Re: 74 Slap stic shifter Ball shifter to T handle easy swap out?
[Re: BIGGERED]
#2357510
08/21/17 11:50 AM
08/21/17 11:50 AM
Posts: 19,310 north of coder
moparx
from my old memory, the ball shifters were round, while the t-handle shifters were either a rectangular stalk, or a round one that was a smaller diameter than the ball knob shifter. years ago, i machined a small, round, push button shifter knob to replace the cracked t-handle on my brother's sattelite/roadrunner from 1" [or so] round aluminum stock. worked as good, or better, than the t-handle, and looked good as well. it was a simple, two piece deal with a spring and retaining set screw. super easy to make. when the car was scrapped, i kept the knob. it resides in the "mess" somewhere.......
[Re: SanityLost]
#2357636
08/21/17 03:40 PM
08/21/17 03:40 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
I've heard the 74's were about half and half on the shifters. But maybe that was just e-bodies. T-handles are horrible. Don't swap unless you have to is my two cents.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#2357912
08/22/17 12:27 AM
08/22/17 12:27 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
I've heard the 74's were about half and half on the shifters. But maybe that was just e-bodies. T-handles are horrible. Don't swap unless you have to is my two cents. Exactly.
[Re: SanityLost]
#2358063
08/22/17 12:15 PM
08/22/17 12:15 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Just a note on T-handles. I have several of them: one NOS Mopar replacement, a much taped up one that came with the car and an aftermarket reproduction. The replacement and the original are identical in construction. The aftermarket repop is remarkably stouter using much thicker plastic in the base of the handle where the cracks usually start. It still fits in the shifter slot but has not shown any evidence of wanting to fail. May be the only repop that came out better than the original. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: SanityLost]
#2358075
08/22/17 12:43 PM
08/22/17 12:43 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
The repro doesn't have a quality chrome and the relesase button spring, thats all. But original pieces ( spring and button/bezel ) fits on the repro handle the same. BTDT.
[Re: Jim_Lusk]
#2358185
08/22/17 05:33 PM
08/22/17 05:33 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I've heard the 74's were about half and half on the shifters. But maybe that was just e-bodies. T-handles are horrible. Don't swap unless you have to is my two cents. Exactly. I guess it's like blonds or brunettes, personally I like the T handle much better.
[Re: SanityLost]
#2358259
08/22/17 07:51 PM
08/22/17 07:51 PM
Michael Ecks
Columbus, GA
Blonde or brunette, when it throws my car into reverse at 50 miles per hour because I slap it too hard... it gots to go.
I went with the redhead option and put a mopar auto grip in mine. Never skipped a gate since. That's the pistol grip style shifter made by quapman on this board.
I do see that classic industries says their T-handle is supposed to be engineered better than the originals, so I may give one a try again someday.
[Re: SanityLost]
#2358470
08/23/17 10:22 AM
08/23/17 10:22 AM
NachoRT74
Valencia, España
I got the repro t handle and I'm REALLY satisfied with it! Perfect piece. You can't tell which on is original and which one not. Except for the chrome pieces, the handle itself is quite perfect.
After couple of years my repro T handle Chromed pieces were already with chrome gone by friction. I DRIVE my car daily. Is just like it somehow over sprayed paint, instead a chromed thick layer like the original one. I found a broken T handle locally with perfect chromed pieces and installed them. Also installed the preload button which repro didn't got.
Aaand about which one I likes more... T handle is the best looking one to me on an auto setup. I don't like the others on an auto floor console.
