Strut rod's don't have a press-pin hole #2357383
08/21/17 01:12 AM
08/21/17 01:12 AM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
We noticed yesterday there is no hole in either of my strut rod's. Chrysler put a press-pin in those from the factory. Is it possible to drill a hole in those while on the car? Or are they hardened and would break many drillbits. thanks.
Still looking for LM29H1B415501, '71 Demon 340
Re: Torsion bars don't have a press-pin hole [Re: PAULS_340] #2357384
08/21/17 01:18 AM
08/21/17 01:18 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I don't think I have ever seen a torsion bar with a pin in it. A clip in the rear socket is all I remember. Where would the pin go?
Re: Torsion bars don't have a press-pin hole [Re: PAULS_340] #2357386
08/21/17 01:19 AM
08/21/17 01:19 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
A hole in the torsion bars? There should be a hole in the end of the strut rods for a roll pin but nothing in the torsion bars.
Re: Torsion bars don't have a press-pin hole [Re: PAULS_340] #2357389
08/21/17 01:23 AM
08/21/17 01:23 AM
Grand Prairie,Texas
Grand Prairie,Texas
iagree
Re: Torsion bars don't have a press-pin hole [Re: stumpy] #2357393
08/21/17 01:31 AM
08/21/17 01:31 AM
Motown, Mi
P
P
Motown, Mi
Thanks burdar for reminding me they are strut rods...it's late and I should just quit for the day.
Re: Torsion bars don't have a press-pin hole [Re: PAULS_340] #2357399
08/21/17 01:36 AM
08/21/17 01:36 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Factory strut rods seem to bend fairly easily. I wouldn't think it would be difficult to drill one. Not sure about an aftermarket one. Try it and see. I'd be interested to hear what others think...is a roll pin really needed? Has anyone ever seen a nut back off on a strut rod?
Re: Torsion bars don't have a press-pin hole [Re: burdar] #2357424
08/21/17 02:54 AM
08/21/17 02:54 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Didn't the factory stop using the roll pin around 70?
Re: Torsion bars don't have a press-pin hole [Re: PAULS_340] #2357446
08/21/17 07:33 AM
08/21/17 07:33 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
My '73 Dart has pin-holes in the strutrods but also selflocking nuts that work just as good.
Re: Torsion bars don't have a press-pin hole [Re: BigBlockMopar] #2357499
08/21/17 11:39 AM
08/21/17 11:39 AM
moparx Offline
moparx  Offline
from what i remember back when those cars were new [i have "oldtimers" disease now, so keep that in mind], weren't those pins quite a way from the nut edge ? if so, the nut would have to back off a bunch before the pin would be of any value, and would certainly cause issues suck as "clanking" or "squeak/creaking" sounds some would investigate before the nut would come off. just my old memory at work here, so be gentle please.
beer
Re: Torsion bars don't have a press-pin hole [Re: PAULS_340] #2357509
08/21/17 11:48 AM
08/21/17 11:48 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Drill baby drill!
Re: Torsion bars don't have a press-pin hole [Re: PAULS_340] #2357517
08/21/17 12:00 PM
08/21/17 12:00 PM
A727Tflite Offline
A727Tflite  Offline
Your original post WAS for strut rods - someone changed it to Torsion bar.
If the nut were to start backing off the car would pull badly to the side with the loose nut. The strut rod controls toe out throughout the range of lower control arm travel. As for drilling it - that shouldn't be a problem if you are thinking of drilling it.
Re: Torsion bars don't have a press-pin hole [Re: A727Tflite] #2357584
08/21/17 02:31 PM
08/21/17 02:31 PM
dogdays Offline
dogdays  Offline
Best done off the car with a drill press and a V-block. Though I really don't think they are necessary.
R.
Re: Strut rod's don't have a press-pin hole [Re: PAULS_340] #2357590
08/21/17 02:38 PM
08/21/17 02:38 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
His original post said "torsion bar". He changed it to "strut rod" after Stumpy and I questioned it.
My 73 uses a locking nut AND a roll pin. The pin isn't even close to the lock nut once installed.
Re: Strut rod's don't have a press-pin hole [Re: burdar] #2357608
08/21/17 02:54 PM
08/21/17 02:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Has anybody ever seen a strut rod nut back off enough to get anywhere near the pin? I always thought the pin was silly.
Re: Strut rod's don't have a press-pin hole [Re: John_Kunkel] #2357638
08/21/17 03:41 PM
08/21/17 03:41 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes, it's a longshot having the locknut back off. Besides the locknut, it is initially tightened to a positive stop with that sleeve being in there.
Re: Strut rod's don't have a press-pin hole [Re: PAULS_340] #2357697
08/21/17 05:29 PM
08/21/17 05:29 PM
The Netherlands
The Netherlands
My '73 Dart (I know there's something missing behind the washer)
Re: Strut rod's don't have a press-pin hole [Re: BigBlockMopar] #2357833
08/21/17 10:19 PM
08/21/17 10:19 PM
chicagoland,usa
chicagoland,usa
Well, that should be doing some strange stuff when you pile on the brakes...
Re: Strut rod's don't have a press-pin hole [Re: BigBlockMopar] #2357858
08/21/17 11:01 PM
08/21/17 11:01 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
My 77 pickup doesn't have a hole for pins. I really don't think they are necessary.
Re: Strut rod's don't have a press-pin hole [Re: elmor353] #2357921
08/22/17 12:44 AM
08/22/17 12:44 AM
Motown, Mi
P
P
Motown, Mi
So my driver side Strut bar nut did work its way almost off last year. A little thread lock and it's fine now. I noticed this weekend several Abody's with the pin. Good drilling project this winter when/if I pull the engine. Thanks
Re: Strut rod's don't have a press-pin hole [Re: PAULS_340] #2358015
08/22/17 09:35 AM
08/22/17 09:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC my 65 didnt have pins.Replaced them like 15 or so years ago with RMS ones with heims.No more problems with bushings etc.Rocky
Chrysler Firepower
