That's gotta slow you down a bit #2366247
09/06/17 08:29 AM
09/06/17 08:29 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Whaddya think? Bullet Roller. 279@50 500lb springs 4 seasons old.
Re: That's gotta slow you down a bit [Re: rebel] #2366255
09/06/17 09:08 AM
09/06/17 09:08 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That 2-cylinder engine must turn some serious RPM with that much cam. tonguue
Re: That's gotta slow you down a bit [Re: rebel] #2366263
09/06/17 09:39 AM
09/06/17 09:39 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Ouch
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: That's gotta slow you down a bit [Re: rebel] #2366339
09/06/17 12:30 PM
09/06/17 12:30 PM
Washington
madscientist Offline
Washington
I'd bet some sort of harmonics issue.
It could have also been a bad core but that stuff usually shows up before that much time goes by.
Seems to me the radial cracks looks like a harmonic issue though.
Re: That's gotta slow you down a bit [Re: rebel] #2366362
09/06/17 01:12 PM
09/06/17 01:12 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
My uncle had a 440 do the same. I think I remember him telling me the cam plug walked out, cam broke in 3 pieces, fell between the rods and ejected a few! Found a piece of the cam between the header tubes
Re: That's gotta slow you down a bit [Re: twayne24365] #2366380
09/06/17 01:37 PM
09/06/17 01:37 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had one break like that from a #4 cam bearing spinning and breaking at that journal. The rear two cylinders were not opening or closing. Drove it all the way home like that. Still ran like a V6 just fine with slightly less oil pressure. It required full rebuild anyway.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: That's gotta slow you down a bit [Re: rebel] #2366383
09/06/17 01:43 PM
09/06/17 01:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Really strange looking pattern on the 2nd lobe down from the break.
Never saw one look like that before....... But I have to suspect its related.
Re: That's gotta slow you down a bit [Re: rebel] #2366534
09/06/17 06:24 PM
09/06/17 06:24 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
So i'm thinking with this failure plus the other thread i have with the damper leaving marks on the crank snout, i need to replace the Damper to be sure i don't have a reoccurance. Anyone have a Summit Voucher theyre not using? $25 of your dollars is $40 of mine. every bit helps. thanx
Re: That's gotta slow you down a bit [Re: madscientist] #2366722
09/07/17 12:12 AM
09/07/17 12:12 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Years ago my buddy would break cams on a regular basis in a high hp chevy small block. It was a harmonics issue - he was using a gear drive. A Jesel belt drive solved the problem.
Re: That's gotta slow you down a bit [Re: rebel] #2366738
09/07/17 12:44 AM
09/07/17 12:44 AM
A727Tflite Offline
A727Tflite  Offline
What condition are the #1, 2 and 3 cam bearings? Have you measured them against the cam journal diameters?
Re: That's gotta slow you down a bit [Re: markz528] #2366796
09/07/17 03:27 AM
09/07/17 03:27 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
I'm already running a belt drive.
Re: That's gotta slow you down a bit [Re: A727Tflite] #2366831
09/07/17 09:29 AM
09/07/17 09:29 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Cam bearings all good. None have moved
Re: That's gotta slow you down a bit [Re: fast68plymouth] #2367235
09/07/17 11:16 PM
09/07/17 11:16 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that was the first thing I noticed, looks like a flat spot or somthing at the begnning of the ramp, looks like the same thing on the lobe nearest the dist drive gear, looks much lighter like a ghost mark. work
Re: That's gotta slow you down a bit [Re: rebel] #2367250
09/07/17 11:34 PM
09/07/17 11:34 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
ive had a cam break in 3 places before,cam was adjusted wrong was my problem
Re: That's gotta slow you down a bit [Re: rebel] #2367260
09/08/17 12:14 AM
09/08/17 12:14 AM
A727Tflite Offline
A727Tflite  Offline
Looks like your picture of the cam bearing was taken from he crankcase side of things. The cam wears on the bottom. Reason why I asked about clearance as we had this issue in production 3.3 and 3.8 engines where the cam would break. In every case the cam bearings were worn out badly from scratches left in the cam journals from a previous production issue. The cam bearings wore at the bottom leaving the cam unsupported. Yes those lobes look strange to me too. Not sure how lobe wear relates to a broken cam - I've seen dog bones fail and the lifter rotates 90 degrees without ever seeing a cam fail from that.
Re: That's gotta slow you down a bit [Re: rebel] #2367305
09/08/17 01:59 AM
09/08/17 01:59 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Yeah well I can't get my phone in from the other side to get a pic. As you can see it's an aftermarket block so no big hole to look thru but fingering it, I can't feel any difference with my eyes closed doing the Stevie Wonder test.
Re: That's gotta slow you down a bit [Re: rebel] #2367554
09/08/17 06:02 PM
09/08/17 06:02 PM
So. Burlington, Vt.
So. Burlington, Vt.
I would see if you could find an 8620 cam core for the replacement, and verify with the cam grinder you absolutely have enough spring load to keep the valvetrain under control.
I would also be trying to figure out what caused that witness mark on the lobe.
I don't know what your combo is, but it's the kind of mark I'd expect to see if there was some minimal contact between an aluminum rod and the cam.
Since you have an aluminum block its also certainly possible that just before/after the cam actually let go it whipped around inside the cam tunnel, and that's just the mark that was left.
If so, there should be a corrosponding mark in the tunnel where the contact was made.
Re: That's gotta slow you down a bit [Re: fast68plymouth] #2367564
09/08/17 06:38 PM
09/08/17 06:38 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Is it me or has it been repaired...did you check it for straight before the in stall
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: That's gotta slow you down a bit [Re: rebel] #2367590
09/08/17 07:53 PM
09/08/17 07:53 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
that mark you're seeing on the lobe is just the effect of the light from the flash on what was probably a bit of water laden oil. i took that pic as i pulled it off the motor. we've had rain for the past few months almost non stop so most of my oily stuff looks milky. i've wiped it down & its gone now. The cam has had a minor repair as last season a roller wheel collapsed so i had it refaced. hence the side damage on that lobe. ive put a new cam in the hole, it seems to be free spinning but i'm going to visit my machinist this morning & have him cast his eyeometer & micrometer over it just to be sure.
Re: That's gotta slow you down a bit [Re: markz528] #2367668
09/08/17 11:22 PM
09/08/17 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been using a gear drive for the last 8 years with
no problems and I'm putting engine together now with one
wave
