What output and brand Alternator should I use? #2361164
08/28/17 02:38 PM
08/28/17 02:38 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Going to be running electric fans and maybe some aftermarket stuff. Will not have an altmeter. Have All new harnesses from M&H. I've read stuff about 1 wire Alternators but still not for sure what would be best for me, maybe 120 amp also??? Thanks!
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2361179
08/28/17 03:13 PM
08/28/17 03:13 PM
dogdays Offline
dogdays  Offline
IIRC the one-wire alternator was developed primarily for the hot rod crowd because it looks better and doesn't require as much wiring. Back in the day, they didn't start charging right away, but had to get over a certain rpm to start charging. So they're okay for a garage queen, but I wouldn't have one for a daily driver. Here's what the MAD website says:
http://www.madelectrical.com/electricaltech/onewire-threewire.shtml
About size - well, it has to fit. Size? Think of all the things you are going to be using on your car, find the max amps and add. As you won't probably be using everything at once, the total of all the max loads should be sufficient.
Again, back in the day, upgrading from a 37 amp alternator to a 65 amp one was the thing to do. Now, I'm guessing you will probably be looking at a 120 amp alternator. Keep in mind that modern electronics are becoming much more efficient, like the newest amplifiers, also LEDs for lighting. To calculate total lighting load, add all the wattages from all the bulbs and divide by 12. Electric fans are an area I have not explored.
Good Luck!
R.
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2361279
08/28/17 07:01 PM
08/28/17 07:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Powermaster brand
I had both their resto line and HO line of alternators, ZERO issues and ZERO failures, IMHO I wouldn't use anything else, they have a wide spread of alts to fit all applications and needs, well worth the money spent in my opinion, choose an application that fits your needs, when you let price dictate an inadequate purchase, that's when failure rears it's head
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2361296
08/28/17 07:28 PM
08/28/17 07:28 PM
waco tx
gogo318 Offline
gogo318  Offline
waco tx
I second Dog Days the one wire alternator does not charge below 1500 RPMs roughly they didn't do great for daily drivers that saw a lot of around town use sitting at traffic lights and what not ask for your amperage I have a 140 amp that I robbed off of a Ramcharger that was outfitted for fire truck use I believe that it is a Mopar product but I'd have to double check for you I run an electric fan a 500 watt amp and AC with the headlights on it sometimes Cuts in and out at idle but driving is fine and charges just to give you a point of reference
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: What output and brand Alternator should I use? [Re: gogo318] #2361389
08/28/17 10:13 PM
08/28/17 10:13 PM
IN
ahy Offline
ahy  Offline
IN
First step is to figure your loads... and go from there. Ignition, fuel pump, fan, lights, AC?, accessories. There are posts in the archives to help with "standard" loads.
An electric fan pulls a lot of amps and the fan is mostly needed in traffic or low speed which means idle RPM. You need lots of alternator idle output with electric fan.
As far as what to run, it depends in part on weather you are running AC. A 120 amp Denso can be retrofitted pretty eaisly with "non AC" setup. "With AC" needs specific brackets which do not fit the Denso or other alternatives so well.
There are 140+ high amp alternators available from Powermaster (GM based) though these may not fit well with BB and AL heads. "No fit" in my case with a BB and Edelbrock heads.
FWIW I run a BB with EFI, big fuel pump and mechanical fan. With the big fuel pump + electronics, a 75A (max) output alternator could barely keep up running and big discharge at idle. I switched to the "big Chrysler" alternator from a '78 Cordoba (100+ amps) and it does fine. Just heavy.
With electric fan I think you need 120+ amps output and good idle output.
I may switch to a Quality Power unit to save weight (link below).It promises to install same as a "square back". Just a little spendy.
Whatever you do, please post results.
http://www.qualitypowerauto.com/item_557/Chrysler-Mount-Mega-Amp-Alternator.htm
Re: What output and brand Alternator should I use? [Re: ahy] #2361392
08/28/17 10:19 PM
08/28/17 10:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
This makes me wonder about their Mopar knowledge:
"Direct bolt-in replacement for most early Chrysler, Dodge, and Plymouth vehicles up to 1983"
Up to 83?
Don't be the exception.
