Re: K frame date code
[Re: 71GTX471]
#2361970
08/29/17 10:00 PM
08/29/17 10:00 PM
Posts: 259 n.c.
geo.
n.c.
Yes, 73- A and B bodies have spool type mounts. If production date is correct, it could be from an E body. Or I guess a replacement part could have dates even later than '74. The Kit Car program was using E body K members "till the program ended. And yes, the E body Ks are the same as '71-2, Bs.
[Re: moparmarks]
#2932602
06/12/21 07:38 PM
06/12/21 07:38 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
OK this is really strange,checked the date code on the K frame in my 71 GTX today I suspected it has been replaced has no skid plate,the damm date code is the same exact as the one I started this post for way back in 2017, 217 40 cant make this s#@t up,so now I know its not original.
[Re: 71GTX471]
#2933019
06/13/21 11:43 PM
06/13/21 11:43 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Is it possible
217 40
174 day of 1970 - 2nd shift
And they put the 2 in the wrong place
Also if no coin , did you still find a stamped two digit part number
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
