Halo lights in your B/E bodys #2360561
08/27/17 01:20 PM
08/27/17 01:20 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
anyone did this conversion yet work if so what kit did you use and how was installation went..............Thaxs up
Re: Halo lights in your B/E bodys [Re: racerx] #2360624
08/27/17 03:37 PM
08/27/17 03:37 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Re: Halo lights in your B/E bodys [Re: UCUDANT] #2360888
08/27/17 11:32 PM
08/27/17 11:32 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted By UCUDANT
Nice ....... up
Re: Halo lights in your B/E bodys [Re: racerx] #2360912
08/28/17 12:02 AM
08/28/17 12:02 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
puke
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Halo lights in your B/E bodys [Re: racerx] #2360933
08/28/17 01:01 AM
08/28/17 01:01 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why are they so expensive ???
Re: Halo lights in your B/E bodys [Re: racerx] #2360949
08/28/17 01:25 AM
08/28/17 01:25 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Because they have xenon bulbs and that means all new wiring to adapt to the factory wiring. Ballasts and diodes to keep them from blinking on and off instead of staying on steadily as well as higher prices for the bulbs. They look a bit ricer to me.
Re: Halo lights in your B/E bodys [Re: racerx] #2361290
08/28/17 07:17 PM
08/28/17 07:17 PM
waco tx
gogo318 Offline
gogo318  Offline
waco tx
I put a 4 pack on my newport but i got the led ones that come as a kit with glass housings and a Philips bulbs pack they were plug and play except for the halo/angel eye light that i just wired in with the side marker lights i did the swap for better visibility with newer cars on the road with hids bright as hell its hard for me to see against there glare brighter lights on my end cancels out oncoming light intensity so i can see better just my 2cents
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: Halo lights in your B/E bodys [Re: GoodysGotaCuda] #2361987
08/29/17 10:16 PM
08/29/17 10:16 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted By GoodysGotaCuda
puke
You don't like those halo lights on the new challengers?
Re: Halo lights in your B/E bodys [Re: racerx] #2362767
08/31/17 11:20 AM
08/31/17 11:20 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It doesn't look right on that Chevelle IMO. Maybe it's the fact that they blink with the turn signals. Maybe they look weird to me because the four headlight system uses smaller bulbs and the halos take up too much area.
I bought some "WHITE" halo lights for my Dart. They just have 4 LEDs in each bulb. They were around $50 on E-bay. They won't fit the stock headlight buckets without modification. I bought another set of buckets at the Nats and modified them to fit the lights. The wiring for the halos goes into the housing around the perimeter and is sealed with a big glob of sealer. I had to notch the buckets to clear that sealer.
I plan to wire them up to the blue ignition "run" wire so they are on all the time. If I don't like the look, I'll just mount them on my garage wall in the original grill.
Re: Halo lights in your B/E bodys [Re: GoodysGotaCuda] #2362804
08/31/17 12:30 PM
08/31/17 12:30 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
puke
I agree. Call me old school but there are just some things that shouldn't be done to a classic muscle car. First and foremost is big wheels and rubber band tires. Second... gimmicks like halo lights.
If you want brighter headlights and tail lights, there are readily available solutions like using relays or LED bulbs. Adding crap like flashing or color changing halo lights is just juvenile IMHO.
And.... before someone asks if I like them on the new Challengers... the answer is NO. However, they are factory and are NOT on a classic so no harm no foul.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Halo lights in your B/E bodys [Re: racerx] #2362812
08/31/17 12:49 PM
08/31/17 12:49 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
They would probably look better on a single per side headlight car, like a Cuda. Not really my favorite accessory but it also depends on the overall look car.
Re: Halo lights in your B/E bodys [Re: racerx] #2366403
09/06/17 02:11 PM
09/06/17 02:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On a bone stocker I don't like them but if you've done some kind of a pro touring or restomod theme they can work.
Re: Halo lights in your B/E bodys [Re: racerx] #2366436
09/06/17 03:05 PM
09/06/17 03:05 PM
K
Kiddart Offline
Kiddart  Offline
K
I love the look
Thank you
Kiddart
Re: Halo lights in your B/E bodys [Re: racerx] #2366704
09/06/17 11:36 PM
09/06/17 11:36 PM
Madrid, IA
hellrzr Offline
hellrzr  Offline
Madrid, IA
Where would one get a setup like that for say a '74 Road Runner?
Re: Halo lights in your B/E bodys [Re: racerx] #2367257
09/08/17 12:06 AM
09/08/17 12:06 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
panic
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Halo lights in your B/E bodys [Re: racerx] #2367333
09/08/17 04:24 AM
09/08/17 04:24 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
puke
Factory applications look appropriate, anything aftermarket is just plain cheesy.
Point is, even if I was given a set, they would never end up on a car of mine. twocents
2020 RAM 1500
Re: Halo lights in your B/E bodys [Re: GoodysGotaCuda] #2368818
09/11/17 02:20 PM
09/11/17 02:20 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
I went with RedLine Lumtronix Halos and LED H4 bulbs, love it so far, installed but haven't driven it yet. Great customer service and glass lens and the LED H4's put out lots of light and draw very little power so you don't have to mess with the factory wiring or add ballasts, ect... plug and play.
http://haloheadlights.co/
There is a lot of good info in this thread. The poster tries several of the setups.
http://www.dodgecharger.com/forum/index.php/topic,104078.0.html
