Re: anyone buy a new 5.7/6.4 crate motor/wiring kit from mopar?
[Re: BlakDak71]
#2367397
09/08/17 11:57 AM
09/08/17 11:57 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I used it in my Dakota. Absolutely love it. Very easy, great instructions/diagrams. Zero complaints.
As mentioned, the manual transmission is recommended due to kickdown issues, so a manual VB trans would also be fine. What year Dakota love to see pics.
[Re: rbkt65]
#2367476
09/08/17 02:39 PM
09/08/17 02:39 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I did a 6.1 hemi with a 518 and used a cable drive throttle body and used a cable for the kickdown... wasn't a direct fit, but did the job. It's nice to be able to go to the local parts store and pick up parts any time.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: rbkt65]
#2379869
10/01/17 12:24 PM
10/01/17 12:24 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I bought an after market transmission controller for a NAG1. It has the speed sensor on the output shaft of the transmission. Works great and I get 23mpg avg on the hiway!!! 5.7/NAG1 5 speed auto/2:76 gear in an 8 3/4 rear end. Source soundgermanautomotive.com
Driving modern convenience in classic beauty
[Re: Darius]
#2379998
10/01/17 03:48 PM
10/01/17 03:48 PM
Posts: 4,254 Canada
WO23Coronet
Canada
I bought an after market transmission controller for a NAG1. It has the speed sensor on the output shaft of the transmission. Works great and I get 23mpg avg on the hiway!!! 5.7/NAG1 5 speed auto/2:76 gear in an 8 3/4 rear end. Source soundgermanautomotive.com You had a heck of a time getting it to work though didn't you? You also used a slipper driveshaft? If someone could come out with a ready to go controller for a NAG1 it would be a great transmission for any muscle car. Your 2.76 ratio with a NAG is like a 727 with a 4.10 off the line
[Re: MattW]
#2380250
10/01/17 10:05 PM
10/01/17 10:05 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
As mentioned, the manual transmission is recommended due to kickdown issues, so a manual VB trans would also be fine. What year Dakota love to see pics. x2
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2385497
10/11/17 10:21 AM
10/11/17 10:21 AM
Posts: 30 Bowling Green, KY
BlakDak71
Bowling Green, KY
As mentioned, the manual transmission is recommended due to kickdown issues, so a manual VB trans would also be fine. What year Dakota love to see pics. x2 For some reason, can't seem to find the pictures of the motor I have on my phone. I'll upload some later. Edit: tried to link a few from my imgur account, they aren't showing up though.
[Re: rbkt65]
#2387816
10/15/17 06:45 PM
10/15/17 06:45 PM
Posts: 118 Arkansas
hotrod98
Arkansas
I bought the new install kit from Mopar for a 6.4 hemi but after reading the instructions, it says that it won't work with my 2012 6.4 crate engine. Wonderful. Anyone know how to make it work with the earlier engine?
1970 Superbird 4-speed, Dana, bucket seats
[Re: rbkt65]
#2408740
11/25/17 06:05 PM
11/25/17 06:05 PM
Posts: 118 Arkansas
hotrod98
Arkansas
I'm in the same dilemma. I have the earlier 6.4 and bought the install kit. The older 6.4's don't have knock sensors and the new kit has connections for them. I read that you can eliminate the knock sensors but not sure what else is different. I need to figure out if I can make this kit work.
