5.7 Intake Manifold Compatibility
#2362906
08/31/17 04:03 PM
08/31/17 04:03 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Is there any ability to take the modern active intake manifold (variable runner) and put it on an early Gen III? (i.e. 2005 5.7)
Did some casual searching for this topic and did not come up with anything. I was considering taking a look at making something, but if there is bolt hole and port shape compatibility already, could be easier to modify than start from scratch
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 5.7 Intake Manifold Compatibility
[Re: VincentVega]
#2363012
08/31/17 07:14 PM
08/31/17 07:14 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Simple answer, no.....but if you take the whole top end of an Eagle 5.7 heads intake than yes....but the electrical end of it would need to be worked out.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: VincentVega]
#2363289
09/01/17 08:17 AM
09/01/17 08:17 AM
ric3xrt
Trumbauersville PA
http://3rdstrikeperformance.com/index.ph...roducts_id=1922Not sure if it's a good price but they have the adaptors. FWIW , I think your better off with the eagle heads. Let me Clarify my Simple answer NO, what is not taking into consideration when putting the eagle intake on the 03-08 heads is with the adaptors the Injector is now a1/4 higher in the charge path and shrouded by the adaptor, there is a reason there is a notch in the intake port on the early Hemi head. My $.02 worth ,
