Need Help w/Electrical Problem #2358780
08/23/17 09:37 PM
08/23/17 09:37 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Hi All,
I am trying to track down an electrical problem with my 71 Charger and could use some guidance/help.
Lights off, turn signals and flashers work perfectly.
When I put the lights on, the left turn signal indicator in the instrument panel comes on steady. All of the lights are on (headlights, sidemarker, tail, etc.). The right turn signal works fine, but the left turn signal flashes very slowly.
It is not a fuse, and I am assuming it is not a ground problem as all of the lights work. Can anybody give me some advice on tracking this down?
Thanks.
Greg
Re: Need Help w/Electrical Problem [Re: GregY] #2358783
08/23/17 09:43 PM
08/23/17 09:43 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Looks like one of the lights is grounding thru the turn signal. Clean the grounds, starting in the area of the outside turn signals.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Need Help w/Electrical Problem [Re: GregY] #2358800
08/23/17 10:23 PM
08/23/17 10:23 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Headlight and front marker light grounds are most likely suspects.
Angry white pureblood male
Re: Need Help w/Electrical Problem [Re: ruderunner] #2358803
08/23/17 10:34 PM
08/23/17 10:34 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
When I disconnect the left turn signal from the left sidemarker light, it fixes the steady turn signal light on the instrument panel, and everything works, except of course the left turn signal. When I plug it back in, there's my problem.
I redid the one ground that I know of, that grounds all the front end lights I believe. That didn't fix it.
Is the turn signal connector bad, or something in the turn signal housing?
Re: Need Help w/Electrical Problem [Re: GregY] #2358830
08/23/17 11:25 PM
08/23/17 11:25 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Clean the inside of the bulb socket. A terminal in there is probably cruddy.
Re: Need Help w/Electrical Problem [Re: GregY] #2358835
08/23/17 11:31 PM
08/23/17 11:31 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Take your regular sized phillips screwdriver and loosen then re-tighten the two screws facing down from light housing through the lower valance. Left side most likely, but do them both. R&L.
Re: Need Help w/Electrical Problem [Re: GregY] #2358849
08/24/17 12:04 AM
08/24/17 12:04 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I think we answered this in your last post You have a ground problem.
Re: Need Help w/Electrical Problem [Re: stumpy] #2358998
08/24/17 08:51 AM
08/24/17 08:51 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
The inside of the bulb housing looks fine, but the one screw in the bottom of the valance is super rusty, I am wondering if that has something to do with it, are those screws grounding the housing (electrical stuff is not my strong point)?
Thanks for the help.
Greg
Re: Need Help w/Electrical Problem [Re: GregY] #2359000
08/24/17 08:58 AM
08/24/17 08:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO Either you have bad bulb or you have the side markers and turn signals swapped. Turn signal plugged into a side marker.
Re: Need Help w/Electrical Problem [Re: GregY] #2359159
08/24/17 02:56 PM
08/24/17 02:56 PM
Grand Prairie,Texas
Grand Prairie,Texas
Yes those screws ground the housing.
Re: Need Help w/Electrical Problem [Re: stumpy] #2359358
08/24/17 10:13 PM
08/24/17 10:13 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I sm glad to hear your getting that car
out of the mothballs - how are you ?
Re: Need Help w/Electrical Problem [Re: sogtx] #2359389
08/24/17 11:07 PM
08/24/17 11:07 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Hey Andy, I am good, just been really busy and had a frustrating experience getting my motor rebuilt after I wrecked it at NYIRP.
It'll probably never be nice, but I am hoping it's close to being reliable and roadworthy.
If you are ever driving around stop by, I'll send you a PM where I live now.
Re: Need Help w/Electrical Problem [Re: GregY] #2359449
08/25/17 01:37 AM
08/25/17 01:37 AM
Shoreline, Washington
72roadrunnergtx Offline
The front turn signal socket is crimped into the pot metal housing, I’ve found ground continuity problems between the socket and housing from time to time. Slightly twisting the socket in the housing can temporally restore a ground path to the socket, or better yet provide alternate ground path to the socket sleeve.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Need Help w/Electrical Problem [Re: 72roadrunnergtx] #2359492
08/25/17 08:19 AM
08/25/17 08:19 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Thank you for all of the help, hopefully I have enough ideas now to get this straightened out.
Greg
Re: Need Help w/Electrical Problem [Re: GregY] #2359503
08/25/17 09:24 AM
08/25/17 09:24 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Punch in ( gently ) couple of sections of the socket outer lip against the housing to "restore" the ground path between socket and housing, very tipical problem. The socket looses the installing pressure with housing
