OEM E body sway bar bushings #2359568
08/25/17 11:54 AM
08/25/17 11:54 AM
TN, USA
Ron TN Offline OP
Ron TN  Offline OP
TN, USA
I put a swap meet OEM rear sway bar on my 73 Barracuda (I call Cuda). The bushings are worn and I want to replace them with Urethane bushings. Is there a replacement bushing with metal brackets or do I have to break apart the current brackets and replace the bushings only in the existing bracket? If I can only replace the bushings, any tips/how to's on how to replace those bushings?
Thanks in advance for your responses.
Re: OEM E body sway bar bushings [Re: Ron TN] #2359612
08/25/17 01:09 PM
08/25/17 01:09 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes u must cut apart the metal brackets and reweld or force the new rubber/urethane into them....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: OEM E body sway bar bushings [Re: Ron TN] #2360003
08/26/17 01:44 AM
08/26/17 01:44 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Drill out the spot welds on the bracket. That's what I did with mine. There was only one spot weld on each side of the bracket. I drilled out one side and pried it apart enough to get the bushing out. Clamp it back together and weld it up.
Re: OEM E body sway bar bushings [Re: Ron TN] #2360183
08/26/17 03:54 PM
08/26/17 03:54 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I've also seen people lube the new ones up and work them in (carefully) with wide mouth pliers, but that was with rubber.
Re: OEM E body sway bar bushings [Re: Ron TN] #2361861
08/29/17 07:05 PM
08/29/17 07:05 PM
TN, USA
Ron TN Offline OP
Ron TN  Offline OP
TN, USA
Where is the best place to get the urethane bushings? I don't recall seeing them anywhere.
Re: OEM E body sway bar bushings [Re: Ron TN] #2362121
08/30/17 01:28 AM
08/30/17 01:28 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I used a kit from Energy Suspension. The part number I used was 9.5106. I used the black ones to try and keep it stock looking.
