Re: 5.7 Apache headed pump gas stroker
[Re: mshred]
#2360182
08/26/17 03:52 PM
08/26/17 03:52 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I all about the G3 stuff now a days, but pump gas 9.90s I think is just outside of the G3s right now.Maybe something thing in the +400 CI range would get there. Stock rockers are good to 7k rpm .There are a few guys here running in that 9.90 range with much better insight. Apache heads have some great flow potential out of the box.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: mshred]
#2360273
08/26/17 07:29 PM
08/26/17 07:29 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Build a 392 out of it, port the heads and run a .620 ish 250@.050 ish on a 110 cam spinning to 72-7300 and you're gonna be right in there.
Mopar to the bone!!!
[Re: mshred]
#2360570
08/27/17 01:41 PM
08/27/17 01:41 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Dustin is right at the 9.90 mark at that weight but has 13-1 comp on e85
Im on pump gas but have more cubes and a little lighter
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2361112
08/28/17 12:54 PM
08/28/17 12:54 PM
Posts: 3,414 Toronto
mshred
Toronto
I all about the G3 stuff now a days, but pump gas 9.90s I think is just outside of the G3s right now.Maybe something thing in the +400 CI range would get there. Stock rockers are good to 7k rpm .There are a few guys here running in that 9.90 range with much better insight. Apache heads have some great flow potential out of the box. I am hoping the Apaches will be the key to getting me the power I need since they are quite a good flowing head Build a 392 out of it, port the heads and run a .620 ish 250@.050 ish on a 110 cam spinning to 72-7300 and you're gonna be right in there. Stock rockers with an aftermarket crank and say the 6.1 oil pump should be good at those rpms right? How big can a 5.7 block go stroked and bored- is the 392 the safe reliable limit or is 400+ cubes doable? Dustin is right at the 9.90 mark at that weight but has 13-1 comp on e85
Im on pump gas but have more cubes and a little lighter Yes I looked at Dustins build thread, very impressive....I couldn't find yours though, did you have one or a link to the initial build? I need to stay pump gas (94 octane)
[Re: mshred]
#2361119
08/28/17 01:02 PM
08/28/17 01:02 PM
ric3xrt
Trumbauersville PA
User name Steff has a good build also.
on fastmopar dot com, there is some real good info in the G3 section
[Re: HotRodDave]
#2361243
08/28/17 05:54 PM
08/28/17 05:54 PM
mshred
Toronto
392 is about the safe reasonable limit on a 5.7 block. Sure some have gone bigger but you are gonna start getting puny rod/stroke ratios, too short of pistons, too thin of bores or something.
A 392 apache short block can be had brand new from the dealer machined, balanced, and assembled for about the same price as a 392 stroker kit for a 5.7 then you got to machine your block and assemble and possibly balance and you get a bigger bore to help unshroud the valves, they are very shrouded on a 5.7 bore with apache heads. Is there a dealer part # for the short block? Is the bottom end of an apache shortlbock top quality (forged crank and NOT powdered metal rods) and free of the high rpm oiling issues? This would be an all motor deal and I saw some 440+ short blocks by some of the hemi shops based on the 6.4 block which would seem like a great way to get where I want but wondering if there's better options out there?
[Re: mshred]
#2361286
08/28/17 07:14 PM
08/28/17 07:14 PM
Triple Threat
Renton Washington
As much as I'd like to help you spend your money, I think you should use what you have and try and get some more out of it. I know its been a few years since you've run the green beast but I remember thinking it has more in it with more tuning.
There's no reason you shouldn't be able to go bottom 10's or even high 9's with an Indy headed 408.
If you're set on making the switch, you should buy Ray's short block.
[Re: Triple Threat]
#2361310
08/28/17 07:43 PM
08/28/17 07:43 PM
mshred
Toronto
If you're set on making the switch, you should buy Ray's short block. Thanks for the kind words Dustin! Planning to get out to the track for the first time this week in 2 years and im super excited! The car is n/t but already on a small hit its been quicker then mentioned and I had only just started getting it to work...but my reason for thinking of the switch is the crazy nitrous prices here- at 13-16$ a pound its gotten crazy. I have thought about a rebuild for n/a with this LA motor, but I would love to get away from a hard blocked solid roller motor if i am going to only run n/a and continue to street drice like i do, and the g3 seems like the ticket, especially since i have two 5.7 cores and a set of NIB apache heads. Its still all just ideas at this point but id like to come out rockin next year with something solid whether i freshen what i have or go g3. I browse the classifieds here but havent seen Rays short from what I can recall
[Re: mshred]
#2361456
08/28/17 11:37 PM
08/28/17 11:37 PM
sixpackgut
Charleston
My short block is a 428. -13cc dish diamonds. One extra piston. K1 rotating assembly. 4.09 bore x4.08. Stock lifters, 6.1 timing chain, 6.1 oil pump. Cam is .600/254. Milodon pan/ pickup and windage tray. I will also include a new sfi car balancer.
