Who's the coolant system expert in here? #2355566
08/17/17 05:34 PM
08/17/17 05:34 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
I'd like to pick someone's brain about coolant systems. Starting with a new virgin system, would like to get it right the first time.
Re: Who's the coolant system expert in here? [Re: Donny] #2355573
08/17/17 05:45 PM
08/17/17 05:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should state a few facts here.. what is the
purpose and what car and engine
wave
Re: Who's the coolant system expert in here? [Re: Donny] #2355604
08/17/17 06:31 PM
08/17/17 06:31 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
408
3/4 block fill
Street strip car
Have nice alum griff rad for the application
Std Carter water pump
I've been reading a lot about Evans waterless coolant , I'm intrigued.
I understand that strikers tend to run hotter engine oil too.
Re: Who's the coolant system expert in here? [Re: Donny] #2355641
08/17/17 08:18 PM
08/17/17 08:18 PM
AndyF Offline
AndyF  Offline
If you already have the water pump and the radiator then you have pretty much locked in your solution. Just make sure you have a good shroud and a big steel fan like one from an Imperial or a pickup truck. Use a clutch fan and a large crank pulley so you are overdriving the fan and water pump. You want as much water velocity thru the radiator as you can get. The more water you push thru the radiator the more cooling you will get.
With a filled block you might need to run an oil cooler too but that is a slightly different topic. Just put it together and drive it and see what happens.
Re: Who's the coolant system expert in here? [Re: Donny] #2355652
08/17/17 08:36 PM
08/17/17 08:36 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By Donny
408
3/4 block fill
Street strip car
I have a friend that tried evans coolant in his car. It's a 454 LSX with a turbo, and a big water to air intercooler in the nose. '85 mustang. This is a street driven car, thats been 8.20's on 16psi.
anyway, he tried out the evans coolant. and yes, his water temp DID go down, 12* from where it used to run. BUT the OIL TEMP went UP. To just under 300* before he could shut it down. and this was just under normal driving.
The heat has to go somewhere, right?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Who's the coolant system expert in here? [Re: Spaceman Spiff] #2355712
08/17/17 09:55 PM
08/17/17 09:55 PM
Washington
madscientist Offline
Washington
408
3/4 block fill
Street strip car
The heat should have went to the radiator and to the air. It will take the least path of resistance.
Re: Who's the coolant system expert in here? [Re: Donny] #2355734
08/17/17 10:17 PM
08/17/17 10:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Make sure the entire radiator and bulkhead is sealed to the hood (small: inner tube slice, big: foam A/C sealer), any air passing the grill must go through the core.
Vacuum advance!!!!
If 727 with high stall, I suggest a Tru-Cool ATF cooler with a thermal bypass.
Stay away from any with their own fan - the fan lasts 6 months, then you're stuck.
Boffin Emeritus
Re: Who's the coolant system expert in here? [Re: polyspheric] #2356074
08/18/17 03:04 PM
08/18/17 03:04 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
My griff radiator has built in trans cooler awith a built in elec fan, I will install an eng oil cooler and shroud when the build requires it.
My take away frm the Evans stuff is this, it will NOT corrode engine parts, it will keep engine parts cooler but the coolant itself may be hotter (which isn't necessarily a bad thing, as long as you get it to the radiator and your rad does it's job properly), all in all the car might (NOT will might) run at a higher temp but it will NOT overheat.
Re: Who's the coolant system expert in here? [Re: Donny] #2356121
08/18/17 04:17 PM
08/18/17 04:17 PM
AndyF Offline
AndyF  Offline
Coolant system design is an engineering problem, not a marketing gimmick.
The key issue is temp differential between inlet and outlet. So if you put 180 degree hot water into one side of the radiator how cold is it when it comes out. The bigger the delta then the better the cooling system.
That is really the only thing that matters, everything else works to make the differential happen. Water velocity, system pressure, fan size and speed, etc. All of those things are working together to create the temp differential across the radiator. If you pay attention to the temp differential you'll figure out what works and what doesn't.
Re: Who's the coolant system expert in here? [Re: AndyF] #2357829
08/21/17 10:07 PM
08/21/17 10:07 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
Everything I'm reading says it's much more than that. Heat transfer from metal engine parts to the coolant is the basis of coolant systems. Coolant can only retain so much heat, it works very much like a sponge, and a sponge can become full. So can coolant. If it becomes full, too hot, it cannot drag any more heat away from the engine as it passes thru.
Re: Who's the coolant system expert in here? [Re: Donny] #2357841
08/21/17 10:33 PM
08/21/17 10:33 PM
AndyF Offline
AndyF  Offline
I don't think that is a good example. Water will keep absorbing heat until it boils so as long as the water isn't boiling then the system will work. The pressure cap on the radiator allows the water to absorb more heat since it delays boiling. If you are boiling a pressurized system then you have a major design issue.
If you are working on something fairly normal then you don't really need to get very deep into cooling system theory. Normal off the shelf parts should get the job done. If you are building land speed record car or something like that then you might want to hire a guy like me to engineer a solution but 90% of guys building cars can get the job done with parts out of the Summit catalog.
Re: Who's the coolant system expert in here? [Re: Donny] #2357843
08/21/17 10:36 PM
08/21/17 10:36 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
I'm not trying to over think anything here or build anything crazy, I'm just looking at Evans as an advantageous way to ensure longer lasting engine parts. No corrosion and no overheating.
Re: Who's the coolant system expert in here? [Re: Donny] #2357985
08/22/17 05:15 AM
08/22/17 05:15 AM
CA
62SAVOY Offline
62SAVOY  Offline
CA
What about using the RedLine Water Wetter in with the coolant. I did everything to get my 70 D200 to run cooler. Heavy truck and always liked to run at 210 no matter hi flow water pump or moving the trans cooler to a separate set of coolers from the radiator. Had a race shop said to try it. Poured it in and went to 190 on temps after that. May not work the same for everyone or have some other bad effect I have not seen yet but it worked for me at least.
