Borgeson Box wants P/S fluid, P/S pump wants ATF... #2360682
08/27/17 05:33 PM
08/27/17 05:33 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Has anyone run into a situation where their power steering box and power steering pump call for different fluids?
From what I understand, Borgeson only calls for power steering fluid in their boxes. Alternatively, my GM-type power steering pump only wants ATF.
I am up to 200 miles on my car and have only run RedLine P/S fluid in it and cannot seem to get rid of the pump whine. I am thinking I will try swapping over to ATF and see how that goes...what have you used?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda] #2360716
08/27/17 06:53 PM
08/27/17 06:53 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
ATF in mine.
Now my Borg box leaked like a sieve the moment I started the engine, but was due to a pinhole in a weld.
A few strikes with a punch fixed that.
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda] #2360867
08/27/17 10:59 PM
08/27/17 10:59 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Call Scott at Bergman.
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BigBlockMopar] #2360898
08/27/17 11:49 PM
08/27/17 11:49 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By BigBlockMopar
ATF in mine.
Ok, there's one Borg box with ATF in it that's lived. Good news!
2020 RAM 1500
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda] #2361576
08/29/17 09:20 AM
08/29/17 09:20 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Bump, anyone else using ATF in a Borgeson box?
Thanks!
2020 RAM 1500
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda] #2361594
08/29/17 10:36 AM
08/29/17 10:36 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
atf will be fine.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: GoodysGotaCuda] #2368440
09/10/17 08:00 PM
09/10/17 08:00 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Either way is fine, but synthetic PS fluid is best. If you have a hydroboost, atf is poison.
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BergmanAutoCraft] #2368458
09/10/17 08:39 PM
09/10/17 08:39 PM
IN
ahy Offline
ahy  Offline
IN
In general, older style PS pumps which ran ATF as original seem to do fine on power steering fluid. I would not worry about the pump with either.
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BergmanAutoCraft] #2428931
01/04/18 03:47 PM
01/04/18 03:47 PM
Hanover, Ontario, Canada
Moparmatty Offline
Moparmatty  Offline
Why is ATF poison to Hydroboost setups? Dodge diesel 4x4 trucks use ATF+4 in their power steering systems.
Matt Tebbutt
Ontario, Canada
Re: Borgeson Box wants P/S fluid, P/S pump wants ATF... [Re: BergmanAutoCraft] #2429220
01/04/18 10:49 PM
01/04/18 10:49 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The bus yard I work @ has 30 small busses- Fords and GMs over a span of 30 model years, they all have Hydroboost and all use ATF- factory fill.
