Re: MoPar "curtis" key cutter
[Re: Moparnut426]
#2357803
08/21/17 09:21 PM
08/21/17 09:21 PM
Posts: 18,157 Mass
DAYCLONA
Mass
the dealer I work for had the dealer key cutter that you use the codes and set the levers and it cuts a key per vin. Well the parts manager gave me a huge tote full of key blanks, tumblers kits, and such along with the old cutter.
Just no code book or vin number sheet.
Is there a website I can subscribe to that would have the codes?
Id love to set up shop and be able to cut vintage MoPar key with some of my NOS key blanks.
Kasey Call 1 800-398-2458 or 1 602-795-8247 Hawley Lock They'll have factory Chrysler/Curtis code books from the 50's on up, generally under $100 new and used And there's always Ebay...
[Re: Moparnut426]
#2358263
08/22/17 07:56 PM
08/22/17 07:56 PM
Posts: 131 central,pa
ply64post
central,pa
To cut the keys with the cutter, there was tags that came with the cars when new.There was a tag for the ignition,door and one for the trunk and glovebox. You copied the numbers off the tags and kept the numbers in a safe place and disposed the tags. If you had to get keys cut, you gave these numbers to the dealer and they would cross reference in the key book for the code to cut the key.I know because I did it.
Hope this will help Jeff
[Re: Moparnut426]
#2359712
08/25/17 03:55 PM
08/25/17 03:55 PM
Posts: 10,694 North Dakota
6PakBee
North Dakota
the dealer I work for had the dealer key cutter that you use the codes and set the levers and it cuts a key per vin. Well the parts manager gave me a huge tote full of key blanks, tumblers kits, and such along with the old cutter. I'm curious, do you have the #14 Curtiss with the big wheel or the #15 that has the cross slide?