May have been Dram's(if you remember him) last engines before he got sick. It's been thru 2 drag weeks
I use the truck balancer
With Apache heads comp will be 10-1. Eagles 11-1
[Re: sixpackgut]
#2363402
09/01/17 12:25 PM
09/01/17 12:25 PM
mshred
Toronto
With Apache heads comp will be 10-1. Eagles 11-1 Yes, I remember Dram (rip). So that is 6.1 based then I assume? Send me a pm with what you are looking for. I'd need to sell my current setup first to have the spending money but it doesn't hurt to talk 👍
[Re: mshred]
#2373187
09/19/17 10:06 AM
09/19/17 10:06 AM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Have the 5.7 blocks sonic checked to see what they will take for an overbore. I have heard of some thick enough to go 4.06! As far as valve shrouding by running Apache heads on a 5.7, the pinch spot next to the cylinder wall is the weakest flowing portion of the port. On top of that the valves move away from the cylinderwall as they lift off the seat. Lastly, a slight notch could be ground into the block ala old school wedge engines, if you like to worry about it.
[Re: mshred]
#2373790
09/20/17 08:35 AM
09/20/17 08:35 AM
ric3xrt
Trumbauersville PA
Block 53021319AC... earlier this year I had one brought to me that was bored to 4.055,that was built as a "6.1" another I had bored to 4.055 that was stroked and built as a 426. the 3rd AC block I have here that was bored 4.055 is a back up for my own build. the 4th AC block I have here is bored to 4.03, for my niece. Block 53021319AG....I have 2 here that I wouldn't take over 3.96 and still feel safe. I have another 4 that I haven't sonic checked yet. Block53021319CB, have 2 and neither has been sonic checked. stock 3.917 bore and oversized (2.18) Intake valve Apache, needs a bore notch. STD Apache Intake Valve , and the 3.917 bore, could use some notching if your going gonzo power build.
[Re: ric3xrt]
#2373927
09/20/17 03:16 PM
09/20/17 03:16 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Block 53021319AC... earlier this year I had one brought to me that was bored to 4.055,that was built as a "6.1" another I had bored to 4.055 that was stroked and built as a 426. the 3rd AC block I have here that was bored 4.055 is a back up for my own build. the 4th AC block I have here is bored to 4.03, for my niece. Block 53021319AG....I have 2 here that I wouldn't take over 3.96 and still feel safe. I have another 4 that I haven't sonic checked yet. Block53021319CB, have 2 and neither has been sonic checked. stock 3.917 bore and oversized (2.18) Intake valve Apache, needs a bore notch. STD Apache Intake Valve , and the 3.917 bore, could use some notching if your going gonzo power build. What years of engines do those part numbers correspond to?
[Re: mshred]
#2374040
09/20/17 07:03 PM
09/20/17 07:03 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
If you're set on making the switch, you should buy Ray's short block. Thanks for the kind words Dustin! Planning to get out to the track for the first time this week in 2 years and im super excited! The car is n/t but already on a small hit its been quicker then mentioned and I had only just started getting it to work...but my reason for thinking of the switch is the crazy nitrous prices here- at 13-16$ a pound its gotten crazy. I have thought about a rebuild for n/a with this LA motor, but I would love to get away from a hard blocked solid roller motor if i am going to only run n/a and continue to street drice like i do, and the g3 seems like the ticket, especially since i have two 5.7 cores and a set of NIB apache heads. Its still all just ideas at this point but id like to come out rockin next year with something solid whether i freshen what i have or go g3. I browse the classifieds here but havent seen Rays short from what I can recall My W9 is for sale !!!! LOL 436 cid hydraulic roller 11.5 to 1 4.04 bore 664hp and 630 tq Matt
[Re: ric3xrt]
#2375058
09/22/17 03:02 PM
09/22/17 03:02 PM
Posts: 198 Chester, VA
tobnHisglory
Chester, VA
When sonic checking, what are the minimums you all consider safe and which places on the cylinder walls are you checking?
-Reggie tobnHisglory2000@aol.com Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4 Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
