Re: Advice, 77 Dodge brakes suck
[Re: 68_661charger]
#2367148
09/07/17 07:51 PM
09/07/17 07:51 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
What was the bore size of the original master cylinder?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 68_661charger]
#2367164
09/07/17 09:02 PM
09/07/17 09:02 PM
Posts: 1,005 Central US
grancuda
Central US
What brand rubber brake hoses did you get?
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
[Re: 68_661charger]
#2367233
09/07/17 11:14 PM
09/07/17 11:14 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I think I would check to be sure the calipers can float on the mounting brackets like they are suppose to. As this stuff is getting older, the hard parts are showing up with wear we have not had to look at before. For instance, if the ears the front pad sit on have a little dip in them, the pads get hung up in the dip and won't move freely like they should. The result is poor brakes.
The same deal with the drum backing plates. The little raised pads the brake shoes sit against are suppose to be flat and smooth. Any roughness or wear will hang up the shoes from moving like they are suppose to, resulting in poor brakes.
I'm seeing a lot more brake issues then we ever saw before. I'm sure some of those issues are related to the off shore parts we seem to be stuck with, but a lot of issues are with older vehicles. I suspect we are beginning to see the always reused brackets and backing plates that are beginning to have wear we have never had to look at in the past.
The last Dakota I did (91 model year) had groves where the front brake pads sat that I ground clean, welded back up and sanded smooth, and the rear drum backing plated had groves where the shoes sat. I also ground them off, welded them up and ground them flat. The brakes on that Dakota are the best they have been since I've owned the truck.
Dodge put that truck together in 77 and I suspect the brakes were fine then. If the parts you have put on are functioning (holding fluid and have a solid pedal), its time to look at what else may need to be fixed before you start swapping out masters that may or may not overcome the worn parts. Gene
[Re: ahy]
#2368533
09/10/17 10:32 PM
09/10/17 10:32 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I've read about seating the pads and shoes by getting up some speed and then jamming the break pedal hard to get them seated. Might help. Another thought, I once put new discs & pads on and forgot to clean the oil off the discs first with brake cleaner. Those suckers wouldn't stop on a 20 dollar bill, let alone a dime. I cleaned the discs and put new pads on and it stopped on that dime and gave 9 cents change. It was on my '78 D-100.
I have mechanical Aptitude. I can screw up anything.
[Re: 68_661charger]
#2368855
09/11/17 03:17 PM
09/11/17 03:17 PM
bboogieart
Lost and Spaced
I think the semi metallic would stop better. They just wear things down faster. That's due to the small bits of metal in them. Might have to go back and check your hydraulics, as many have suggested above.
[Re: 68_661charger]
#2369276
09/12/17 09:55 AM
09/12/17 09:55 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Metalic pads need a lot of heat (friction ) to work . without power assist theres no way to put enough pressure on them to work right . put a power booster on the truck or get the right pads. Not sure if you can get "organic" pads any more. Your pads are too hard.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: Challenger 1]
#2370269
09/13/17 06:55 PM
09/13/17 06:55 PM
bboogieart
Lost and Spaced
Manual brakes may take more effort to use. They should not apply less pressure. I myself prefer manual. Brakes and steering. Wouldn't have thought the pads themselves were the issue. Good info for future use. Also glad you got it figured out.
[Re: bboogieart]
#2371690
09/16/17 01:43 PM
09/16/17 01:43 PM
Posts: 7,664 IN
ahy
IN
