74 Slap stic shifter Ball shifter to T handle easy swap out? #2357448
08/21/17 08:46 AM
08/21/17 08:46 AM
SINY
SanityLost Offline OP
SINY
Wondering IF a car say a 74 Road Runner that has the simulated wood ball shifter, How hard or easy is it to switch it over to the T handle shifter? Is it a matter of removing it and replacing with the other?
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: SanityLost] #2357450
08/21/17 09:12 AM
08/21/17 09:12 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
The stalks are different so it's not a simple change of the ball to handle.
Red
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: BIGGERED] #2357510
08/21/17 11:50 AM
08/21/17 11:50 AM
moparx Offline
moparx  Offline
from my old memory, the ball shifters were round, while the t-handle shifters were either a rectangular stalk, or a round one that was a smaller diameter than the ball knob shifter. years ago, i machined a small, round, push button shifter knob to replace the cracked t-handle on my brother's sattelite/roadrunner from 1" [or so] round aluminum stock. worked as good, or better, than the t-handle, and looked good as well. it was a simple, two piece deal with a spring and retaining set screw. super easy to make. when the car was scrapped, i kept the knob. it resides in the "mess" somewhere.......
beer
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: SanityLost] #2357602
08/21/17 02:47 PM
08/21/17 02:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Your 74 came with the round knob from the factory. They went back to the round knob since the T handles were prone to cracking.
The entire mechanism is different. The round knob shifters use a round shaft. The T handles use rectangular shaft.(with rounded ends) The plastic shifter slide is also different. It matches the shaft shape.(round for ball shifters and rectangular for T handles)
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: SanityLost] #2357636
08/21/17 03:40 PM
08/21/17 03:40 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
I've heard the 74's were about half and half on the shifters. But maybe that was just e-bodies. T-handles are horrible. Don't swap unless you have to is my two cents.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: Michael Ecks] #2357912
08/22/17 12:27 AM
08/22/17 12:27 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Exactly.
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: SanityLost] #2358063
08/22/17 12:15 PM
08/22/17 12:15 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Just a note on T-handles. I have several of them: one NOS Mopar replacement, a much taped up one that came with the car and an aftermarket reproduction.
The replacement and the original are identical in construction.
The aftermarket repop is remarkably stouter using much thicker plastic in the base of the handle where the cracks usually start. It still fits in the shifter slot but has not shown any evidence of wanting to fail. May be the only repop that came out better than the original.
Craig
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: SanityLost] #2358075
08/22/17 12:43 PM
08/22/17 12:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The repro doesn't have a quality chrome and the relesase button spring, thats all. But original pieces ( spring and button/bezel ) fits on the repro handle the same. BTDT.
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: Jim_Lusk] #2358185
08/22/17 05:33 PM
08/22/17 05:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Exactly.
I guess it's like blonds or brunettes, personally I like the T handle much better.
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: SanityLost] #2358259
08/22/17 07:51 PM
08/22/17 07:51 PM
Columbus, GA
Columbus, GA
Blonde or brunette, when it throws my car into reverse at 50 miles per hour because I slap it too hard... it gots to go.
I went with the redhead option and put a mopar auto grip in mine. Never skipped a gate since. That's the pistol grip style shifter made by quapman on this board.
I do see that classic industries says their T-handle is supposed to be engineered better than the originals, so I may give one a try again someday.
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: Michael Ecks] #2358317
08/22/17 09:41 PM
08/22/17 09:41 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
When I said it's a simple job I meant just that, but no where did I say you just take off t-handle and install ball type. You have to change the shifter mech. which is held in with 4 bolts.
Ron
Re: 74 Slap stic shifter Ball shifter to T handle easy swap out? [Re: SanityLost] #2358470
08/23/17 10:22 AM
08/23/17 10:22 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I got the repro t handle and I'm REALLY satisfied with it! Perfect piece. You can't tell which on is original and which one not. Except for the chrome pieces, the handle itself is quite perfect.
After couple of years my repro T handle Chromed pieces were already with chrome gone by friction. I DRIVE my car daily. Is just like it somehow over sprayed paint, instead a chromed thick layer like the original one. I found a broken T handle locally with perfect chromed pieces and installed them. Also installed the preload button which repro didn't got.
Aaand about which one I likes more... T handle is the best looking one to me on an auto setup. I don't like the others on an auto floor console.