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2361411
08/28/17 10:50 PM
08/28/17 10:50 PM
eastern,Ky
eastern,Ky
Yeah going to have Vintage Air, Fans, Killer sound system, 440 RB 240 TF heads and so forth. With a 3 wire set up and no altmeter would I still need to run a wire form the alternator to the starter to pull some of the juice off of the factory harness. Yeah If I have to pay the extra $$$ that's fine I just want my electrical system working right and safe. Getting the correct mounting brackets and pulleys to work with the AC is a big plus also lol. Thanks!
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2361430
08/28/17 11:06 PM
08/28/17 11:06 PM
IN
ahy Offline
ahy  Offline
IN
As far as wiring goes, yes you need a bypass with increased loads and alternator output.
Re pop factory wiring will not take the current. With M&H harness I ran 6 gauge bypass from alternator to fender relay and from there to starter and battery in trunk via 1 gauge cable. I put a 10 gauge fusible link in the 6 gauge cable between alternator and fender relay.
Also, I believe conventional regulator (eg 3 wire) is better and that is what I run on my Mopar. One wire is OK... the charge wire just needs to be heavy and short because remote voltage sensing is not compensating alternator output for voltage loss in the wiring.
Maybe I have been lucky... the black MP voltage regulator I bought 15 years ago still works fine with my bigger alternator. I cannot same the same about the "premium" reman alternators that I have run.
Re: What output and brand Alternator should I use? [Re: ahy] #2361433
08/28/17 11:09 PM
08/28/17 11:09 PM
On a side note I would absolutely do Nachos' bulkhead parallel bypass.
Re: What output and brand Alternator should I use? [Re: ahy] #2362636
08/31/17 12:23 AM
08/31/17 12:23 AM
eastern,Ky
eastern,Ky
What your calling the squareback is that like the original that would have came on my car. I called powermaster and you're right they had nothing that would fit my car with high amperage without making special brackets to make them fit.
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2368084
09/09/17 11:30 PM
09/09/17 11:30 PM
Indiana
toms Offline
toms  Offline
Indiana
You probably have already gotten your alternator? What I have is a Tuff stuff alternator that puts out amps at low RPM that fits right where the old one did with no problems. I'm running 2 fans that draw 37 amps electric pump at 10 amps. The new alternator is a 130 amps. Puts out 65 amps at 800 RPM and 85 amps at 1700 RPM. The tech I talked to said that for a Mopar that a regular alternator will put out higher amps at low RPM then a one wire. The alternator, electronic regulator and wiring harness delivered was $205.
Re: What output and brand Alternator should I use? [Re: DAYCLONA] #2368200
09/10/17 10:28 AM
09/10/17 10:28 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By DAYCLONA
Powermaster brand
I am going to try one of these in my Warlock, they claim 65a at idle, which is just fine for me.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2368325
09/10/17 02:20 PM
09/10/17 02:20 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have only had two non-stock style alternators, neither mounted in the stock location. I noticed some places have a graph of alternator output vs. alternator RPM? You also need to consider the pulley ratios and maximum RPM. If your running a 2:1 pulley ratio and 7,000 Engine RPM, the alternator needs to be able to handle 14,000+ RPM.
Re: What output and brand Alternator should I use? [Re: toms] #2368675
09/11/17 07:07 AM
09/11/17 07:07 AM
eastern,Ky
eastern,Ky
No I have not. Thanks everybody for the help!!!
Re: What output and brand Alternator should I use? [Re: 70RT Charger] #2369242
09/12/17 05:40 AM
09/12/17 05:40 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Let us know what you get and how it works out.
On my Charger, I used a 136 Amp Denso from a Ram Truck that I got fairly cheap, but had to convert to V-Belt, and is too thick to mount in stock location. The Charger is more race than street car, so I relocated the alternator to about where a stock A/C unit would be. This gives better belt contact with the pulley too.
The Coronet has a serpentine belt conversion (Billet Specialties) with the 140 Amp, Power Master brand, one-wire alternator. It works fine.
Re: What output and brand Alternator should I use? [Re: 451Mopar] #2369501
09/12/17 04:44 PM
09/12/17 04:44 PM
eastern,Ky
eastern,Ky
I believe I'm going to go with the tuff stuff but it will be a while before I'll get it running .
