5.7 Apache headed pump gas stroker #2360060
08/26/17 10:07 AM
08/26/17 10:07 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I have two 5.7 core motors (pre 07') and a set of brand new Apache cylinder heads in the box and with nitrous prices here out of control, I am considering a move away from my 408" Indy 360-2 sb motor. For one thing, it seems that the valvetrain alone on the G3 is better overall and would require less attention/maintenance then my current solid roller setup.
Apples to apples, a pump gas 5.7 stroker with Apache heads vs. a Indy headed stroker SB, how much of a difference is there? Ive never tried to optimize my current setup for all motor performance, but if i can run consistent 9.90 or faster on straight motor at 3300lbs on pump gas I would be extremely happy. Pump gas only because it is a street car.
So what say you guys? Worth switching over to the 5.7 stuff I have or just make a few changes to my current setup to try and get there?
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2360182
08/26/17 03:52 PM
08/26/17 03:52 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I all about the G3 stuff now a days, but pump gas 9.90s I think is just outside of the G3s right now.Maybe something thing in the +400 CI range would get there. Stock rockers are good to 7k rpm .There are a few guys here running in that 9.90 range with much better insight. Apache heads have some great flow potential out of the box.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2360273
08/26/17 07:29 PM
08/26/17 07:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Build a 392 out of it, port the heads and run a .620 ish 250@.050 ish on a 110 cam spinning to 72-7300 and you're gonna be right in there.
Mopar to the bone!!!
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2360570
08/27/17 01:41 PM
08/27/17 01:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Dustin is right at the 9.90 mark at that weight but has 13-1 comp on e85
Im on pump gas but have more cubes and a little lighter
Re: 5.7 Apache headed pump gas stroker [Re: sixpackgut] #2361112
08/28/17 12:54 PM
08/28/17 12:54 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I am hoping the Apaches will be the key to getting me the power I need since they are quite a good flowing head
Stock rockers with an aftermarket crank and say the 6.1 oil pump should be good at those rpms right? How big can a 5.7 block go stroked and bored- is the 392 the safe reliable limit or is 400+ cubes doable?
Yes I looked at Dustins build thread, very impressive....I couldn't find yours though, did you have one or a link to the initial build? I need to stay pump gas (94 octane)
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2361119
08/28/17 01:02 PM
08/28/17 01:02 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
User name Steff has a good build also.
on fastmopar dot com, there is some real good info in the G3 section
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2361162
08/28/17 02:33 PM
08/28/17 02:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
392 is about the safe reasonable limit on a 5.7 block. Sure some have gone bigger but you are gonna start getting puny rod/stroke ratios, too short of pistons, too thin of bores or something.
A 392 apache short block can be had brand new from the dealer machined, balanced, and assembled for about the same price as a 392 stroker kit for a 5.7 then you got to machine your block and assemble and possibly balance and you get a bigger bore to help unshroud the valves, they are very shrouded on a 5.7 bore with apache heads.
Re: 5.7 Apache headed pump gas stroker [Re: HotRodDave] #2361243
08/28/17 05:54 PM
08/28/17 05:54 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Is there a dealer part # for the short block? Is the bottom end of an apache shortlbock top quality (forged crank and NOT powdered metal rods) and free of the high rpm oiling issues?
This would be an all motor deal and I saw some 440+ short blocks by some of the hemi shops based on the 6.4 block which would seem like a great way to get where I want but wondering if there's better options out there?
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2361286
08/28/17 07:14 PM
08/28/17 07:14 PM
Renton Washington
Triple Threat Offline
Renton Washington
As much as I'd like to help you spend your money, I think you should use what you have and try and get some more out of it. I know its been a few years since you've run the green beast but I remember thinking it has more in it with more tuning.
There's no reason you shouldn't be able to go bottom 10's or even high 9's with an Indy headed 408.
