Re: That's gotta slow you down a bit
[Re: rebel]
#2366339
09/06/17 12:30 PM
09/06/17 12:30 PM
Posts: 4,457 Washington
madscientist
Washington
I'd bet some sort of harmonics issue.
It could have also been a bad core but that stuff usually shows up before that much time goes by.
Seems to me the radial cracks looks like a harmonic issue though.
[Re: twayne24365]
#2366380
09/06/17 01:37 PM
09/06/17 01:37 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I had one break like that from a #4 cam bearing spinning and breaking at that journal. The rear two cylinders were not opening or closing. Drove it all the way home like that. Still ran like a V6 just fine with slightly less oil pressure. It required full rebuild anyway.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: rebel]
#2366383
09/06/17 01:43 PM
09/06/17 01:43 PM
Posts: 14,502 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Really strange looking pattern on the 2nd lobe down from the break.
Never saw one look like that before....... But I have to suspect its related.
[Re: madscientist]
#2366722
09/07/17 12:12 AM
09/07/17 12:12 AM
Posts: 4,272 Morrow, OH
markz528
Morrow, OH
Seems to me the radial cracks looks like a harmonic issue though. Years ago my buddy would break cams on a regular basis in a high hp chevy small block. It was a harmonics issue - he was using a gear drive. A Jesel belt drive solved the problem.
[Re: rebel]
#2366738
09/07/17 12:44 AM
09/07/17 12:44 AM
Posts: 3,080 Michigan
A727Tflite
What condition are the #1, 2 and 3 cam bearings? Have you measured them against the cam journal diameters?
[Re: markz528]
#2366796
09/07/17 03:27 AM
09/07/17 03:27 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Seems to me the radial cracks looks like a harmonic issue though. Years ago my buddy would break cams on a regular basis in a high hp chevy small block. It was a harmonics issue - he was using a gear drive. A Jesel belt drive solved the problem. I'm already running a belt drive.
[Re: A727Tflite]
#2366831
09/07/17 09:29 AM
09/07/17 09:29 AM
rebel
aotearoa
What condition are the #1, 2 and 3 cam bearings? Have you measured them against the cam journal diameters? Cam bearings all good. None have moved
[Re: fast68plymouth]
#2367235
09/07/17 11:16 PM
09/07/17 11:16 PM
dartman366
Mt. Vernon, Ohio
Never saw one look like that before....... But I have to suspect its related. that was the first thing I noticed, looks like a flat spot or somthing at the begnning of the ramp, looks like the same thing on the lobe nearest the dist drive gear, looks much lighter like a ghost mark.
[Re: rebel]
#2367554
09/08/17 06:02 PM
09/08/17 06:02 PM
fast68plymouth
So. Burlington, Vt.
I would see if you could find an 8620 cam core for the replacement, and verify with the cam grinder you absolutely have enough spring load to keep the valvetrain under control.
I would also be trying to figure out what caused that witness mark on the lobe.
I don't know what your combo is, but it's the kind of mark I'd expect to see if there was some minimal contact between an aluminum rod and the cam.
Since you have an aluminum block its also certainly possible that just before/after the cam actually let go it whipped around inside the cam tunnel, and that's just the mark that was left. If so, there should be a corrosponding mark in the tunnel where the contact was made.
#2367564
09/08/17 06:38 PM
09/08/17 06:38 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Is it me or has it been repaired...did you check it for straight before the in stall
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: markz528]
#2367668
09/08/17 11:22 PM
09/08/17 11:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Seems to me the radial cracks looks like a harmonic issue though. Years ago my buddy would break cams on a regular basis in a high hp chevy small block. It was a harmonics issue - he was using a gear drive. A Jesel belt drive solved the problem. I've been using a gear drive for the last 8 years with no problems and I'm putting engine together now with one
