K frame date code #2361598
08/29/17 10:47 AM
08/29/17 10:47 AM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
I was looking a K frame @ E Town this weekend that had the rounded skid plate & no coin on it,the date code stamped on front is 2174 0 the vender selling it said it fits 71/74 B & E,has the 2 idler arm brackets & 2 holes in front lip for sway bar brackets couldn't recall what to look for @ the time for the later sway bar mounting & pass through holes.what year would this be based on the date code.
Re: K frame date code [Re: 71GTX471] #2361612
08/29/17 11:21 AM
08/29/17 11:21 AM
blewbyu Offline
blewbyu  Offline
Its the 217 day of 1974 if i am reading the date code correct
Re: K frame date code [Re: 71GTX471] #2361684
08/29/17 01:20 PM
08/29/17 01:20 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Definitely is not 71-4 b-body as there is no such thing. 71-2 b-body bolts directly to the frame and 73-4 b-body uses an isolator bushing k-member.
Re: K frame date code [Re: 71GTX471] #2361946
08/29/17 09:25 PM
08/29/17 09:25 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
That's right I forgot about the 73/74 being a isolated K frame which it wasn't, 217 74 is what I was thinking but didn't make sense,can a 74 still have a skid plate,wouldn't 74 also have spool type motor mounts or did that start later.
Re: K frame date code [Re: 71GTX471] #2361970
08/29/17 10:00 PM
08/29/17 10:00 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Yes, 73- A and B bodies have spool type mounts.
If production date is correct, it could be from an E body.
Or I guess a replacement part could have dates even later than '74.
The Kit Car program was using E body K members "till the program ended.
And yes, the E body Ks are the same as '71-2, Bs.
Re: K frame date code [Re: 71GTX471] #2362519
08/30/17 08:51 PM
08/30/17 08:51 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Could a 72 up E body K still have a skid plate it looked factory installed to me.
Re: K frame date code [Re: 71GTX471] #2362601
08/30/17 11:28 PM
08/30/17 11:28 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
E-body never had spool mounts.
Got any pictures?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: K frame date code [Re: moparmarks] #2932602
06/12/21 07:38 PM
06/12/21 07:38 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
OK this is really strange,checked the date code on the K frame in my 71 GTX today I suspected it has been replaced has no skid plate,the damm date code is the same exact as the one I started this post for way back in 2017, 217 40 cant make this s#@t up,so now I know its not original.
Re: K frame date code [Re: 71GTX471] #2932716
06/13/21 08:25 AM
06/13/21 08:25 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
K frames with the skid plates where for the hemi cars. Not sure if the k frames where actually date coded but believe they have part #'s. They reproduce the skid plates so someone could weld one on and try to pass it off for original. The originals i seen had factory welds and scrapes from it hitting the asphalt.
Re: K frame date code [Re: Moparite] #2932841
06/13/21 03:43 PM
06/13/21 03:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1970 - 1972 B & E-bodies with 440HP, 440+6 & HEMI all used a k-frame with a skid plate
Re: K frame date code [Re: 71GTX471] #2933019
06/13/21 11:43 PM
06/13/21 11:43 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Is it possible
217 40
174 day of 1970 - 2nd shift
And they put the 2 in the wrong place
Also if no coin , did you still find a stamped two digit part number
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: K frame date code [Re: bee1971] #2933020
06/13/21 11:45 PM
06/13/21 11:45 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Part
Siberian Huskies
