FRONT DISC CONVERSION #236208
02/25/09 07:04 PM
02/25/09 07:04 PM
AZ
FM370RR Offline OP
mopar addict
FM370RR  Offline OP
mopar addict
AZ
im going to do the front disc conversion on my 70 runner.wilwood kit seems likely but how do strange,summit,and cant think of the name off hand but they advertise in the mope mags that use what looks like a gm caliper stack up?thanks for any info you can provide.
Re: FRONT DISC CONVERSION [Re: FM370RR] #236209
02/25/09 08:50 PM
02/25/09 08:50 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Not up on the aftermarket kits but you do know you can use A-body parts on yours?
http://www.moparts.org/Tech/tech/pages/b-ebody.html
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: FRONT DISC CONVERSION [Re: I_bleed_MOPAR] #236210
02/25/09 08:53 PM
02/25/09 08:53 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I used the whole spindle off a Diplomat cop car on my 72.Direct bolt on. A couple new hoses and a master cylinder swap and it stops on a dime.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: FRONT DISC CONVERSION [Re: FM370RR] #236211
02/26/09 02:41 AM
02/26/09 02:41 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
you in the phx metro area?
I have F body and late B set-ups out in the shop
Re: FRONT DISC CONVERSION [Re: FM370RR] #236212
02/26/09 02:53 PM
02/26/09 02:53 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Try www.scarebirds.com I bought the bracket hardware from them, and then I went to napa/advanced and purchaced my choice of GM parts. They work well with my manual set up. I have about 10k miles on the dart w/14 inch rallys. Give em a call they can e-mail you the parts list and instructions before you buy..
Re: FRONT DISC CONVERSION [Re: Dakota_Don] #236213
02/26/09 03:39 PM
02/26/09 03:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yes, the above is a great link ... if you want to scare birds away !!! It won't help with your brake swap.
Re: FRONT DISC CONVERSION [Re: Stanton] #236214
02/26/09 03:42 PM
02/26/09 03:42 PM
"Scare birds away such as pigeon pests - repel pigeons from convinient roosting areas in combination with sonic ultrasonic or electronic bird repellers and get rid of your pigeon problems with distress calls featured on Bird-X's bird control repellers."
Hahahahahaha...
Re: FRONT DISC CONVERSION [Re: nomore65BelvJim] #236215
02/26/09 03:50 PM
02/26/09 03:50 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Thats what I used twice and they are a great setup.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: FRONT DISC CONVERSION [Re: Stanton] #236216
02/26/09 04:09 PM
02/26/09 04:09 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
ya, what-ever
Re: FRONT DISC CONVERSION [Re: Dakota_Don] #236217
02/26/09 04:40 PM
02/26/09 04:40 PM
Northwest Chicago Suburb
DaDart Offline
DaDart  Offline
I think this is the correct site
brakes
3 Darts and a Ram
Re: FRONT DISC CONVERSION [Re: DaDart] #236218
02/26/09 05:16 PM
02/26/09 05:16 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Oh me sooooooooooo Bad LoL sorry, LoL thank you for correcting the web site LoL god i love the internet. LoL reminds me the time i was looking for info on the whitehouse LoL
Re: FRONT DISC CONVERSION [Re: Dakota_Don] #236219
02/27/09 01:53 PM
02/27/09 01:53 PM
AZ
FM370RR Offline OP
mopar addict
FM370RR  Offline OP
mopar addict
AZ
ended up goin with this kit.it uses all mopar stuff.
http://www.speedwaymotors.com/mopar-disc-brake-kit,3793.html
Re: FRONT DISC CONVERSION [Re: FM370RR] #236220
02/27/09 02:18 PM
02/27/09 02:18 PM
you could have done it alot cheaper if you would have listened to what you were told here.
Re: FRONT DISC CONVERSION #236221
02/27/09 03:01 PM
02/27/09 03:01 PM
AZ
FM370RR Offline OP
mopar addict
FM370RR  Offline OP
mopar addict
AZ
ya i prolly could have saved a few bucks but im happy with my 1 stop purchase.
