Big Power, Small Tire #2360376
08/26/17 11:42 PM
08/26/17 11:42 PM
Alberta
Wookie316 Offline OP
Alberta
I've been running the Hoosier C07 10.5x30 Radial Slick. It hooks well on my car, but since Barney now has 100 + HP more they fade away very quick. Wondering what guys are using. Love the top end stability of a radial on a big car, but I may have no choice and have to go back to a Bias slick.
Those running more than 800 HP on a 10.5 I need opinions. I can keep running these, but looking for something with a bit more life.
Yes I'm conservative on the burnout if anyone is wondering. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Big Power, Small Tire [Re: Wookie316] #2360381
08/26/17 11:51 PM
08/26/17 11:51 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Wookie,
Look at the MT Pro bracket radial . 29.5x10.5R15 . Its 30" tall
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Big Power, Small Tire [Re: Wookie316] #2360389
08/27/17 12:12 AM
08/27/17 12:12 AM
Outside
thedriver Offline
thedriver  Offline
Outside
Are you writing posts on the return road? Lol
1973 challenger
Dana. 4 speed. Low deck.
Re: Big Power, Small Tire [Re: Wookie316] #2360399
08/27/17 12:30 AM
08/27/17 12:30 AM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
"Wookie,
Look at the MT Pro bracket radial . 29.5x10.5R15 . Its 30" tall"
So far I've gone 9.20s at over 3500lbs in a 69 GTX on the above mention tire. All motor 540 Hemi. needs VERY little burn out.
Re: Big Power, Small Tire [Re: mercman1] #2360420
08/27/17 01:21 AM
08/27/17 01:21 AM
Alberta
Alberta
Originally Posted By mercman1
"Wookie,
Not quite. Back at hotel. I went from 5 passes within .04 last night to only hooking 2 times in 7 passes today. Test and tunes. Gotta love them.
Re: Big Power, Small Tire [Re: Wookie316] #2361037
08/28/17 10:34 AM
08/28/17 10:34 AM
an8sec70cuda Offline
I use M/T 29.5x10.5 stiff sidewall ET Drag slicks w/ tubes when the track won't work w/ radials.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Big Power, Small Tire [Re: Wookie316] #2361050
08/28/17 11:08 AM
08/28/17 11:08 AM
Alberta
Alberta
I know it was somewhat a prep issue because all the big power small tire guys were having trouble. That said, I do need new tires regardless.
Re: Big Power, Small Tire [Re: Wookie316] #2361142
08/28/17 01:55 PM
08/28/17 01:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We do ok on a 29.5x10.5 SS M/T. We have well north of 800HP NA. We have been 1.13 60' and 8.04 so far this year..
Re: Big Power, Small Tire [Re: Wookie316] #2361145
08/28/17 01:59 PM
08/28/17 01:59 PM
Alberta
Alberta
Pulled trigger on a set of M/T PBR's. $60 a tire cheaper than the Hoosiers I was running. I can get used to that.
Re: Big Power, Small Tire [Re: Wookie316] #2361219
08/28/17 04:57 PM
08/28/17 04:57 PM
canada
W2-408 Offline
W2-408  Offline
canada
You're going to love the PBR's. At Castrol I don't even use the line lock anymore. Just stab the throttle out of the burnout box, never had them spin yet and the 60 foot doesn't move more than about 8 thou all day. My car runs pretty much the same ET's as you.
Street car, 10.12 @ 132 with W2's and pump gas
Re: Big Power, Small Tire [Re: Wookie316] #2361224
08/28/17 05:09 PM
08/28/17 05:09 PM
Alberta
Alberta
Great to know. Thanks. I like that they are cheaper too. How many passes you getting on a set?
Re: Big Power, Small Tire [Re: Wookie316] #2361228
08/28/17 05:20 PM
08/28/17 05:20 PM
canada
W2-408 Offline
W2-408  Offline
canada
I just switched to them this year, with basically no burn out on them over close to 100 passes so far they look like new. I know of people in the states that say they're getting close to 300 passes on a set.
Re: Big Power, Small Tire [Re: Wookie316] #2361248
08/28/17 05:58 PM
08/28/17 05:58 PM
Alberta
Alberta
I'll be very happy if I can get 100+ on a set. Thanks for the info. Much appreciated.
Re: Big Power, Small Tire [Re: Wookie316] #2361300
08/28/17 07:30 PM
08/28/17 07:30 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Wookie ,
I went just over 150 passes before swapping out mine . There was still more left but was too close to end of season rounds to risk
Tex
New best MPH 130.32
Re: Big Power, Small Tire [Re: Wookie316] #2361328
08/28/17 08:11 PM
08/28/17 08:11 PM
Alberta
Alberta
I hope to see that # out of mine however it has been suggested to me that big power in a big car like mine may not like the sidewall punishment the receive and shorten the life of an average user.
Re: Big Power, Small Tire [Re: Wookie316] #2361481
08/29/17 12:10 AM
08/29/17 12:10 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
I've had the same set of PBR simce 2015
Race every Sunday
TnT a couple times
Put 11 passes on them in TT and eliminations last year
And few eliminations year before
Re: Big Power, Small Tire [Re: Wookie316] #2368572
09/10/17 11:48 PM
09/10/17 11:48 PM
Alberta
Alberta
Ran the PBR's this weekend. 60 is same as Hoosiers. Had to run 18 PSI to hook. Hoosier's work at 20. Lower PSI = lower MPH & ET. That was at SIR. Need to try at Castrol yet.
Re: Big Power, Small Tire [Re: Wookie316] #2368597
09/11/17 12:37 AM
09/11/17 12:37 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Wookie ,
I am at 16 1/4psi thereabouts . Didn't like the 18 1/2 I used in the Hoosier radial
Tex
New best MPH 130.32
Re: Big Power, Small Tire [Re: tex013] #2368629
09/11/17 01:31 AM
09/11/17 01:31 AM
Cab_Burge Online work
Cab_Burge  Online Work
You guys need to remember that not all tire gauges read exactly the same, even the outside Barometric pressure can influence what your low pressure tire gauge will read with the same amount of air in the rear tires shruggy
My message is use your tire gauge on your tires only and DON'T loan it out to anyone tsk twocents
I will use one of my cheaper gauges on a another racers tires but I won't let him use my gauges at all, that is after having multiple good low pressure tire gauges ruin by loaning them out to someone I don't know or trust realcrazy shruggy
Re: Big Power, Small Tire [Re: Cab_Burge] #2368648
09/11/17 03:35 AM
09/11/17 03:35 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
up Cab
isn't that the truth
Tex
New best MPH 130.32
