Anyone ever replace gasket on air cleaner cover? #236620
02/26/09 08:12 AM
02/26/09 08:12 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
And if you have, where did you get the replacement gasket?
I have a 70 RR, but I think the air cleaner is for a 71 - and the gasket on the cover seems to be cork and measures about 1/4" x 1/4".
Re: Anyone ever replace gasket on air cleaner cover? [Re: RM21N0A] #236621
02/26/09 09:48 AM
02/26/09 09:48 AM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
I need one too...
Re: Anyone ever replace gasket on air cleaner cover? [Re: charger440sixpak] #236622
02/26/09 11:16 PM
02/26/09 11:16 PM
Knoxville,Md
70redbee Offline
70redbee  Offline
Knoxville,Md
If you can't find a replacement just go to NAPA and buy yourself a roll of cork gasket material and make one yourself. Should be able to draw it out and cut it with a pair of scissors and keep the rest for another project. Can't have too many extra parts and pieces. Hope this helps.
Re: Anyone ever replace gasket on air cleaner cover? [Re: 70redbee] #236623
02/27/09 07:37 PM
02/27/09 07:37 PM
Martin TN
ridin98ci Offline
ridin98ci  Offline
Martin TN
I think he means the foam rubber seal on the air cleaner lid......try some stick on foam weather striping....just use some good glue
LOUD AND PROUD!!!
Re: Anyone ever replace gasket on air cleaner cover? [Re: ridin98ci] #236624
02/27/09 07:40 PM
02/27/09 07:40 PM
S.e. lower MIch..
66droptop Offline
66droptop  Offline
S.e. lower MIch..
I used a little black rubber washer...
Re: Anyone ever replace gasket on air cleaner cover? [Re: RM21N0A] #236625
02/27/09 10:49 PM
02/27/09 10:49 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I sent a world famous resto gasket making dude one about a year ago to get some made Either the one I sent was too far gone to copy, or he hasn't had time to get to it yet.
Re: Anyone ever replace gasket on air cleaner cover? [Re: JDMopar] #236626
02/27/09 11:02 PM
02/27/09 11:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I was wondering if the world famous gasket guru was on the job...
Re: Anyone ever replace gasket on air cleaner cover? [Re: 1_WILD_RT] #236627
02/28/09 01:39 PM
02/28/09 01:39 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Here's a picture of what I'm talking about. You can see where I already dug out a piece of the gasket, and how rusty the lid has gotten under it.
I've checked with Year One and Paddock about the gasket, and I've checked with several NAPA and other auto parts stores about 1/4" by 1/4" (or round 1/4") gasket material sold by the foot. No luck anywhere so far.
Someone must have replaced this before - mine can't be the only that got this corroded.
I want to dig the old one out, paint the thing, and put in another gasket, so I just need to get some ideas.
Re: Anyone ever replace gasket on air cleaner cover? [Re: RM21N0A] #236628
02/28/09 02:21 PM
02/28/09 02:21 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Later years have a foam type gasket. I have a nos one around here somewhere. As far as finding the cork one I have no idea. Mike
Re: Anyone ever replace gasket on air cleaner cover? [Re: mopars4ever] #236629
02/28/09 03:58 PM
02/28/09 03:58 PM
Mass
charge70 Offline
charge70  Offline
Mass
Go to the dealer and see if this part# is still available.It's 2536016 it may have been superseded by now.That's the factory # for that seal.I remember reading somewhere,I think MoPar Action that this factory part ends up being a little short and you'll need to order 2 of them.Worth checking into. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Anyone ever replace gasket on air cleaner cover? [Re: 1_WILD_RT] #236630
02/28/09 07:18 PM
02/28/09 07:18 PM
JDMopar Offline
JDMopar  Offline
It may not be worth Jims time to make these. I figured they were one long 1/4 x 1/4 foam ribbon, but they are actually a one piece foam ring. Jim is VERY detail oriented, and I don't think he would settle for making these less than perfect I'll bet it would cost out the yingyang to buy a piece of the correct foam, cut one gasket out and trash the rest.
