1968 426 Hemi ideas/help
#2360672
08/27/17 05:14 PM
08/27/17 05:14 PM
Posts: 60 your fridge
dmaddox
your fridge
I have inherited a 1968 J code Hemi. Its basically a re-body, only remaining of the car is roof/firewall (center section of the car). So it will never be a "nationals" class restoration. So, I've decided a resto-mod car that is streetable yet, 10-11 sec car on the drag strip. I apologize for my silly questions and ideas, just taking my fathers project and running with it. So, kind of taking his dream car that he wanted and how he wanted it. I have no idea what is going on with all of these parts, but I am skilled in engine/restoring process (just in another auto manufacturer). So, I need your help. Goals, resto-mod, sub 11 second car. Is an original 4 speed car. He had the block machined, 20 over and is wrapped and ready to go. These other parts....dont look like much/stored terribly in a humid climate. Should I stroke it? Sell these heads/parts? Start over? Block is date-code correct(ish) is a june 67 date code. Here is a link to some pictures: https://goo.gl/photos/F37YpKsGZ8kZP7F4AI just don't know where to start or what to do. Stroke, aftermarket heads, etc..? I hear the carbs are 100% correct and original and worth a mint. Just need some advice and direction. I appreciate any feedback and ideas.
Re: 1968 426 Hemi ideas/help
[Re: dmaddox]
#2360678
08/27/17 05:24 PM
08/27/17 05:24 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
An otherwise stock 426 inch Hemi with a larger camshaft and headers should go deep into the 11's. If you were starting from scratch I would recommend a 4.15 stroke crankshaft just because it will bring the power in earlier which makes it nicer to drive on the street but the 426 will make plenty of steam with stock heads and a few add-ons. It looks like it is ready to go together, if it was mine it would be a bit of a hard decision but I think I would sell the stock rotating assembly, put in a 4.15 crank with light pistons, a 650 lift solid roller camshaft, TTI headers and a Stage V intake manifold with an injection setup. It would be easy to get low 11's this way and you could get it into the 10's if you wanted. I would also install a scattershield, dual disc clutch with a 10.5 inch flywheel. The less expensive choice and one which will keep the value of the car higher though is to make the car as stock as you can which is a good idea as you have a correct block and carbs. You could put it all together with stock intake and exhaust manifolds, a better than stock camshaft, 3 inch exhaust system and have it turning high 11's that way too.
Sheldon
[Re: dmaddox]
#2360876
08/27/17 11:17 PM
08/27/17 11:17 PM
Posts: 6,417 Abilene, Texas
fastmark
Abilene, Texas
I'd like to correct your first post. A rebody is a car that all the panels with numbers and other Hemi only items are swapped to another rust free shell. This does not appear to be what you are doing here. There are several competent shops that could easily REPLACE all the body parts on your car that as needed. The amount of money you spend could be a deciding factor but I would not just right the car off for a factory restoration and start customizing it. No matter what you do to the motor, it still needs to be put back together properly. You could sell or trade that Hemi body for a rust free non Hemi car if a custom is what you want.
[Re: fastmark]
#2360897
08/27/17 11:47 PM
08/27/17 11:47 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
I'd like to correct your first post. A rebody is a car that all the panels with numbers and other Hemi only items are swapped to another rust free shell. This does not appear to be what you are doing here. There are several competent shops that could easily REPLACE all the body parts on your car that as needed. The amount of money you spend could be a deciding factor but I would not just right the car off for a factory restoration and start customizing it. No matter what you do to the motor, it still needs to be put back together properly. You could sell or trade that Hemi body for a rust free non Hemi car if a custom is what you want. Umm...sorry, but the "definition" of a "rebody" is not defined by you or the above. It's far more complicated. Get real.
[Re: dmaddox]
#2360914
08/28/17 12:09 AM
08/28/17 12:09 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Based on what I can see that block has seen some race duty in its life (casting being smoothed and ground in the lifter galley, bronze lifter bushings, etc.) and it appears that it might have been decked long ago. So before buying any parts I'd recommend taking it to a good machine shop and have it magnufluxed for cracks, inspected for repairs and modifications as compared to stock (bore, deck height, etc.) and then put together a battle plan for the build.
FWIW I would also have someone Mopar knowledgeable look at the car, it may not be as bad as you imagine, most of them can be saved without the drastic move of doing a re-body, you'd be surprised.
.02
[Re: dmaddox]
#2360930
08/28/17 12:54 AM
08/28/17 12:54 AM
dmaddox
your fridge
Quick story: I found the car in texas like this: http://s64.photobucket.com/user/cinez/library/RoadRunnerIt had everything but the motor. I sought out the ownership records and found what I was told was the original motor. I was lied to I think, but dad and I forked over the cash to get it. We had it magnafluxed, cleaned and found two cracks...it was bored 20 over, repaired and wrapped in plastic (in a moist storage bin until today). We have the original title, it is a J code car...but it was in ROUGH shape. I was lied to some more....and some more after that. I helped dad find parts, on and after that we started in on the body. This was all that remains of the core J code car: http://s64.photobucket.com/user/cinez/media/DSCN0753.jpg.htmlI am sad that my dad lost so much on this car....has gotten too old to mess with it anymore and now I am trying to make sense of it all. The block is seen here, as it was 10 years ago: (PAGE 4) http://s64.photobucket.com/user/cinez/library/68HEMII'm so overwhelmed.....
