MoPar "curtis" key cutter #2357689
08/21/17 05:17 PM
08/21/17 05:17 PM
Finally a HUSKER again
Moparnut426 Offline OP
the dealer I work for had the dealer key cutter that you use the codes and set the levers and it cuts a key per vin. Well the parts manager gave me a huge tote full of key blanks, tumblers kits, and such along with the old cutter.
Just no code book or vin number sheet.
Is there a website I can subscribe to that would have the codes?
Id love to set up shop and be able to cut vintage MoPar key with some of my NOS key blanks.
Kasey
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2357777
08/21/17 08:24 PM
08/21/17 08:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Car thieves would love to find that information available online also.
So your chances of finding a way to match VINs to keys are not good.
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2357803
08/21/17 09:21 PM
08/21/17 09:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Kasey
Call 1 800-398-2458 or 1 602-795-8247 Hawley Lock
They'll have factory Chrysler/Curtis code books from the 50's on up, generally under $100 new and used
And there's always Ebay...
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2357810
08/21/17 09:40 PM
08/21/17 09:40 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I don't think they have a book that matches to the VIN number. They match to the number that is stamped on the lock itself. I've got one of those cutter and the book that you are looking for. It takes the number stamped on the lock and translates it to the correct depth of cut for each position on the key. I would go buy some new blanks to practice on. Those NOS originals are too valuable to waste.
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2358033
08/22/17 10:41 AM
08/22/17 10:41 AM
I have a couple Cuda locks I can practice on. It was just something I was considering to do to help some of us old car guys out.
I know I can call a dealer with the old set up, my shop only has the new double sided key and codes available. The single sided keys are harder to find the info on.
I just hate calling another shop for something if I can get it myself.
Ill try the codes on the lock cylinders first.
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2358263
08/22/17 07:56 PM
08/22/17 07:56 PM
central,pa
P
ply64post Offline
ply64post  Offline
P
central,pa
To cut the keys with the cutter, there was tags that came with the cars when new.There was a tag for the ignition,door and one for the trunk and glovebox. You copied the numbers off the tags and kept the numbers in a safe place and disposed the tags. If you had to get keys cut, you gave these numbers to the dealer and they would cross reference in the key book for the code to cut the key.I know because I did it.
Hope this will help
Jeff
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2358274
08/22/17 08:20 PM
08/22/17 08:20 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Is the cutter still sharp? They get dull over time. I agree that if the dealer didn`t write the codes down from the tags and put it on their paperwork the owner was SOL. Unless of course the owner kept the key ring tags.
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2358722
08/23/17 07:28 PM
08/23/17 07:28 PM
Its sharp as I just went through it and sharpened it on a buddies surface grinder.
Re: MoPar "curtis" key cutter [Re: Moparnut426] #2359712
08/25/17 03:55 PM
08/25/17 03:55 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm curious, do you have the #14 Curtiss with the big wheel or the #15 that has the cross slide?
