Advice, 77 Dodge brakes suck #2367144
09/07/17 07:38 PM
09/07/17 07:38 PM
Indiana
68_661charger Offline OP
Indiana
77 Dodge D100. Manual brakes. New master cylinder 1 inch bore, new rubber hoses, remanned calipers, turned rotors, semi metallic pads. In the rear new metal and rubber brake lines, wheel cylinders. Ive bled the brakes several times. I can plan to stop the truck with notice but i don't think its good enough for an emergency stop. Put it this way I dont think I could lock the brakes up on a wet road. Yeah I know, why would I want to? I just feel the brakes should grab. Ive had 4 wheel drums stop better than this. Would switching to a power booster make them stronger? Maybe a smaller bore master? Where to find?
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2367148
09/07/17 07:51 PM
09/07/17 07:51 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What was the bore size of the original master cylinder?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2367151
09/07/17 07:58 PM
09/07/17 07:58 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I have a 1-1/32" manual on my Duster that I would consider borderline and would be tough to lock up. When we built my sons BB '75 D100 we did away with the power brakes and installed a 15/16" mc (from Dr. Diff). It feels pretty good.
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2367164
09/07/17 09:02 PM
09/07/17 09:02 PM
Central US
grancuda Offline
grancuda  Offline
Central US
What brand rubber brake hoses did you get?
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2367172
09/07/17 09:16 PM
09/07/17 09:16 PM
Indiana
Indiana
The master I took off was an inch as well but it drove the same slightly worse. I belive the rubber hoses are Dormans and Ive read about smaller bore masters but I was unsure of the gain from a 1/16? An 1/8th at most?
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2367233
09/07/17 11:14 PM
09/07/17 11:14 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I think I would check to be sure the calipers can float on the mounting brackets like they are suppose to. As this stuff is getting older, the hard parts are showing up with wear we have not had to look at before. For instance, if the ears the front pad sit on have a little dip in them, the pads get hung up in the dip and won't move freely like they should. The result is poor brakes.
The same deal with the drum backing plates. The little raised pads the brake shoes sit against are suppose to be flat and smooth. Any roughness or wear will hang up the shoes from moving like they are suppose to, resulting in poor brakes.
I'm seeing a lot more brake issues then we ever saw before. I'm sure some of those issues are related to the off shore parts we seem to be stuck with, but a lot of issues are with older vehicles. I suspect we are beginning to see the always reused brackets and backing plates that are beginning to have wear we have never had to look at in the past.
The last Dakota I did (91 model year) had groves where the front brake pads sat that I ground clean, welded back up and sanded smooth, and the rear drum backing plated had groves where the shoes sat. I also ground them off, welded them up and ground them flat. The brakes on that Dakota are the best they have been since I've owned the truck.
Dodge put that truck together in 77 and I suspect the brakes were fine then. If the parts you have put on are functioning (holding fluid and have a solid pedal), its time to look at what else may need to be fixed before you start swapping out masters that may or may not overcome the worn parts. Gene
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2367294
09/08/17 01:39 AM
09/08/17 01:39 AM
Indiana
Indiana
Ill check for the wear marks on the caliper adapter next...
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2368460
09/10/17 08:42 PM
09/10/17 08:42 PM
IN
ahy Offline
ahy  Offline
IN
Some of the semi-mettalic pads/shoes take quite a bit of pressure to work.
The brakes might work better with low cost organic pads. Worth a try I think.
Re: Advice, 77 Dodge brakes suck [Re: ahy] #2368533
09/10/17 10:32 PM
09/10/17 10:32 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I've read about seating the pads and shoes by getting up some speed and then jamming the break pedal hard to get them seated. Might help. shruggy
Another thought, I once put new discs & pads on and forgot to clean the oil off the discs first with brake cleaner. Those suckers wouldn't stop on a 20 dollar bill, let alone a dime. I cleaned the discs and put new pads on and it stopped on that dime and gave 9 cents change.
It was on my '78 D-100.
I have mechanical Aptitude.
I can screw up anything.
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2368550
09/10/17 11:20 PM
09/10/17 11:20 PM
Indiana
Indiana
I've been wondering if organic would work better than semi-metallic? On the other hand I put on the fresh calipers with the old pads and un-turned rotors and old master cylinder and the truck basically stops the same as it does now with all the new stuff... I've also wondered if the original manual master was different from the two I've had? or try what poorboy suggested with the dimples in the adapter brackets. I've driven it a fair amount around the neighborhood practicing stops but I've yet to really get up to speed. Everything has been clean clean clean.
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2368855
09/11/17 03:17 PM
09/11/17 03:17 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I think the semi metallic would stop better.
They just wear things down faster.
That's due to the small bits of metal in them.
Might have to go back and check your hydraulics,
as many have suggested above.
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2369276
09/12/17 09:55 AM
09/12/17 09:55 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Metalic pads need a lot of heat (friction ) to work . without power assist theres no way to put enough pressure on them to work right . put a power booster on the truck or get the right pads. Not sure if you can get "organic" pads any more. Your pads are too hard.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2370234
09/13/17 06:08 PM
09/13/17 06:08 PM
Indiana
Indiana
Put on a set of cheapie organic pads and that did the trick. Truck stops like I feel it should. The semi-metallics might be for power brakes . Just glad its over. Thanks for all the suggestions.
Re: Advice, 77 Dodge brakes suck [Re: 68_661charger] #2370260
09/13/17 06:43 PM
09/13/17 06:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have been using some Performance Friction semi metallic pads on F450 and F550 trucks at work. They are there heavy duty top of the line pad for extreme service I was told when I shopped for them. Came from Oreillys. I am not impressed with the performance.
I test drove one at work just today with less than half a load on it after a repair and thought, woo these brakes suck. They worked but just did not feel good and I am doubting if they could lock up. You know what I mean?
The brakes are not that old and it got new rotors and pads when I did the brakes. They are power brakes.
I think the pads are more prone to glazing over and just today I was thinking to myself I was going to try a different pad and not metallic.
Thanks for letting us know what the final out come was. Glad you got it fixed.
Re: Advice, 77 Dodge brakes suck [Re: Challenger 1] #2370269
09/13/17 06:55 PM
09/13/17 06:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Manual brakes may take more effort to use.
They should not apply less pressure. shruggy
I myself prefer manual.
Brakes and steering.
Wouldn't have thought the pads themselves were the issue.
Good info for future use.
Also glad you got it figured out. up
Re: Advice, 77 Dodge brakes suck [Re: bboogieart] #2371690
09/16/17 01:43 PM
09/16/17 01:43 PM
IN
ahy Offline
ahy  Offline
IN
Glad it is sorted out.