If you're set on making the switch, you should buy Ray's short block.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 5.7 Apache headed pump gas stroker [Re: Triple Threat] #2361310
08/28/17 07:43 PM
08/28/17 07:43 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks for the kind words Dustin! Planning to get out to the track for the first time this week in 2 years and im super excited! The car is n/t but already on a small hit its been quicker then mentioned and I had only just started getting it to work...but my reason for thinking of the switch is the crazy nitrous prices here- at 13-16$ a pound its gotten crazy. I have thought about a rebuild for n/a with this LA motor, but I would love to get away from a hard blocked solid roller motor if i am going to only run n/a and continue to street drice like i do, and the g3 seems like the ticket, especially since i have two 5.7 cores and a set of NIB apache heads.
Its still all just ideas at this point but id like to come out rockin next year with something solid whether i freshen what i have or go g3.
I browse the classifieds here but havent seen Rays short from what I can recall
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2361456
08/28/17 11:37 PM
08/28/17 11:37 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
My short block is a 428. -13cc dish diamonds. One extra piston. K1 rotating assembly. 4.09 bore x4.08. Stock lifters, 6.1 timing chain, 6.1 oil pump. Cam is .600/254. Milodon pan/ pickup and windage tray. I will also include a new sfi car balancer.
May have been Dram's(if you remember him) last engines before he got sick. It's been thru 2 drag weeks
I use the truck balancer
With Apache heads comp will be 10-1. Eagles 11-1
Re: 5.7 Apache headed pump gas stroker [Re: sixpackgut] #2363402
09/01/17 12:25 PM
09/01/17 12:25 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Yes, I remember Dram (rip). So that is 6.1 based then I assume? Send me a pm with what you are looking for. I'd need to sell my current setup first to have the spending money but it doesn't hurt to talk 👍
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2373187
09/19/17 10:06 AM
09/19/17 10:06 AM
gregsdart Online content
gregsdart  Online Content
Have the 5.7 blocks sonic checked to see what they will take for an overbore. I have heard of some thick enough to go 4.06!
As far as valve shrouding by running Apache heads on a 5.7, the pinch spot next to the cylinder wall is the weakest flowing portion of the port. On top of that the valves move away from the cylinderwall as they lift off the seat. Lastly, a slight notch could be ground into the block ala old school wedge engines, if you like to worry about it.
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2373790
09/20/17 08:35 AM
09/20/17 08:35 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Block 53021319AC...
earlier this year I had one brought to me that was bored to 4.055,that was built as a "6.1" another I had bored to 4.055 that was stroked and built as a 426. the 3rd AC block I have here that was bored 4.055 is a back up for my own build.
the 4th AC block I have here is bored to 4.03, for my niece.
Block 53021319AG....I have 2 here that I wouldn't take over 3.96 and still feel safe. I have another 4 that I haven't sonic checked yet.
Block53021319CB, have 2 and neither has been sonic checked.
stock 3.917 bore and oversized (2.18) Intake valve Apache, needs a bore notch.
STD Apache Intake Valve , and the 3.917 bore, could use some notching if your going gonzo power build.
Re: 5.7 Apache headed pump gas stroker [Re: ric3xrt] #2373927
09/20/17 03:16 PM
09/20/17 03:16 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Block 53021319AC...
What years of engines do those part numbers correspond to?
Re: 5.7 Apache headed pump gas stroker [Re: mshred] #2374040
09/20/17 07:03 PM
09/20/17 07:03 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
My W9 is for sale !!!! LOL
436 cid hydraulic roller 11.5 to 1
4.04 bore
664hp and 630 tq
Matt
Re: 5.7 Apache headed pump gas stroker [Re: WO23Coronet] #2374910
09/22/17 10:04 AM
09/22/17 10:04 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
[/quote]
What years of engines do those part numbers correspond to? [/quote]
Not sure doesn't seam to be a rhythm or reason to it.
Re: 5.7 Apache headed pump gas stroker [Re: ric3xrt] #2375058
09/22/17 03:02 PM
09/22/17 03:02 PM
Chester, VA
tobnHisglory Offline
Chester, VA
When sonic checking, what are the minimums you all consider safe and which places on the cylinder walls are you checking?
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
