Re: Borgeson Box wants P/S fluid, P/S pump wants ATF...
[Re: BigBlockMopar]
#2360898
08/27/17 11:49 PM
08/27/17 11:49 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
ATF in mine. Now my Borg box leaked like a sieve the moment I started the engine, but was due to a pinhole in a weld. A few strikes with a punch fixed that.
Ok, there's one Borg box with ATF in it that's lived. Good news!
[Re: BergmanAutoCraft]
#2428931
01/04/18 03:47 PM
01/04/18 03:47 PM
Posts: 516 Hanover, Ontario, Canada
Moparmatty
Either way is fine, but synthetic PS fluid is best. If you have a hydroboost, atf is poison. Why is ATF poison to Hydroboost setups? Dodge diesel 4x4 trucks use ATF+4 in their power steering systems.
Matt Tebbutt Ontario, Canada
#2429220
01/04/18 10:49 PM
01/04/18 10:49 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Either way is fine, but synthetic PS fluid is best. If you have a hydroboost, atf is poison. The bus yard I work @ has 30 small busses- Fords and GMs over a span of 30 model years, they all have Hydroboost and all use ATF- factory fill.