Re: FRONT DISC CONVERSION [Re: FM370RR] #236222
02/27/09 03:18 PM
02/27/09 03:18 PM
O
OLD318 Offline
OLD318  Offline
O
This is just my
NOTE: This is counter to what everyone else is saying on here.
Having been there and done a 70-B Body disc brake swap, (from 4 way power drum) I would personally recommend the setup from master power brakes...
If you think you can do it any cheaper/ any
better I would tell you from bitter experience, that's not really true.
You can do it cheaper...
But your braking performance/experience behind the wheel, might not match your expectation.
and that's why your converting in the first place isn't it?
I would strongly recommend that kit with the power booster and the master cylinder from
MP Brakes...
Your brake lines to your drum metering valve
can stay there, just get the disc brake
A-Body metering valve (from inline tube)
That way you don't change your brake lines...
Best of luck to you either way!!!
Also, your drum brake steel wheels if they are
original 14x5 drum wheels will not fit.
you need a 14x5.5 disc brake wheel.
Check you salvage yards 1977-78 Plymouth volare
Dodge Aspen...same wheels slightly larger offset
They work perfect with the A-body swap
(Which is all the MP brakes kit is really)...
PM me if you have any questions/concerns...
Once you get the kit setup right..
it is a BIG improvement over front drum!
Just remember, at the end of the day..
The KEY To all of these parts working right
is pressure out of the master cylinder.
There is an excellent article on the MP Brakes
website which explains all of this...
It's a GREAT READ!!!.. please indulge..
My
Re: FRONT DISC CONVERSION [Re: OLD318] #236223
02/27/09 03:50 PM
02/27/09 03:50 PM
AndyF Offline
AndyF  Offline
There are so many choices these days that I don't think there is a universal answer.
For instance, I'd never consider putting a MP brake kit on any car I worked on but I tend to work on stuff where the owner is going to take the car to regular track days. For those customers we only use Brembo calipers, typically Porsche or Viper setups. I tend to install 13 inch kits with aluminum hubs and custom wheels. But that kind of stuff costs about $2000 per axle.
On the other hand, low end kits like the MP and SST stuff are the perfect solution for daily drivers, especially if the owners aren't very handy and don't want to slog thru wrecking yards looking for 11.75 setups.
There is also a whole universe of guys who are handy with a wrench but don't have a lot of money and for those folks the factory 11.75 conversion is a super deal.
And of course, the drag race guys prefer lightweight brakes since they only stop once every hour or so. So they have a bunch of choices from Wilwood, Aerospace, etc to pick from.
Re: FRONT DISC CONVERSION [Re: FM370RR] #236224
02/28/09 12:11 PM
02/28/09 12:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This kit from Speedway looks like the ticket !! Everything you need in one box. Could it REALLY be done that much cheaper scavenging wrecks and buying the odd new parts !! Everything here is NEW - there is a value in that !!! It's ALL Mopar too.
http://www.speedwaymotors.com/Mopar-Disc-Brake-Kit,3793.html
Re: FRONT DISC CONVERSION [Re: Stanton] #236225
02/28/09 01:28 PM
02/28/09 01:28 PM
BDW Offline
BDW  Offline
No you can't get cheaper than that. Only problem is the kit uses the smaller rotor. I did the Mopar Action 11.75 swap. Despite what everyone say, it ends up costing as much as the kit.
Unless you get the spindle and caliper adapter from the junkyard (your time is worth something) it adds up.
I've never seen used spindles and 11.75 adapters go for less than $150 - $200.
Re: FRONT DISC CONVERSION [Re: Stanton] #236226
02/28/09 02:14 PM
02/28/09 02:14 PM
They are only about a half mile from me & in fact I used to work in their machine shop. They are fairly quality conscious there but it is mostly chebby orientated. they consider returns to be a great profit reducer/time waster and are real anal about that so make your parts selection carefully & ask as many pertinent questions as you need to even if the tech has to go get someone else to ans all your Q's before you place your order. EDIT a defective part is a different story but mainly they want customers to get the right part(s) the FIRST time & there's not a lot of Mopar knowledge there so take all the time you need with them.
