Re: Who's the coolant system expert in here?
[Re: Donny]
#2355652
08/17/17 08:36 PM
08/17/17 08:36 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
408 3/4 block fill
Street strip car
Have nice alum griff rad for the application Std Carter water pump
I've been reading a lot about Evans waterless coolant , I'm intrigued.
I understand that strikers tend to run hotter engine oil too. I have a friend that tried evans coolant in his car. It's a 454 LSX with a turbo, and a big water to air intercooler in the nose. '85 mustang. This is a street driven car, thats been 8.20's on 16psi. anyway, he tried out the evans coolant. and yes, his water temp DID go down, 12* from where it used to run. BUT the OIL TEMP went UP. To just under 300* before he could shut it down. and this was just under normal driving. The heat has to go somewhere, right?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2355712
08/17/17 09:55 PM
08/17/17 09:55 PM
Posts: 4,457 Washington
madscientist
Washington
408 3/4 block fill
Street strip car
I understand that strikers tend to run hotter engine oil too. I have a friend that tried evans coolant in his car. It's a 454 LSX with a turbo, and a big water to air intercooler in the nose. '85 mustang. This is a street driven car, thats been 8.20's on 16psi. anyway, he tried out the evans coolant. and yes, his water temp DID go down, 12* from where it used to run. BUT the OIL TEMP went UP. To just under 300* before he could shut it down. and this was just under normal driving. The heat has to go somewhere, right? The heat should have went to the radiator and to the air. It will take the least path of resistance.
[Re: Donny]
#2355734
08/17/17 10:17 PM
08/17/17 10:17 PM
Posts: 4,209 New York
polyspheric
New York
Make sure the entire radiator and bulkhead is sealed to the hood (small: inner tube slice, big: foam A/C sealer), any air passing the grill must go through the core. Vacuum advance!!!!
If 727 with high stall, I suggest a Tru-Cool ATF cooler with a thermal bypass. Stay away from any with their own fan - the fan lasts 6 months, then you're stuck.
Boffin Emeritus
[Re: AndyF]
#2357829
08/21/17 10:07 PM
08/21/17 10:07 PM
Posts: 141 Ohio, USA
Donny
Ohio, USA
Coolant system design is an engineering problem, not a marketing gimmick.
The key issue is temp differential between inlet and outlet. So if you put 180 degree hot water into one side of the radiator how cold is it when it comes out. The bigger the delta then the better the cooling system.
That is really the only thing that matters, everything else works to make the differential happen. Water velocity, system pressure, fan size and speed, etc. All of those things are working together to create the temp differential across the radiator. If you pay attention to the temp differential you'll figure out what works and what doesn't. Everything I'm reading says it's much more than that. Heat transfer from metal engine parts to the coolant is the basis of coolant systems. Coolant can only retain so much heat, it works very much like a sponge, and a sponge can become full. So can coolant. If it becomes full, too hot, it cannot drag any more heat away from the engine as it passes thru.
