Re: 440 external oil pump question.
[Re: Herbykw]
#2367241
09/07/17 11:22 PM
09/07/17 11:22 PM
RapidRobert
Herb Welcome here. I don't have an answer as my BB info is lacking & my cordoba exp is non existant but do post a pic when you get it figured out. I take it the piece/part that it is hitting cannot be trimmed?
[Re: Herbykw]
#2367375
09/08/17 10:56 AM
09/08/17 10:56 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Just use Milodon's 21815 oil pump and a stock oil pump cover. This pump has the inlet on the pump body, faces the front of the car, then you just bolt a stock cover onto it. I've used this setup on my cuda for years. http://www.manciniracing.com/brbhemwedalp.html
[Re: Herbykw]
#2367401
09/08/17 12:07 PM
09/08/17 12:07 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
Or use a stock pump and the plate from Milodon for the external line
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: Herbykw]
#2368338
09/10/17 02:59 PM
09/10/17 02:59 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have that same Source kit, it fit in the block fine, just some really minor grinding needed. Same here. Only minor grinding at the bottoms of some of the bores. I could probably have run an internal pickup but I already had all the external stuff so figured what the hell. Ironically, every piece I had I sold and replaced !!
