Bolt on hub/bearing assembly #2354985
08/16/17 05:55 PM
08/16/17 05:55 PM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
Is anyone making a bolt on hub assembly yet for the old stuff, or is the answer still 'take an original rotor and turn it down in a lathe to make one'?
Looking for a hub assembly that fits onto the spindle and is held on with the original castle nut, that allows you to use slip on rotors.
**Photobucket sucks**
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2355003
08/16/17 06:26 PM
08/16/17 06:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I thought AndyF at one time had a solution, and Dr Diff, not sure what Ron Sutton offers in OEM bearings. bump
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2355024
08/16/17 07:05 PM
08/16/17 07:05 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The Dr Diff brake kits use one. It might increase the track width some...you'd have to ask Cass to be sure.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2355028
08/16/17 07:23 PM
08/16/17 07:23 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Any old front wheel 'brake drum' has these hubs 'incorporated' and would be easy to seperate and source to come by.
Drumbrake-hubs might even have a better (narrower) track width too.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2355111
08/16/17 10:10 PM
08/16/17 10:10 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My Wilwood hubs use slip on rotors. Factory e-body drum spindles.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Bolt on hub/bearing assembly [Re: BigBlockMopar] #2355117
08/16/17 10:18 PM
08/16/17 10:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That would be the smaller bearing set-up, correct?
Same option is not available in the big bearing?
Re: Bolt on hub/bearing assembly [Re: GoodysGotaCuda] #2355173
08/16/17 11:43 PM
08/16/17 11:43 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
Do you have pics or part numbers? I saw some wilwoods, but they looked like the kind of hub that uses a 2 piece rotor, and the friction surface bolts to the back side of the hub. I'd like to find hubs that use true slip on rotors so I can use any rotor with the right bolt pattern.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2355234
08/17/17 01:20 AM
08/17/17 01:20 AM
Winnipeg, Manitoba, Canada
JRC Offline
JRC  Offline
I also used Wilwood aluminum hubs, mine are for a 73 dodge a-body with disk brake spindles and using a true slip on 2pc rotors.
http://www.wilwood.com/Search/PartNoSearch.aspx?q=270-11533
Id post pics if i could. Im running the wilwood hub I linked along with 14" 2pc rotors, aluminum hats and wilwood GNIII calipers.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2355342
08/17/17 10:36 AM
08/17/17 10:36 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I don't have any disassembled photos but their instructions for the ebody kit has good exploded diagrams. My rotors are multi pattern slip on.
2020 RAM 1500
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2355361
08/17/17 10:56 AM
08/17/17 10:56 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Cass - Dr Diff. Aluminum.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2356133
08/18/17 04:40 PM
08/18/17 04:40 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Dr. Diff offers some good setups... he probably has exactly what you're looking for. I've seen a couple on local cars (HSAX/HPDE)... good quality, etc.
Re: Bolt on hub/bearing assembly [Re: jcc] #2356299
08/18/17 11:36 PM
08/18/17 11:36 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Only one I've heard of is '73- A body with drums, think it's small bolt pattern
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2356367
08/19/17 01:43 AM
08/19/17 01:43 AM
AndyF Online content
AndyF  Online Content
You are talking about two different things. You can buy aluminum hubs from Baer or Wilwood that use the factory style bearings and seals. I wouldn't really call that a bolt on hub assembly though. A hub assembly is what most of the new cars have where the bearings are all sealed in a hub assembly and the whole thing is held on with a big nut and a lot of torque.
I designed a setup like that for Mopar vehicles but I didn't have the money to tool it up. The design is fairly simple and it would provide a bunch of advantages but it would cost a ton of money to produce.
Re: Bolt on hub/bearing assembly [Re: AndyF] #2356425
08/19/17 07:36 AM
08/19/17 07:36 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
Andy, did you look at having Coleman build the spindles for that type of hub/bearing?
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2356863
08/19/17 11:29 PM
08/19/17 11:29 PM
No, I never talked to Coleman about the spindles. I designed up a Mopar knuckle with a Mustang stub axle (spindle) which allow a person to bolt on a Mustang sealed hub and then bolt on Mustang brakes and wheels. I figured that would be the cheapest way to go. The knuckle could've been built with a 1" drop also. Pretty simple concept but it takes $100K or more to make it happen and then some serious marketing in order to sell enough volume to recoup the investment. Just decided I wasn't going to risk my money on it since most Mopar guys are into the restoration end rather than the cornering thing.
Here is a picture of a few hubs I made back in the day. The black one is aluminum, the other ones are steel. Looks like I was trying different offsets.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2356913
08/20/17 01:37 AM
08/20/17 01:37 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
Sealed bearings would be cool, but I'd be ok with a hub assembly that uses hand packed wheel bearings, primary goal being a hub that I can slip any 5-lug rotor onto, allowing me to fabricate my own brake kit. I know there's some good kits out there but most are using wilwood or Baer calipers. I prefer to use Brembos found on OEM set ups for ease if replavement parts, and the reliability of an all weather caliper complete with dust boots vs the 'resto-mod' stuff that lacks boots.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2356946
08/20/17 02:46 AM
08/20/17 02:46 AM
If it was me I'd buy the Baer hubs and work from there. Baer stuff is much higher quality than anything that Wilwood makes. If you don't want to spend the money for the Baer stuff then get some drum brake hubs and start with them.
Re: Bolt on hub/bearing assembly [Re: 70Cuda383] #2356979
08/20/17 07:40 AM
08/20/17 07:40 AM
The Netherlands
The Netherlands
The different offsets in the hubs is a nice thing the a-body crowd would love.
Pretty much every discbrake conversion makes the trackwidth wider on these, while tire/fender clearance is already too close to run a decent width tire and a nice stance.
Too bad they're such cheap-a folks usually smile
Re: Bolt on hub/bearing assembly [Re: BigBlockMopar] #2357019
08/20/17 10:56 AM
08/20/17 10:56 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Really? This is an 18x9 +35mm wheel with a 275-35-18 on it with the Dr Diff Cobra brakes, nothing really custom here. Ideal would have been 2mm further in but it doesn't hit at all so I'm not concerned. You're just not going to be running a zero offset wheel.
Unless there's something special about Valiant/Duster fenders I don't know about, I don't see why this would be an issue on any 67-76 A-body.
I also have the B-body axle in the back to match.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Bolt on hub/bearing assembly [Re: goldduster318] #2357046
08/20/17 12:02 PM
08/20/17 12:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Which year(s) B-body axle are you running; 65-67 or 68-70?
