Need Help w/Electrical Problem
#2358780
08/23/17 09:37 PM
08/23/17 09:37 PM
Posts: 1,194 Rochester, New York
GregY
Rochester, New York
Hi All,
I am trying to track down an electrical problem with my 71 Charger and could use some guidance/help.
Lights off, turn signals and flashers work perfectly.
When I put the lights on, the left turn signal indicator in the instrument panel comes on steady. All of the lights are on (headlights, sidemarker, tail, etc.). The right turn signal works fine, but the left turn signal flashes very slowly.
It is not a fuse, and I am assuming it is not a ground problem as all of the lights work. Can anybody give me some advice on tracking this down?
Thanks.
Greg
Re: Need Help w/Electrical Problem
[Re: GregY]
#2358783
08/23/17 09:43 PM
08/23/17 09:43 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Looks like one of the lights is grounding thru the turn signal. Clean the grounds, starting in the area of the outside turn signals.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: GregY]
#2358800
08/23/17 10:23 PM
08/23/17 10:23 PM
Posts: 5,836 ohio
ruderunner
ohio
Headlight and front marker light grounds are most likely suspects.
Angry white pureblood male
[Re: ruderunner]
#2358803
08/23/17 10:34 PM
08/23/17 10:34 PM
GregY
Rochester, New York
When I disconnect the left turn signal from the left sidemarker light, it fixes the steady turn signal light on the instrument panel, and everything works, except of course the left turn signal. When I plug it back in, there's my problem.
I redid the one ground that I know of, that grounds all the front end lights I believe. That didn't fix it.
Is the turn signal connector bad, or something in the turn signal housing?
[Re: stumpy]
#2358998
08/24/17 08:51 AM
08/24/17 08:51 AM
GregY
Rochester, New York
The inside of the bulb housing looks fine, but the one screw in the bottom of the valance is super rusty, I am wondering if that has something to do with it, are those screws grounding the housing (electrical stuff is not my strong point)?
Thanks for the help.
Greg
[Re: GregY]
#2359503
08/25/17 09:24 AM
08/25/17 09:24 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Punch in ( gently ) couple of sections of the socket outer lip against the housing to "restore" the ground path between socket and housing, very tipical problem. The socket looses the installing pressure with housing
