Big Power, Small Tire
#2360376
08/26/17 11:42 PM
08/26/17 11:42 PM
Posts: 326 Alberta
Wookie316
Alberta
I've been running the Hoosier C07 10.5x30 Radial Slick. It hooks well on my car, but since Barney now has 100 + HP more they fade away very quick. Wondering what guys are using. Love the top end stability of a radial on a big car, but I may have no choice and have to go back to a Bias slick. Those running more than 800 HP on a 10.5 I need opinions. I can keep running these, but looking for something with a bit more life. Yes I'm conservative on the burnout if anyone is wondering. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Big Power, Small Tire
[Re: Wookie316]
#2360381
08/26/17 11:51 PM
08/26/17 11:51 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Wookie, Look at the MT Pro bracket radial . 29.5x10.5R15 . Its 30" tall
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Wookie316]
#2360389
08/27/17 12:12 AM
08/27/17 12:12 AM
Posts: 1,481 Outside
thedriver
Outside
Are you writing posts on the return road? Lol
1973 challenger Dana. 4 speed. Low deck.
[Re: mercman1]
#2360420
08/27/17 01:21 AM
08/27/17 01:21 AM
Posts: 326 Alberta
Wookie316
Alberta
"Wookie, Look at the MT Pro bracket radial . 29.5x10.5R15 . Its 30" tall"
So far I've gone 9.20s at over 3500lbs in a 69 GTX on the above mention tire. All motor 540 Hemi. needs VERY little burn out. Not quite. Back at hotel. I went from 5 passes within .04 last night to only hooking 2 times in 7 passes today. Test and tunes. Gotta love them.
[Re: Wookie316]
#2361037
08/28/17 10:34 AM
08/28/17 10:34 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I use M/T 29.5x10.5 stiff sidewall ET Drag slicks w/ tubes when the track won't work w/ radials.
[Re: Wookie316]
#2361050
08/28/17 11:08 AM
08/28/17 11:08 AM
Posts: 326 Alberta
Wookie316
Alberta
I know it was somewhat a prep issue because all the big power small tire guys were having trouble. That said, I do need new tires regardless.
[Re: Wookie316]
#2361142
08/28/17 01:55 PM
08/28/17 01:55 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
We do ok on a 29.5x10.5 SS M/T. We have well north of 800HP NA. We have been 1.13 60' and 8.04 so far this year..
[Re: Wookie316]
#2361145
08/28/17 01:59 PM
08/28/17 01:59 PM
Posts: 326 Alberta
Wookie316
Alberta
Pulled trigger on a set of M/T PBR's. $60 a tire cheaper than the Hoosiers I was running. I can get used to that.
[Re: Wookie316]
#2361219
08/28/17 04:57 PM
08/28/17 04:57 PM
Posts: 52 canada
W2-408
canada
You're going to love the PBR's. At Castrol I don't even use the line lock anymore. Just stab the throttle out of the burnout box, never had them spin yet and the 60 foot doesn't move more than about 8 thou all day. My car runs pretty much the same ET's as you.
Street car, 10.12 @ 132 with W2's and pump gas
[Re: Wookie316]
#2361224
08/28/17 05:09 PM
08/28/17 05:09 PM
Posts: 326 Alberta
Wookie316
Alberta
Great to know. Thanks. I like that they are cheaper too. How many passes you getting on a set?
[Re: Wookie316]
#2361228
08/28/17 05:20 PM
08/28/17 05:20 PM
Posts: 52 canada
W2-408
canada
I just switched to them this year, with basically no burn out on them over close to 100 passes so far they look like new. I know of people in the states that say they're getting close to 300 passes on a set.
[Re: Wookie316]
#2361248
08/28/17 05:58 PM
08/28/17 05:58 PM
Posts: 326 Alberta
Wookie316
Alberta
I'll be very happy if I can get 100+ on a set. Thanks for the info. Much appreciated.
[Re: Wookie316]
#2361300
08/28/17 07:30 PM
08/28/17 07:30 PM
tex013
Sydney,Australia
Wookie , I went just over 150 passes before swapping out mine . There was still more left but was too close to end of season rounds to risk
Tex
[Re: Wookie316]
#2361328
08/28/17 08:11 PM
08/28/17 08:11 PM
Posts: 326 Alberta
Wookie316
Alberta
I hope to see that # out of mine however it has been suggested to me that big power in a big car like mine may not like the sidewall punishment the receive and shorten the life of an average user.
[Re: Wookie316]
#2368572
09/10/17 11:48 PM
09/10/17 11:48 PM
Posts: 326 Alberta
Wookie316
Alberta
Ran the PBR's this weekend. 60 is same as Hoosiers. Had to run 18 PSI to hook. Hoosier's work at 20. Lower PSI = lower MPH & ET. That was at SIR. Need to try at Castrol yet.
[Re: Wookie316]
#2368597
09/11/17 12:37 AM
09/11/17 12:37 AM
tex013
Sydney,Australia
Wookie , I am at 16 1/4psi thereabouts . Didn't like the 18 1/2 I used in the Hoosier radial
Tex
[Re: Cab_Burge]
#2368648
09/11/17 03:35 AM
09/11/17 03:35 AM
tex013
Sydney,Australia
Cab isn't that the truth Tex
