70 roadrunner hemi power brakes/non power #2356805
08/19/17 09:13 PM
08/19/17 09:13 PM
phx
metalgod Offline OP
metalgod  Offline OP
phx
looking to remove power brake booster and swap to manual car has factory disc brakes, what master cylinder to use and does porportioning valve need to be changed as well?
Re: 70 roadrunner hemi power brakes/non power [Re: metalgod] #2356868
08/19/17 11:36 PM
08/19/17 11:36 PM
If the MC has the shallow circular recess around the bore of the rear piston about halfway down which is needed for the manual brake pushrod snip of neoprene to lock into then I would keep it & the prop valve & see how it acts. You might very well be fine as is & you would not have to even open up the system.
Re: 70 roadrunner hemi power brakes/non power [Re: metalgod] #2357168
08/20/17 04:26 PM
08/20/17 04:26 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
On my 70RR, front disk brakes from 73 A body I have no power booster. My MC is from a Dakota truck works fine..
Just my $0.02... wink
Re: 70 roadrunner hemi power brakes/non power [Re: metalgod] #2357181
08/20/17 04:59 PM
08/20/17 04:59 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Wondered why you are removing the Booster. Is the booster a non Hemi Booster and are having trouble with clearance to the Valve cover. If you do it with a complete conversion via someone like Wilwood you likely will not be doing it again until your return to the stock with a restoration to the Runner. Keep all parts you take off in a box for the future.
1971 HEMI E BODY REGISTRY
Re: 70 roadrunner hemi power brakes/non power [Re: metalgod] #2357280
08/20/17 09:21 PM
08/20/17 09:21 PM
KY
DougR Offline
DougR  Offline
KY
I did this combo on my 1970 Hemi Challenger. I used a master cylinder with the smallest bore I could get for the best hydraulic ratio. Sorry, I don't have the exact number. I did not change anything else and the brakes work great. I believe they are over-boosted with power brakes.
Re: 70 roadrunner hemi power brakes/non power [Re: DougR] #2358756
08/23/17 09:04 PM
08/23/17 09:04 PM
phx
metalgod Offline OP
metalgod  Offline OP
phx
Its the correct hemi booster and brackets the booster is shot i dont have time to have it rebuilt just want to replace with correct looking and functioning non power front disc brake master cylinder which one do i use?
Re: 70 roadrunner hemi power brakes/non power [Re: metalgod] #2358836
08/23/17 11:35 PM
08/23/17 11:35 PM
IN
ahy Offline
ahy  Offline
IN
I believe the manual setup uses a different pedal linkage... basically more leverage (and pedal travel) to get decent braking with manageable effort. Re-pop dual diaphram boosters are available (Dr Diff, MBM) suggest one of those... or new pedal linkage and likely smaller diameter master with manual brakes.
