correct length for e-body tire stud w/spacesaver spare? #235686
02/25/09 10:10 AM
02/25/09 10:10 AM
DELAWARE
TONY_DAGOSTINO Offline OP
DELAWARE
i know ive measured these before, but im coming up with conflicting info
what have you found?
Re: correct length for e-body tire stud w/spacesaver spare? [Re: TONY_DAGOSTINO] #235687
02/25/09 01:46 PM
02/25/09 01:46 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Studs
I think the curved stud is for a standard full size spare.
Re: correct length for e-body tire stud w/spacesaver spare? [Re: TONY_DAGOSTINO] #235688
02/25/09 02:16 PM
02/25/09 02:16 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Sorry to muddy the waters, but...
My 1970 Challenger convertible (Hamtramck, SPD 915) has a straight stud of the same style, in between the two lengths Snoopy pictured. About 8.25" to 8.5" (it's bolted in, so I can't get a precise measurement).
Down to just a blue car now.
Re: correct length for e-body tire stud w/spacesaver spare? [Re: 68HemiB] #235689
02/25/09 09:20 PM
02/25/09 09:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Mine (hardtop) is 6 1/4" OAL.
Re: correct length for e-body tire stud w/spacesaver spare? [Re: 68HemiB] #235690
02/25/09 11:08 PM
02/25/09 11:08 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
I don’t think that these hold down rods were manufactured with an absolute precision cut “length”. This was an area that I researched and found at least three (slightly) different lengths that could have been used for a 1970 E Body vehicle. They were all within a half inch of being the same length which leads me believe that a “dimension” was probably specified but not precisely followed by the subsidized manufacturer who supplied these to Chrysler. I found other “X” vehicle models that used rods very similar to those found in most Chrysler vehicles. It appears that whatever round stock was used to make these was in close proximity to other styles and could have easily been “swapped” or “mixed up” during the machining process. Some samples had the exact same rod length but used a different number or “length” of threads. The tips were also different. Some had a ¼” smooth machined tip at the end and others had threads that ran to the end of the rod. Most of those (threads to the tip) were in the larger B and C Body vehicles.
Re: correct length for e-body tire stud w/spacesaver spare? [Re: ECS] #235691
02/25/09 11:19 PM
02/25/09 11:19 PM
cataclysm80 Offline
cataclysm80  Offline
Tav
Re: correct length for e-body tire stud w/spacesaver spare? [Re: cataclysm80] #235692
02/26/09 01:02 AM
02/26/09 01:02 AM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
I remember years ago pre 2005 I had a pic on my old computer that had 3 lenths for challenger{i was just thinking about it the other day}
1 for hard top with regular spare and one for space saver
and 1 for convert but my memery is not what it used to be so waiting to see whats is posted
Re: correct length for e-body tire stud w/spacesaver spare? [Re: 340SIX] #235693
02/26/09 01:30 AM
02/26/09 01:30 AM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Off topic (kind of) but I documented at least five different lengths of lug nut/jack handles for E Body cars. The examples I researched during the Challenger project varied as much as an inch and a half in length! The measurements were all taken from ORIGINAL, unmolested 1970 Challengers. I don’t think the items in the trunk were a focal point of “exactness” in the overall scheme of things. From taking to guys who worked on the assembly line, they used whatever was available for certain items as long as it did not fall too far out of the specified dimensions. I would also conclude that when the assembly line ran low on certain variations of trunk items, the line manager would make an executive decision to substitute a different but similar part. You would never know the difference unless these parts were compared in a side by side fashion.
Re: correct length for e-body tire stud w/spacesaver spare? [Re: ECS] #235694
02/26/09 09:53 AM
02/26/09 09:53 AM
DELAWARE
DELAWARE
hi
thanks for your input, i know its valid and well researched when you post Dave!
but from what im seeing + hearing it appears there is about a 2" variance in lengths
someone has a 6-1/4" length + i have found 8" length in a few cars i researched (cudas)that just seams extreme for a part that you wouldnt have thought would run out that quickly
and also, its not like 90% of the cars are 1 way + there are a few exceptions to the rule, it almost appears that
there isnt a rule
i wouldnt think there would be a difference between cuda + challenger on this
thanks again for all of your input
tony
Re: correct length for e-body tire stud w/spacesaver spare? [Re: TONY_DAGOSTINO] #235695
02/26/09 10:32 AM
02/26/09 10:32 AM
PA
BS27ROB Offline
BS27ROB  Offline
PA
The one in my 70 Cuda conv. is about 8 1/4" OAL.
Re: correct length for e-body tire stud w/spacesaver spare? [Re: BS27ROB] #235696
02/26/09 01:53 PM
02/26/09 01:53 PM
Did they use the straight ones for verts and the bent ones for cars with a roof? What was the rule so to say?
Re: correct length for e-body tire stud w/space spare? [Re: TONY_DAGOSTINO] #235697
02/26/09 03:12 PM
02/26/09 03:12 PM
Snoopy Offline
Snoopy  Offline
I wouldn't think there would be a difference between cuda + challenger on this
Both cars where built at the same plants and used the same basic trunk pan, spare and other trunk accessories. Why would there be a difference in the wheel mounting stud?
I don't think the part was that critical. I would bet that if they ran out of the correct one, they would grab any stud that would fit just to keep the line flowing.
It appears that the "If there is a problem, let them sort it out at the dealer" rule applied in these situations.
I don't know about any of you, but in all the years I have owned cars, I don't ever remember having the desire to compare the length of my stud to someone else's. I wouldn't want to find out mine was to short. Who wants rod envy?
Here are the part numbers from an engineering print and the 70-71 parts book showing 3 different studs (rods) for 70-71 E-Bodies.
Re: correct length for e-body tire stud w/space spare? [Re: Snoopy] #235698
02/26/09 04:28 PM
02/26/09 04:28 PM
Would not the space saver be much longer since the tire, jack hook and bottle all go on it?
Re: correct length for e-body tire stud w/space spare? [Re: Snoopy] #235699
02/26/09 04:57 PM
02/26/09 04:57 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Who wants rod envy?
Oh great, now something else to lose sleep over.
Although mine IS over eight inches, as posted above.
Re: correct length for e-body tire stud w/space spare? [Re: 68HemiB] #235700
02/26/09 05:08 PM
02/26/09 05:08 PM
Snoopy Offline
Snoopy  Offline
Here is an old thread on the subject.
Re: correct length for e-body tire stud w/space spare? [Re: Snoopy] #235701
03/04/09 09:30 AM
03/04/09 09:30 AM
New Jersey Bada Bing
bremotorsports Offline
71 Cuda convertible
8-1/4"
Bill Rolik
Re: correct length for e-body tire stud w/space spare? [Re: bremotorsports] #235702
03/04/09 11:31 AM
03/04/09 11:31 AM
3
360six Offline
360six  Offline
74 Barracuda hardtop: 8 7/8 tip to tip straight,no curve
Re: correct length for e-body tire stud w/space spare? [Re: 340SIX] #235703
03/04/09 10:04 PM
03/04/09 10:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The jack hook does not go on the rod.
