Ebody disc brake kit on a A body, or use E body spindle on A #2357546
08/21/17 01:13 PM
08/21/17 01:13 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Two questions that are similar
1) Can you use an E body brake it (Baer/Wilwood 13"-14") on 73+ Abody spindles, on an A body?
2) Could you use 70 Cuda spindles on an A body to run a Cuda disc brake kit on an A body?
I ask because Baer does not list a kit for A bodies in the 13-14" size. If the spindles are the basically the same I would think it would work, assuming you have the big ball joint A arms as well.
Re: Ebody disc brake kit on a A body, or use E body spindle on A [Re: NV69B7RR] #2357558
08/21/17 01:37 PM
08/21/17 01:37 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
70 E body spindles have a smaller inner bearing than the 73/76 A body spindles, which mean the rotors are different. If you already have spindles Dr Diff has a spacer so you can use the bigger bearings.
Re: Ebody disc brake kit on a A body, or use E body spindle on A [Re: NV69B7RR] #2357634
08/21/17 03:38 PM
08/21/17 03:38 PM
AndyF Online content
AndyF  Online Content
Baer has never figured out Mopar applications. I tried to help them out 10 years ago but they weren't too interested in learning. E body knuckles fit on A body cars so the brakes will interchange. You might have other issues to sort out such as track width and upper ball joint size depending on the year of the A body.
Re: Ebody disc brake kit on a A body, or use E body spindle on A [Re: NV69B7RR] #2357939
08/22/17 01:07 AM
08/22/17 01:07 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks for the replies! It gives me something to think about.
Re: Ebody disc brake kit on a A body, or use E body spindle on A [Re: NV69B7RR] #2357970
08/22/17 02:35 AM
08/22/17 02:35 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
73-74 E-body spindles are the same as 73-76 A-body spindles. Larger inner bearing.
70-72 E-body spindles are the same as 70-72 B-body spindles. Smaller inner bearing.
