Differential fill plug question #2358295
08/22/17 08:52 PM
08/22/17 08:52 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Should the fill plug on a Dana (or any other rearend) have some sort of thread sealant applied to it?
Re: Differential fill plug question [Re: 1970RT] #2358299
08/22/17 09:01 PM
08/22/17 09:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
no, not generally, as you fill just below the plug, if anything maybe some teflon paste to prevent it from rusting or leaking if so desired
Re: Differential fill plug question [Re: 1970RT] #2358375
08/22/17 11:35 PM
08/22/17 11:35 PM
I use a light circular smear of Permatex #3 around the threads with the shoe polish type brush. it is thin/goes on easy/seals well. I ain't sure if that is pipe thread or not.
Re: Differential fill plug question [Re: 1970RT] #2359478
08/25/17 04:47 AM
08/25/17 04:47 AM
Cab_Burge Online work
Cab_Burge  Online Work
The plug should have NPT, National Pipe Threads, which are self sealing due to the threads being tapered from small at the opening to larger as it threads in, just like pipes do scope
Re: Differential fill plug question [Re: 1970RT] #2359513
08/25/17 10:15 AM
08/25/17 10:15 AM
an8sec70cuda Offline
If you don't put some type of sealer on it, it will leak.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Differential fill plug question [Re: 1970RT] #2359534
08/25/17 11:02 AM
08/25/17 11:02 AM
BDW Online content
BDW  Online Content
Agreed, mine leaked before I added some teflon tape on the threads.
Re: Differential fill plug question [Re: 1970RT] #2359615
08/25/17 01:16 PM
08/25/17 01:16 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
You'll notice all plumbers use sealant on NPT thread joints.
Joe
Re: Differential fill plug question [Re: jlatessa] #2359625
08/25/17 01:30 PM
08/25/17 01:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Joe
That's why Carter says not to use sealant on their fuel pump threads.
Anyone that can't manage to cover their asscrack is no go to source in my book.
Now plumbers who can manage to cover their asscrack know that NPT doesn't need sealant. Burr free and a lube is all you need.
Don't be the exception.
Re: Differential fill plug question [Re: DAYCLONA] #2359916
08/25/17 10:20 PM
08/25/17 10:20 PM
IN
ahy Offline
ahy  Offline
IN
I do not use any sealant. No leaks from the plug. It is not under pressure (assuming the axle vent is installed and clear!). No harm in a little sealant but not normally used at this location in my experience.
As far as tapered pipe plugs go in general, there are different classes of thread quality. The highest quality (rarely available) does not need any any sealant in pressure applications. "Standard" quality needs sealant. Some of the stuff the home improvement store sells will not seal regardless of what sealant is used in my experience.
Re: Differential fill plug question [Re: ahy] #2360084
08/26/17 11:33 AM
08/26/17 11:33 AM
moparx Offline
moparx  Offline
iagree the theory behind a tapered thread generally, is the sealing ability without anything applied topically to complete the seal. but the quality of the taper threads, material, and the threading process, all play into this equation. finding "quality" NPT threads can be quite difficult these days, especially in hardware store plumbing supplies, as well as the typical automotive NPT threaded item. in general, most will seal, but the "seal" will be "damp" without leaking. in other words, you will see dust clinging around the fitting, or it will be damp with nothing leaking or dripping. i generally use a dab of loctite 567 teflon sealant [part #56765] and wipe away the excess from the joint after it is tightened up. this stuff is high temperature, and works in gasoline [although i wouldn't recommend it's use in fuel systems, it works good in bulk tank applications],petroleum oils, natural gas [not over 300# pressure],butane, and propane, plus air compressor systems.
beer
Re: Differential fill plug question [Re: 1970RT] #2360094
08/26/17 11:59 AM
08/26/17 11:59 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes you need to use some in this case. It'll also help you get it out next time. twocents
Re: Differential fill plug question [Re: moparx] #2360111
08/26/17 12:48 PM
08/26/17 12:48 PM
I've heard that Loctite 567 is the very best, hands down & yes hardware store NPT fitting quality is hit or miss.
Re: Differential fill plug question [Re: RapidRobert] #2360114
08/26/17 01:03 PM
08/26/17 01:03 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
My biggest issue has been to over tighten these type situations.
Once I get it in my head it doesn't need to be quite so tight I have no more trouble.
I have never used a sealant on the rear cover drain plug.
I have mechanical Aptitude.
I can screw up anything.
Re: Differential fill plug question [Re: bboogieart] #2360205
08/26/17 05:10 PM
08/26/17 05:10 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Well, I put a little Permatex on it just to be on the safe side. The cover is an aftermarket chrome cover so it may not have the best fill plug on it. I had my Dana all gone through and assembled the summer before last at the local ring and pinion shop. It had just been sitting on the garage floor until recently. I finally got around to installing it in the car and then filled it just before my original post. Here I was worried about the fluid leaking out the fill plug only to find out once I put the new fluid in it is leaking pretty good out of the pinion seal (which was replaced when it was assembled).
Re: Differential fill plug question [Re: an8sec70cuda] #2360225
08/26/17 06:11 PM
08/26/17 06:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've never used sealer, never had one leak. If the fluid level is correct and the vent is open, there is no pressure in the rear end to force the lube past the threads.
