Re: Torque converter spec page inside
[Re: Clanton]
#2366669
09/06/17 10:31 PM
09/06/17 10:31 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
to check the crank bolt clearence to the converter lay the flex plate on the converter pilot up with bolts under the flex plate like it would be on the engine.On the last pic you can see the bolt marks around the anti balooning plate where it needs to be cut deeper by .150 and .500 wider. ps: the crank bolts are .250 to .265" tall at the head with a bolt circle diameter of 4.250 ring to clear around them.
[Re: Clanton]
#2366766
09/07/17 01:30 AM
09/07/17 01:30 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I am generally a stick guy but this info is great. Im saving it and thanks for posting. I do have a mopar with a 727 that has a stock converter but it is way to tight and i am going to upgrade. This info will come in handy to check everything out
