13 PM
09/14/17 05:13 PM
dogdays Offline
dogdays  Offline
You said "flex and converter". That'll bolt to the six bolt crank no sweat. As they are both 360 systems the factory imbalance is the same. If one was a 5.9Mag the answer would be no.
R.
Re: Question about different diameter 360 flexplates [Re: Badge] #2370821
09/14/17 05:18 PM
09/14/17 05:18 PM
the 10 inch plate is for a 904, the 11" plate/converter is for a 727. You'd have to use the setup to match whichever transmission you are using. the 360 was offered with both.
Re: Question about different diameter 360 flexplates [Re: RapidRobert] #2370922
09/14/17 08:50 PM
09/14/17 08:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 727 used both the 10" and 11" flexplate, as long as the flexplate matches the converter and the converter weight is correct for the 360 you're good to go.
Re: Question about different diameter 360 flexplates [Re: John_Kunkel] #2370940
09/14/17 09:43 PM
09/14/17 09:43 PM
Badge Offline OP
Badge  Offline OP
Thanks guys. I just wanted to make both the larger flex and the converter would work. Afraid the balance weight and bolt patterns might cause a problem.
Re: Question about different diameter 360 flexplates [Re: Badge] #2370975
09/14/17 10:36 PM
09/14/17 10:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Balance weight should be on the stock converter and all LA 360's use the same weight.
