1966 727 B-Body trans cooler line routing
#2368412
09/10/17 06:02 PM
09/10/17 06:02 PM
Posts: 321 Spokane, WA
FastbackJon
Spokane, WA
I am working on a 1966 Charger 318 poly automatic. I am replacing the transmission oil cooler lines (they were all cut up and patched with rubber splices) with the engine and transmission in the vehicle.
I have new pre-bent lines to put in. I see a boxed in hole in the K-frame on the driver's side under the motor mount. Is there any chance Chrysler would route the lines through that hole to protect them? Or should I just route them on the engine side of the K-frame?
I checked the service manual and online and found no information on this.
Thanks!
Re: 1966 727 B-Body trans cooler line routing
[Re: FastbackJon]
#2368454
09/10/17 08:32 PM
09/10/17 08:32 PM
RapidRobert
Or should I just route them on the engine side of the K-frame? that's where I would think, on top of the K just to the left (inside side) of the mtr mt in the pic.
[Re: RapidRobert]
#2368503
09/10/17 09:57 PM
09/10/17 09:57 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Or should I just route them on the engine side of the K-frame? that's where I would think, on top of the K just to the left (inside side) of the mtr mt in the pic. Exactly. Right up tight to the oil pan. Some set-ups even have a bracket in there somewhere close to the trans for the tubes to reside in. Nice to see someone using a Poly today. There are speed parts for them now too.
I have mechanical Aptitude. I can screw up anything.
[Re: FastbackJon]
#2368873
09/11/17 03:45 PM
09/11/17 03:45 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Cooler line routing. Support bracket mounts to lower starter mounting stud.
