Re: 70 roadrunner hemi power brakes/non power
[Re: metalgod]
#2356868
08/19/17 11:36 PM
08/19/17 11:36 PM
RapidRobert
If the MC has the shallow circular recess around the bore of the rear piston about halfway down which is needed for the manual brake pushrod snip of neoprene to lock into then I would keep it & the prop valve & see how it acts. You might very well be fine as is & you would not have to even open up the system.
[Re: metalgod]
#2357181
08/20/17 04:59 PM
08/20/17 04:59 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Wondered why you are removing the Booster. Is the booster a non Hemi Booster and are having trouble with clearance to the Valve cover. If you do it with a complete conversion via someone like Wilwood you likely will not be doing it again until your return to the stock with a restoration to the Runner. Keep all parts you take off in a box for the future.
1971 HEMI E BODY REGISTRY
