First gen dakota power steering rack fitting size #2368613
09/11/17 01:08 AM
09/11/17 01:08 AM
tri-cities Washington/Denver, ...
5280Dart Offline OP
5280Dart  Offline OP
Anyone know what the pressure side hose fitting size is on a first gen dakota 2wd.
Tried a Russle 5/8-18 to AN fitting bUt the o-ring seat is about .100" short of seating, and the threads are a bit loose. I'm connecting to a gen III hemi pump, so a factory replacment hose for the dakota is not a sure bet, and I already have the rest of the braided hose assembly. .. thanks in advance
Re: First gen dakota power steering rack fitting size [Re: 5280Dart] #2368634
09/11/17 01:41 AM
09/11/17 01:41 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I promise the ps hose fitting on the Hemi will not match up with anything older. You may be a lot farther ahead to use the end from the Dakota and have the hose custom built.
I have a couple 91 Dakotas here, but I have no idea how one would identify what size the fitting is. I believe the fitting on the rack is a removable fitting, maybe it can be changed with something else? I'll look tomorrow if i get a chance. Gene
Re: First gen dakota power steering rack fitting size [Re: 5280Dart] #2368868
09/11/17 03:37 PM
09/11/17 03:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Might be 16MM metric.
https://www.summitracing.com/parts/rus-670531/overview/
Re: First gen dakota power steering rack fitting size [Re: 5280Dart] #2369126
09/12/17 12:18 AM
09/12/17 12:18 AM
ccarson Offline
ccarson  Offline
Call Stear & Gear in Columbus they will know
Re: First gen dakota power steering rack fitting size [Re: 5280Dart] #2370076
09/13/17 02:33 PM
09/13/17 02:33 PM
5280Dart Offline OP
5280Dart  Offline OP
The answer is 18 mm x 1.5.