Re: Anyone ever replace gasket on air cleaner cover? [Re: JDMopar] #236631
02/28/09 09:35 PM
02/28/09 09:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Back when Chrysler was selling a replacnemt seal it was a long straight ribbon that you cut to fit... It certianly doesn't need to seal absolutely perfect, whats the worse that would happen, air drawn in around the edge instead of through the open snorkle?
Re: Anyone ever replace gasket on air cleaner cover? [Re: 1_WILD_RT] #236632
02/28/09 10:55 PM
02/28/09 10:55 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
When I did mine I got some 1/4 inch window weatherstripping tape from Home Depot. Pulled out the old and stuck in the new--worked great.
Besides, as mentioned, it's not important that it seals, anyway. The real seal is between the lid and the air cleaner element.
Also, nobody will ever see it.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Anyone ever replace gasket on air cleaner cover? [Re: 1_WILD_RT] #236633
03/01/09 01:56 AM
03/01/09 01:56 AM
JDMopar Offline
JDMopar  Offline
I was just sayin that Jim won't make something less than perfect.
Re: Anyone ever replace gasket on air cleaner cover? [Re: RM21N0A] #236634
03/01/09 02:14 AM
03/01/09 02:14 AM
Knoxville,Md
70redbee Offline
70redbee  Offline
Knoxville,Md
Try DMT on ebag and if he doesn't have it maybe he will make it for you.I have bought some of his stuff and it fits pretty well.
Re: Anyone ever replace gasket on air cleaner cover? [Re: RM21N0A] #236635
03/01/09 02:25 AM
03/01/09 02:25 AM
AndyF Offline
AndyF  Offline
Used to be a replacement part at and Dodge dealer. I've replaced them before with the factory part but that was at least 10 years ago.
Re: Anyone ever replace gasket on air cleaner cover? [Re: AndyF] #236636
03/01/09 01:46 PM
03/01/09 01:46 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Home Depot has weatherstrip in a crapload of sizes. I re-did the cover on my 340 with it. I got 1/2 inch wide black urethane, seems to be working just fine, for like $7.
Re: Anyone ever replace gasket on air cleaner cover? [Re: 4BBodies] #236637
03/02/09 08:23 AM
03/02/09 08:23 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Thanks for all the replies and suggestions.
I was kind of stuck and needed to hear what some of you had done or ideas that you had.
Going to be in the sixties this coming weekend (snowing like crazy right now though) so I'll be able to paint outside, instead of in the deep sink next to the washing machine.
Then I'm sure I'll end up doing one of the things mentioned here.
Re: Anyone ever replace gasket on air cleaner cover? [Re: 4BBodies] #236638
03/02/09 10:42 AM
03/02/09 10:42 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've restored about 5 air cleaners with reg weather stripping from Home dump, I mean depot. Sold them on Ebay and people loved them. All A+ feedbacks. It fits perfect and no one will ever be able to tell.
Re: Anyone ever replace gasket on air cleaner cover? [Re: 1_WILD_RT] #236639
03/02/09 12:45 PM
03/02/09 12:45 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
This doesn't answer the issue of seeking "cork" as the gasket material, and I am setting myself up for some flaming, but...
In a previous life, I worked at an automotive electric shop that did a tremendous business in restoration after fires. It was indeed the unusual and small underhood fire that didn't somewhat damage the seal on the air cleaner lid. Bearing in mind that we weren't looking for paper-tag-on-the-radiator-neck restoration, just make-it-look-good-under-the-hood, the air cleaner housing would often get bead blasted and then rattle canned. Regardless of how much paint the housing needed or didn't need, without fail the top lid gasket "restoration" was to scrape out the old remains and gorilla snot in a length of 5/32" vacuum hose.
Probably not the best approach for the OE tent at the Nats, but it's not as Mickey Mouse as it sounds. Probably would pass muster with more people than you think.
Down to just a blue car now.
